Author Topic: PD carb help  (Read 1770 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
PD carb help
« on: October 22, 2011, 07:55:59 AM »
I am helping a friend clean his PD carbs from a 1978 CB550k. Having never worked with these carbs before, can someone confirm whether the brass piece below the "tower" in the picture is a jet (slow?) that can be removed?
It's got a small hole at the top, and the thing is IN there. So before trying to unscrew it or pull it - I figured I should ask the experts.
Also, not sure how to get the carbs separated off the plate without a hassle - seems round, pivoting "doors" (can't recall the proper name) are all connected by the rod that runs the length of 2 carbs each.
Thanks in advance!
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: PD carb help
« Reply #1 on: October 22, 2011, 07:59:47 AM »
Yes, that jet pulls out, try some heat from a pencil torch.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
Re: PD carb help
« Reply #2 on: October 22, 2011, 09:25:14 AM »
Thanks Rigid!  The heat worked perfectly.
One more question (I hope!): does the float needle seat come out?  I can't see a place to grab onto it - or a placement for a chop stick on the other side either.
Appreciate the quick help.
Scott
~Sophocles
Offline TrueSpin
  • Not Really An
  • 1978 750F3
Re: PD carb help
« Reply #3 on: October 22, 2011, 09:41:33 AM »
Those are the choke butterflies, and yes, they do have to come off the shaft (unfortunately) to separate the carbs from each other.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
Re: PD carb help
« Reply #4 on: October 22, 2011, 09:46:41 AM »
Right!  Butterflies. Spaced out.
Do you know if these float needle seats come out?  Those would be the last of the brass bit in tere at this point.
Thanks!
~Sophocles
  • I'm back
Re: PD carb help
« Reply #5 on: October 22, 2011, 09:51:33 AM »
Why would you do that?
Just remove the float bowls.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
Re: PD carb help
« Reply #6 on: October 22, 2011, 09:59:37 AM »
He was looking to dip them in carb dip. Won't fit in the can when they are all 4 connected. They have been sitting in the elements, neglected for quite some time, so dip would not have been the worst idea. But I convinced him to just clean them on the plate.
Float needle seats?  Removable or no?
~Sophocles
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: PD carb help
« Reply #7 on: October 22, 2011, 10:10:17 AM »
Float needle seats should not be removeable. The PD carbs use a rubber-tipped float needle, the seat should not be a wear item.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
Re: PD carb help
« Reply #8 on: October 22, 2011, 10:14:12 AM »
Great. Thanks for the clarification.
~Sophocles
Re: PD carb help
« Reply #9 on: October 22, 2011, 11:49:25 AM »
The float seats must be drilled, or milled, for removal. (I've never done it, and I don't know where to get replacements.)
The float needles are not all rubber tipped from the factory.  Perhaps some were.
If the steel needles and seat don't seal upon closure, then I suggest lapping compound to re-mate the needle with the seat.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
Re: PD carb help
« Reply #10 on: October 22, 2011, 12:22:04 PM »
Thanks TT. He has the rubber style, so he should be good. Amazing how different these carbs are compared to my 087a.
~Sophocles
