Author Topic: 1975 CB750 Front Wheel Moving Side to Side about 1cm in Fork - Help!  (Read 2255 times)
Offline andyvclifford
Hi,
My name is Andy, I am a first time poster long time reader of the forums.  I have a 1975 CB750 that I recently picked up about 2 months ago.  I have been slowly working on it bringing it back to road running condition.  Recently i was working on the front brakes and noticed when I had taken the brake off that the Front Wheel of the bike has about 1cm of play Left to Right on the axle as it sits in between the forks on the bike.  If you turn the handlebars all the way to the right it moves one way, and if you turn them all the way back it moves the other way.  I have included pictures below of the gap both open and closed on the left side (disc brake side) of the bike.  What could be the cause of this, is it a simple fix or a symptom of something larger?   I have not removed the front wheel yet, nor have I Ever removed it or worked on it, although the wheel seems to be true when I spin it.  When i was riding the bike there wasnt front brake drag that i could notice, so it must not be moving too much while riding, as it seems to mostly move when the handlebars are turned to their extreme (which really only happens for me when doing a U-turn or turning the bike around while parked).
The first image is of the disc brake side of the wheel with the gap open and the second two are shots of the disc brake side of the wheel with the gap closed.
Thank you very much ahead of time!
Andy
Re: 1975 CB750 Front Wheel Moving Side to Side about 1cm in Fork - Help!
« Reply #1 on: December 10, 2015, 06:55:58 AM »
Either missing spacers or your bearings are shot.
« Reply #2 on: December 10, 2015, 07:02:13 AM »
Sure, I will take some photos on my Lunch break from work!
In regards to the spacers - how do i identify the missing spacers / is that a part that i can easily find and put on myself or should i bring this to a shop?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: December 10, 2015, 07:10:05 AM »
Looks more like 1mm as opposed to 1cm.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: December 10, 2015, 07:10:12 AM »
Dont bring it to a shop!  I would remove the front wheel and then compare the parts you have to the parts fiche, here is the link...
http://www.westernhonda.com/fiche_select2.asp?category=Motorcycles&make=Honda&year=1975&fveh=132839
« Reply #5 on: December 10, 2015, 08:01:58 AM »
Thank you that site is very helpful!  I will remove the wheel this evening if i can get a jack to get my bike up.  How likely is it that the forks are too "wide", that seems unlikely, the bike is in really good condition overall and i dont think it has been in any major accidents with only 14,000 miles but i suppose anything is possible on a 40 year old machine
« Reply #6 on: December 10, 2015, 08:06:01 AM »
The best way to jack the front up is to use a piece of 2x4 on top of the jack against the frame  cross tube up front.
It does not need much, just few inches of the ground.
You may also be able to rotate fork tubes to eliminate the gap, I seen it before.
« Last Edit: December 10, 2015, 08:07:51 AM by 70CB750 »
Offline robvangulik
  • Honda Fourever
« Reply #7 on: December 10, 2015, 01:07:26 PM »
My thought exactly. No big problem, just loosen the bolts holding the front axle , screw the axle bolt tighter, jiggle the front wheel a bit, and see what happens when you tighten it up again.
« Last Edit: December 10, 2015, 01:10:45 PM by robvangulik »
« Reply #8 on: December 10, 2015, 01:11:18 PM »
Thank you!  I will jack it up tonight hopefully after work and take it apart and try these suggestions and report back.  Yes i meant 1 mm that was my fault.  Still getting used to the metric system  :)
Offline robvangulik
  • Honda Fourever
« Reply #9 on: December 10, 2015, 01:18:29 PM »
 ;D the difference is a factor 10, 1 mm can easily be corrected, 1 cm would be a bigger problem, I wouldn't ride with a front wheel shifting that distance ::)
Offline Powderman
« Reply #10 on: December 10, 2015, 03:14:02 PM »
1cm=10mm. No way I would ride with that kind of gap.
« Reply #11 on: December 10, 2015, 04:24:12 PM »
looks to me like the axle nut is not tight
Offline jonda500
« Reply #12 on: December 11, 2015, 08:51:56 PM »
Personally I wouldn't like to use such a long piece of wood balanced on a trolley jack - I use a small piece of wood under the oil filter housing to jack mine up - it doesn't take much force to rock it back on the centre stand till the rear wheel gently kisses the ground.
You can tighten that axle nut without jacking it up - loosen the two fork cap nuts just on that side and use an open ended spanner to tighten the axle nut. Then lightly tap the bottom of the fork in 1mm with a piece of wood and retighten the cap nuts.
The fork caps should both have the "F" mark at the front and the front nuts tightened first so that the gap's at the back.
John
A starter clutch thread:
