Author Topic: GOLDEN CB750 BROOKLYN  (Read 28315 times)
Offline Syscrush
  • Sold. :(
Re: GOLDEN CB750 BROOKLYN
« Reply #25 on: March 07, 2013, 05:35:15 AM »
I love shorty exhausts.  Looks great.
Offline zuehl666
« Reply #26 on: March 07, 2013, 08:44:55 AM »
Thanks. It still has a removable baffle too, so it should sound decent.
Offline chris mcshifty
« Reply #27 on: March 09, 2013, 11:30:21 AM »
Sweet bike any update
Offline zuehl666
« Reply #28 on: March 11, 2013, 12:59:38 PM »
Left my camera in my friends car, sorry for the #$%*ty phone pics.
I got the motor painted and put back in saturday, its all black with stainless hardware, white valve cover and im still working on the sides, but they will most likely be a charcoal grey metallic. Also, the bottom rear motor mount bolt is way too long now that the pegs aren't mounted to it. Any ideas on what to do there? I'm thinking of running one bolt on either side and the nut will sit in the groove of the motor, kinda like the front right side mounting bolt works.
Offline Syscrush
  • Sold. :(
« Reply #29 on: March 11, 2013, 01:05:38 PM »
I just might ride to Brooklyn with a topcase full of beers to see this bike in person.
Online seanbarney41
« Reply #30 on: March 11, 2013, 01:38:22 PM »
For your motor mount bolt, just chop off some old crusty footpegs and use the remaining piece that the bolt goes through as a spacer.   You can grind, file, sand and paint to make it look nice
Offline kyre
    • CB400F / 466 Build Thread
« Reply #31 on: March 11, 2013, 05:00:33 PM »
Nice bike, def liking the gold flake also very jealous of the size of your work space!
CB400F / 466 Build Thread (currently in progress)
http://forums.sohc4.net/index.php?topic=105027.0
Offline zuehl666
« Reply #32 on: March 12, 2013, 09:32:49 AM »
Thanks. The space is out in jersey city. It's a shared space, always has spots open for rent if you're interested.
Offline zuehl666
« Reply #33 on: March 12, 2013, 09:35:42 AM »
Also, here's an idea of how the exhaust will lay out. Im pretty happy with it. Now I just need to clean the crust of it and paint it haha.
Offline Syscrush
  • Sold. :(
« Reply #34 on: March 12, 2013, 10:23:18 AM »
A couple of years ago I went to a small vintage Japanese bike show/gathering on N 14th street in Brooklyn.  If it's a recurring thing, your bike would fit in very well there once it's finished.
EDIT: OK, it wasn't all Japanese.  It was organized/hosted by NYCVMS.  Website here, no idea if they're doing it again this year or not.
« Last Edit: March 12, 2013, 10:25:50 AM by Syscrush »
Offline zuehl666
« Reply #35 on: March 18, 2013, 09:35:43 AM »
Cleaned up and painted the swing arm and rear wheel. Eventually I want to re-spoke with new spokes and paint the rims / hubs black. Still have to get a couple things like tires, battery, and a couple other little things. Next i'll have to do some more work on the exhaust. I ran into a little issue with the shifter side linkage... Running a straight piece is a pretty hard angle, it works fine just looks a little weird. So I bent up another piece I had to contour the motor which looks better and has more foot clearance, but on downshifting it flexes a bunch and hits the frame. So I'll have to figure something out there.
Offline Frankensteins Bride
« Reply #36 on: March 18, 2013, 09:47:47 AM »
Wow that is just fantastic! Can't wait to see her all done up! :) Watching now...
Working on: 78 Cb750k
Waiting for arrival: 73 Cb750
Frankensteins Wolf
Offline Syscrush
  • Sold. :(
« Reply #37 on: March 18, 2013, 10:03:03 AM »
Maybe some small gussets at the bends?
Offline zuehl666
« Reply #38 on: March 18, 2013, 10:29:34 AM »
That might do the trick, I was also thinking I could weld some kind of guide to the frame where it flexes, so it wont have the chance to flex at all. It's just threaded rod ran though an aluminum sleeve. Steel sleeving might even help out. I'll take some better pics of it this weekend when I get back in the shop.
« Reply #39 on: March 18, 2013, 05:22:27 PM »
Love that rear brake cover!!
Offline zuehl666
« Reply #40 on: March 22, 2013, 02:44:40 PM »
Does anyone know what the stock chain length is on a k1?and is 530 stock or 520? I keep finding different results. thanks
Online seanbarney41
« Reply #41 on: March 22, 2013, 02:57:07 PM »
530...100 links w/ 18f 48r tooth sprockets
Offline zuehl666
« Reply #42 on: March 25, 2013, 11:26:49 AM »
Thanks!
Offline zuehl666
« Reply #43 on: March 25, 2013, 11:32:10 AM »
I got the exhaust painted and temporarily mounted. The phillips head stud screws for the flanges were in bad shape, and generally a pain in the ass, so I ordered some allen head screws that will replace them.
« Reply #44 on: March 25, 2013, 11:42:05 AM »
Be carefull, going from phillips (actually JIS) to allen head can lead to thread stripping - you are able to apply much more force with allen wrench.
Offline zuehl666
« Reply #45 on: March 25, 2013, 11:54:56 AM »
I'll keep that in mind. Thanks
Offline zuehl666
« Reply #46 on: April 01, 2013, 11:42:05 AM »
I got the exhaust finally mounted up with new flange screws, the allen heads are much easier to work with. Finished painting the clutch cover, and other little bits. Sealed the tank with kbs gold standard, was pretty easy to work with.  Just ordered some new fork seals, gators, oil pressure gauge, so I should have all that buttoned up by the weekend.
Found this written under the clutch cover, thought that was pretty cool...
Offline sazaver
« Reply #47 on: April 01, 2013, 12:18:55 PM »
I love that fork brace, looks really oldscool.
I am in brooklyn too... keep up the pics
Offline zuehl666
« Reply #48 on: April 01, 2013, 02:33:45 PM »
Thanks man. The brace is fairly easy to make, tried to make it like the hoop braces they sell for xs650's. Where abouts in Brooklyn are you?
Offline sazaver
« Reply #49 on: April 01, 2013, 02:56:38 PM »
I am in West Williamsburg are, close to the Bridge.
