Author Topic: "Fried Intake Valves" 1976 CB550  (Read 6362 times)
Offline Can550
« on: March 22, 2017, 08:42:41 PM »
Hi,
Very new to this forum and CBs. Would like to know when someone says "intake valves are cooked" what does it mean in terms of difficulty level to repair/ fix this problem?
Thanks,
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: "Fried Intake Valves" 1976 CB550
« Reply #1 on: March 22, 2017, 09:13:48 PM »
The valve stem seal may have burned out and is leaking oil from the top into the combustion chamber.
Or the valve itself is damaged in its seat.
Either way, gonna need a top end rebuild, with special attention to the valves.
Offline Can550
« Reply #2 on: March 22, 2017, 09:30:00 PM »
Many thanks for replying Bomberman.
« Reply #3 on: March 22, 2017, 10:00:17 PM »
Hi,
Thanks,
Why did someone tell you the intake valves are cooked?? Exhaust valves are more likely to be burned than intakes. I wouldn't put any faith in such an off-hand diagnosis.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: March 23, 2017, 04:10:25 AM »
Hi,
Thanks,
+1
How do you even diagnose intake valve condition without disassembly and a visual inspection?
What problems are you having?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline b52bombardier1
« Reply #5 on: March 23, 2017, 04:46:13 AM »
Have you checked your engine for compression?  Does it smoke?
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline Can550
« Reply #6 on: March 23, 2017, 04:05:28 PM »
Thanks everyone
I don't have bike as yet. This question was asked as I got it from someone.
Offline Can550
« Reply #7 on: March 23, 2017, 04:07:43 PM »
As stated by the owner, "valve adjustment/ service was overdue and I rode bike past 500 miles, towards the end of ride bike made high pitch noise/ sound, engine lost power and stopped".
Bike has been garaged since then (which was probably over two decades ago).
  • Holy Cow! I'm a
« Reply #8 on: March 23, 2017, 04:22:50 PM »
That might have been the sound of it sinking a valve into the head.
« Reply #9 on: March 23, 2017, 07:15:54 PM »
" towards the end of ride bike made high pitch noise/ sound, engine lost power and stopped".
The high pitch sound may have been the camshaft seizing in it's bearings from a lack of oil. If this is the case, the cylinder head, the camshaft, and the cam cover may need to be replaced.
Offline Can550
« Reply #10 on: March 23, 2017, 07:43:56 PM »
Thanks
So now after many years of storage, is it ok to attempt starting it since engine rolls with kickstart?
« Reply #11 on: March 23, 2017, 07:52:41 PM »
If the engine turns freely with the kickstart, then, yes, I would attempt to start it. You may want to put a small amount of oil into the spark plug holes first, due to the long slumber. Once you get it started, make sure oil is getting pumped up to the camshaft, looking through the tappet cover openings. The previous owner's recollection of what happened so long ago is suspect.
Offline Can550
« Reply #12 on: March 23, 2017, 08:27:00 PM »
Many thanks Scottly
An attempt to start shall be made soon and I shall update accordingly.
« Reply #13 on: March 24, 2017, 04:56:57 AM »
 At least change the oil and filter if not done already first and look for metal and a peek at the spark plugs may show some clues also if broken metal from a valve or something is in a chamber. The old oil pan drop tells a lot also. If a cam bearing is already toast starting it again won't kill it much more.
Offline DaveBarbier
« Reply #14 on: March 24, 2017, 05:15:51 AM »
Might want to pour some oil in the tappet covers to be sure there's lubrication for the cam on initial startup.
« Reply #15 on: March 24, 2017, 08:57:10 AM »
These ^^^
A $14 USB borescope comes in real handy here  ;)
If you get the bike, it better be cheap. Like well under $500 cheap, as you could be in for a time and money consuming rebuild.
Offline Can550
« Reply #16 on: March 24, 2017, 09:18:46 AM »
Damn
It's much more than that
« Reply #17 on: March 24, 2017, 09:24:27 AM »
How much more....and does it have a title?
  • Holy Cow! I'm a
« Reply #18 on: March 24, 2017, 09:26:13 AM »
Damn
Did the advert have words like;
Café
Rare
Custom
Collectible
Antique
Vintage
Those are the four words people use to sell their broke down CB's at "there's a sucker" prices.
« Reply #19 on: March 24, 2017, 09:30:48 AM »
Summer is coming, and riding season for us in N America.
If you want to ride...this may not be the bike for you.  Maybe you want to have a project bike for the summer?  I dunno.... :-\
Give us more details on what your in for, and show us the bike youre looking at.
No one will snake it out from under you.  We're not like that in here.
In my area.  Just for comparison.  Short work would make this a rider.
https://seattle.craigslist.org/kit/mcy/6053891983.html
« Last Edit: March 24, 2017, 09:33:28 AM by flybox1 »
Offline Can550
« Reply #20 on: March 24, 2017, 09:51:19 AM »
Hi flybox
My reason to buy this bike was just some good old memories from childhood.
No there were no such words in the ad.
I'm not looking at this bike for riding this summer. I have a road King for my riding.
I'm not worried about anyone taking away this bike. Not only because I have already bought it (awaiting transportation) but also that you all are bunch of good helping guys out here.
I did post a brief of this bike but by mistake posted under new member introduction. Will cut and paste here or rewrite later in the evening.
Your response and input is highly appreciated
Cheers
Offline DaveBarbier
« Reply #21 on: March 24, 2017, 09:54:19 AM »
Damn
1: Café
2: Rare
3: Custom
3 1/2: Collectible
3 3/4: Antique
4: Vintage
I thought there were six words there but after labeling them I see that you're right, my bad :))
« Reply #22 on: March 24, 2017, 09:59:09 AM »
Can....i checked out the post.  No side view of the bike or closeups of what youre potentially working with make it tough to suggest anything other than what Calj mentioned....3000mi maintenance items first....and then try n start it.
Once you get it, start a thread over on the Project shop pages....post lots of pictures so your questions can be answered in one place, and your progress followed.
Cheers.
  • Holy Cow! I'm a
« Reply #23 on: March 24, 2017, 10:41:01 AM »
Damn
1: Café
2: Rare
3: Custom
3 1/2: Collectible
3 3/4: Antique
4: Vintage
Lol oops  ::)
Offline Can550
« Reply #24 on: March 24, 2017, 12:04:02 PM »
Lol
My comment of "much more" is referred to your suggested price of well below 500$ and not the key words/ luring words of seller
