Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 205280 times)
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
Re: 1974 CB550. Monoshock. Engine Build. "BLAC"
« Reply #650 on: February 15, 2017, 11:53:54 AM »
Speculation at best in my book.
With the boring life I lead... and no fun life experiences.... that's all I got, buddy!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline GV1390
  • Express Gratitude.
« Reply #651 on: February 15, 2017, 12:02:09 PM »
More complicated, sure.  Unsafe, I dont think so.
I'm all too familiar with this.
-_-
08' Ducati S4RS, 71’ CB500, 71' CL350, 72' R90/6, 16' Ural Gear Up & 02' ZRX1200R.
Offline BLAC
  • An espresso is a
« Reply #652 on: February 15, 2017, 12:05:34 PM »
-_-
It's the new motto of my build haha
Expensive? Absolutely.
Easy? No.
Safe? Probably.
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline sinister902
    • Anger Street Kustoms
« Reply #653 on: February 15, 2017, 12:19:03 PM »
EDIT: It is very common to have a MC to a single rear disc setup on most bikes... is there a reason that I could not just take a rear MC and use it on the front of my bike?
depends on bore size of the master. needs to be able to move enough fluid for the caliper to be effective. Rear calipers are typically small single pistons.
« Reply #654 on: February 15, 2017, 12:19:50 PM »
-_-
Says the guy who rides like Indian Larry (standing on the seat)!
Oh to be in your 20's and indestructible!!
Offline GV1390
« Reply #655 on: February 15, 2017, 12:25:02 PM »
-_-
Next time keep scrolling past those pictures that were taken in 2015 if you don't like them.
 :D
« Reply #656 on: February 15, 2017, 12:27:31 PM »
-_-
Easy? No.
Safe? Probably.
Easy? No...if it was everyone would be doing it.
Look end last page at the red bike I added...mc and throttle in the bars..not easy.
Offline Ericcb750
« Reply #657 on: February 15, 2017, 12:36:30 PM »
Hey B, So you're leaving your cases bare? I know we're talking master Cyl's at the moment.
In My extremely "un-professional" opinion, I would think that as long as the mounting system is solid and the bore of the M/c is correct for a single caliper/disk , I would think it should work alright??
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
Offline BLAC
  • An espresso is a
« Reply #658 on: February 15, 2017, 12:48:13 PM »
Yes I'm leaving mine bare.  Everything has its downsides, paint chips and flakes and powdercoat can do the same over time.  I don't mind the look of aging metal and with the sprays and treatments to bring back the finish i am comfortable keeping it looking nice.
« Last Edit: February 15, 2017, 01:14:39 PM by BLAC »
« Reply #659 on: February 15, 2017, 02:24:34 PM »
Not to be a wet blanket, but powdercoat is extremely durable and stain resistant.  You will have to be vigilant to inspect your engine and clean up your mess if you have oil, gas or grease accumulate on it.  Once it cooks on, it is a more difficult stain to remove.  That said, if you are the meticulous type, you should be just fine.
Offline BLAC
  • An espresso is a
« Reply #660 on: February 15, 2017, 03:25:40 PM »
Very true, i just don't like the inability to repair nicks and scratches without redoing the whole piece.
« Reply #661 on: February 15, 2017, 03:31:40 PM »
Good powdercoating shouldn't "nick and scratch" unless you hit it with a hammer, must be some #$%*ty powdercoaters out your way.... :P
Offline BLAC
  • An espresso is a
« Reply #662 on: February 15, 2017, 03:35:41 PM »
rocks on the freeway can be a #$%*.  My family friend built a trailer, powder coated it, then a week after he finished it, the leading edge got chipped up after hitting a patch of loose gravel, got wet and the moisture spread under the powder coat.  He stripped it down to the metal then painted it.
Not saying that is all that common or going to happen on my bike, just saying that is one attribute of powder coat I don't love.
« Reply #663 on: February 15, 2017, 03:42:17 PM »
My trade is in industrial epoxies, done both electrostatic and lots powdercoating too, if powdercoating is done well it is the most durable coating of the lot, I'd say the prep wasn't that good if a small piece of gravel chipped the powder, it should take a much bigger hit than that.  Everyone knows someone with a "story".... ;D
« Reply #664 on: February 15, 2017, 03:52:21 PM »
In my experience, powdercoating has withstood rocks, gas, oil and environmental exposure better than paint.  I have not seen powdercoat chip unless you drop it against the ground, hit it with a hammer or other hardened implement -- but that's just me.  As Mick says, everyone has a story. . .
FYI - I painted my last engine with VHT paint because (then) beadblasting and powdercoating the cases was a pain in the butt to make sure all of the media was cleared out.
Offline BLAC
  • An espresso is a
« Reply #665 on: February 15, 2017, 03:58:20 PM »
I never said it wasnt resilient or I disliked powder coat  :P Im going to powdercoat my frame.  I just dislike how you cant repair damage without redoing it all.  As far as engine cases are concerned, I agree powder coat is perfect for that application (probably better than paint when considering the gas/oil it will contact), I just prefer the look of bare metal.
« Reply #666 on: February 15, 2017, 03:59:56 PM »
You can repair damaged powder without having to redo the whole thing, if you have the facilities and if you know what you are doing... 8)
« Reply #667 on: February 15, 2017, 04:07:48 PM »
Nuff said.  I think we whipped that dead horse plenty!  ;)  At least it wasn't an oil or forkbrace thread!  ;D
Offline BLAC
  • An espresso is a
« Reply #668 on: February 15, 2017, 04:09:27 PM »
Agreed!
p.s. what type of oil do you recommend for your forkbrace?   :P
« Reply #669 on: February 15, 2017, 04:11:32 PM »
Agreed!
Come on, guys!  It's all ball bearings these days!
Offline 540nova
« Reply #670 on: February 16, 2017, 03:20:03 AM »
After powdercoating my frame, I noticed a blemish that bothered me, where I didn't finish the grinding adequately. I had my painter blend it out, and painted that section in perfectly matching acrylic enamel paint. Powdercoated frames can be touched up.
Offline BLAC
  • An espresso is a
« Reply #671 on: February 16, 2017, 10:01:36 AM »
Offline 540nova
« Reply #672 on: February 16, 2017, 10:51:51 AM »
LOL, beating a dead horse. I get it.
« Reply #673 on: February 16, 2017, 11:11:10 AM »
Let the man build the bike the way he wants.. Not long ago 1/2 the bikes in the world ran bare cases and heads..
Offline BLAC
  • An espresso is a
« Reply #674 on: February 16, 2017, 12:09:41 PM »
Get up to speed, Frank. We are all having fun with each other  ::)
haha All in good fun!  and its not "beating the dead horse" its "beating the living bryan into submission"   :P
PS im off to Racetech with my frame!
