Author Topic: Advise please - what to do with half of 750F?  (Read 1121 times)
« on: October 09, 2012, 07:26:31 PM »
I scored today. Originally I went for the engine only since the price was right but the guy had the whole front wheel/fork/tripple tree/discs/brakes/fender and rear wheel with brake, carburetors, air box, coils, cables, most of the harness.
The engine itself is clean and turns over easily - hand on kickstart lever - will do
compression test to confirm. Took off oil filter and pan, nothing in it bu remnants of oil that feels good between fingers. Spark plugs are grayish black - good  color.
I was looking for engine for a while since I have a K3 frame in the barn and I was thinking about piecing together a machine in the next year or so.
Now I have more than I expected and all those pieces are in great shape. The question is - is it worth the trouble to adapt F wheels to K3 frame? I suppose the engine will fit in the frame but I was wrong before.
My goal is a reliable and comfortable travelling bike for two - maybe with a sidecar in the future.
Oh the guy was selling all the parts and keeping the frame to build electrical motorcycle :)
Offline JohnG
  • 1976 CB750F - original owner
Re: Advise please - what to do with half of 750F?
« Reply #1 on: October 09, 2012, 07:50:26 PM »
One detailed way to check things is to get onto a website like BikeBandit and
compare actual part #s.  That removes alot of mystery.
IF it is a 75 or 76  F  then the front wheel will be the same as your K.
The rear wheel is quite different as the F wheel is designed for a disk brake and the K had a drum.
The engine should be identical.  What changes there are , are internal.  The manner in which the exhaust attaches is different but no big deal unless you wish to use an original 4-4.
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
Offline splitt
« Reply #2 on: October 09, 2012, 08:10:30 PM »
What year F is it? A 75F or 76F will drop straight in. I have a 76 CB750F in a 75 CB750K frame, straight swap. I'm also using the F wheels and front end. The 77 and 78 CB750F's are like the K models, the output shaft on the engine is offset 3/8" outboard compared to your K3. You can purchase offset sprockets to correct this.
What is the reason to run the F wheels?
BTW, Good score!
« Reply #3 on: October 10, 2012, 03:02:20 AM »
Thank you, guys.  The seller said it was 78 and I will check the serial number eventually.
The wheels are in great shape, tubeless and without spokes. Low maintenance and reliable and the rear disc is a bonus.
« Last Edit: October 10, 2012, 03:08:31 AM by 70CB750 »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: October 10, 2012, 04:34:22 AM »
I don't think the 78' Comstars are tubless. My 78 750F has the Comstar rims with tubes. The tire may be a tubeless tire, but I'm pretty sure the SOHC Comstars still require a tube. Good score by the way! Let me know if there's something you don't need!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #5 on: October 10, 2012, 04:52:42 AM »
You are probably right. I only looked at the tire not at the valve.
The bike must been in pretty good shape as far as I can tell from the pieces I got.
