Author Topic: tips/tricks tearing oem seat  (Read 1947 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« on: November 14, 2016, 02:30:45 PM »
Those old seats tear themselves apart don't they?
Anyone have a new or tried and true trick to stopping this nonsense?
Re: tips/tricks tearing oem seat
« Reply #1 on: November 14, 2016, 02:46:26 PM »
Dont use them.
Get an used pan and slap on one of those Gumtwo seat covers.  Comfy!
  • Holy Cow! I'm a
« Reply #2 on: November 14, 2016, 02:48:45 PM »
Dont use them.
I know right?
I have a solo seat to install, eventually.  In the meantime though...
« Reply #3 on: November 14, 2016, 02:59:43 PM »
My red 550 came with the smallest 1" separation on a seam.  Nearly impossible to repair and have it look good.
Re-cover is the way to go...original covers get so stretched and brittle.  If you find a good OEM, store it away.
Offline MickB
« Reply #4 on: November 14, 2016, 02:59:51 PM »
Get a seat cover for only around $30 and replace the old one, it's not too difficult.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: November 14, 2016, 03:07:35 PM »
The old material gets so brittle I don't think it can be stopped. Gumtwo's covers look good and are easy to install:
New gator teeth upholstery strips riveted to the seat pan to hold the new seat cover:
New skin stretched into place:
All that work just for this:
I wrapped the foam with saran wrap and folded it under the edge of the pan prior to stretching the cover into place. Helps keep the cover from snagging the foam and helps keep the foam from absorbing any water that might get through the stitching. Looks very good without much effort.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Gene
  • Chat enuf you too can be a
« Reply #6 on: November 14, 2016, 04:27:21 PM »
Black duct tape will hold you for a while.  But, GumTwo's seat covers are great. You could try that vinyl repair stuff you can get at any auto-parts store - But I've found that doesn't hold.
*1973 CB750K3 (Bow)
  • Holy Cow! I'm a
« Reply #7 on: November 14, 2016, 04:39:27 PM »
You're right about the tape patch.  It certainly slowed the tearing, but as you can see....not permanently.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #8 on: November 15, 2016, 05:24:03 AM »
I used black tarp tape for awhile... but I have a replacement cover coming for christmas. ;D
--Evan
1975 CB750K "Rhonda"
Offline Ericcb750
« Reply #9 on: November 15, 2016, 11:48:07 AM »
That cover is Gorgeous!! I'm going to have to look into one of these....
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
« Reply #10 on: November 15, 2016, 12:21:20 PM »
Here's my 74 550s Gumtwo seat re-cover.
Easy to install. Stretch into place and clips.  Glue (upholsterers cement) under clips one by one working around, keeping the same tension.  Re-secure pan teeth and trip strip.
Easy peasy.
  • Holy Cow! I'm a
« Reply #11 on: November 15, 2016, 02:05:26 PM »
Do guntwo covers come in brown?
« Reply #12 on: November 15, 2016, 04:42:06 PM »
Here's one I did awhile back. Pretty basic really...
If you can reuse the OEM trim and strap as I did here, the results are much better. [I've yet to see a good re-pop strap]
Offline Gene
« Reply #13 on: November 15, 2016, 04:58:21 PM »
+1 original strap if you can make it work.
*1973 CB750K3 (Bow)
