Author Topic: Engine cranks but bike won't fire  (Read 5263 times)
Offline aminemed
« on: January 28, 2018, 05:24:10 AM »
Bike is a 750 k2, fired yesterday with some lag while running and then engine stopped after a few minutes, I couldnt restart it and depleted my battery. Tried again and depleted battery three times in total.
Battery is almost new, above 13 voltA
Changed 2 plugs to new ones as I had spare plugs at home (cylinder 1 and 4)
Fuel is ok (tank derusted)
My plugs are black with gasoline on them
Bike would fire for a few seconds then engine dies
Was running great until this time and firing right away
Can't understand what is going on!
Any tips would be welcome
Re: Engine cranks but bike won't fire
« Reply #1 on: January 28, 2018, 05:36:45 AM »
so I guess this is your first fire up?or was it running when parked last?
Offline Deltarider
« Reply #2 on: January 28, 2018, 05:51:04 AM »
1. Is killswitch in 'Run'?
2. What did you last have your hands on?
3. Is there still a solid plugcap - wire connection?
4. Connect spare sparkplug to plugcap, lie it against the head to check for spark whilst cranking.
5. Is breakerpoints gap still within spec?
« Last Edit: January 28, 2018, 05:53:30 AM by Deltarider »
CB500K2-ED Excel black
Offline aminemed
« Reply #3 on: January 28, 2018, 05:53:26 AM »
No bike was firing last time was last Sunday took it for a ride and it fired and for a few minutes before it died yesterday
Offline aminemed
« Reply #4 on: January 28, 2018, 05:58:04 AM »
And all sparkplug caps are brand new NGK!
Offline aminemed
« Reply #5 on: January 28, 2018, 06:29:01 AM »
Plugs are 2 months old, I changed cylinder 1 and 4 I assume it should fire on 2 cylinders anyways ? No ?
Offline robvangulik
  • Honda Fourever
« Reply #6 on: January 28, 2018, 06:51:18 AM »
With your carbs its so easy to take off the floatbowls to see if there are jets lying loose in there or if anything else is wrong with fuel supply, i'd start there if i were you.
Offline setdog
« Reply #7 on: January 28, 2018, 06:58:04 AM »
the holy trinity, fuel air spark
you got fuel
you got air
you got spark
"black/gassed plugs", id pull the carbs and do a carb sync
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline Keith
« Reply #8 on: January 28, 2018, 07:04:39 AM »
The engine needs 3 things to run....spark, fuel, compression. Those are the basics, start there. Plugs are black, so you are getting at least some fuel. Do you have spark? Pull a plug wire, put a plug in the cap, and hold the electrode against the engine. Spark? Check points...dwell meter is the best method. No Compression? Valves too tight? Catasprophic engine failure? If you have spark and compression, spray combustible fluid in carbs....should fire, showing a fuel problem. Educate yourself...a good mechanic can pinpoint a problem like this in a few minutes.
Offline aminemed
« Reply #9 on: January 28, 2018, 07:13:56 AM »
K checked plugs resistance so changed also a 3rd plug that was at 3.9 Kohms, so got basically 3 good plugs bike started right away and I run it around the block, engine died again after 3 min so had to push it. Did not start again. I guess this rules out any fuel related issue. But don't understand this plug issue !
« Last Edit: January 28, 2018, 07:26:22 AM by aminemed »
Offline setdog
« Reply #10 on: January 28, 2018, 07:36:56 AM »
Completely wrong. It points to a fuel issue as a major possibility. Pull the plugs you just changed and inspect them. Either do the proper tuning or settle in for protracted and persistent issues.
+1 do the proper tuning,
take a step back, you know the bike runs.  i would grab manual and go through the periodical maintenance, and visit valves, timing and carburetors (or is it timing, valves, carbs?).  it may be time consuming but its worth it.  seems to me the bike is begging for a tune up.
i have do timing on my bike too now that i think about it
« Last Edit: January 28, 2018, 07:41:21 AM by setdog »
76 CB 200T. (sold)
Offline aminemed
« Reply #11 on: January 28, 2018, 07:49:59 AM »
What is then first step I should do ?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #12 on: January 28, 2018, 07:59:41 AM »
+2
Your recent thread about leaky carbs that mysteriously fixed themselves means that every possibility is on the table.
http://forums.sohc4.net/index.php/topic,169826.msg1971094.html#msg1971094
Properly functioning carbs don't leak, ever, so rule out everything else by verifying point gap, timing, proper spark, nice new clean air filter and spark plugs, properly vented fuel cap, cam chain tension, and anything else I might be missing from the 3000 to 10,000 mile tune-up. Get at least four extra sets of spark plugs since you're already fouling plugs you'll likely be fouling several more before you get it sorted.
I hate working on carbs so I try to rule out everything else first. Hell, at one point I went so far as to do an engine swap to avoid rebuilding the carbs, but the replacement engine (with the same carbs) had the same poor running issues as the original motor! So I ultimately rebuilt the carbs. I would not go to such an extreme today, and I have gotten pretty good at cleaning and adjusting these multiple carb assemblies, but I still don't like it...  :P
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline setdog
« Reply #13 on: January 28, 2018, 08:01:17 AM »
download the manual
i think you can google cb750 k0 k7 shop manual
last time i looked dotheton had a good link
find the periodical maintenance section
76 CB 200T. (sold)
Offline strynboen
« Reply #14 on: January 28, 2018, 08:06:29 AM »
have you first drowned the plugs..they often shorts aut..just of the fuel and some sooth blends up...take a gas burner and heat them up..so they dryes good up...and then rotate the engine to blov all fuel aut...and then put the still hot plugs inn..and try to start..use no choker and open trottel..to get as mutch air in the engine.to help the mix to lean a bit up...
i hate all this v-w.... vords
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
« Reply #15 on: January 28, 2018, 08:08:43 AM »
Black spark plugs, especially wet ones point to a very rich fuel setting.
You’ll need to freshen up your sooty spark plugs before you try anything new. Wear your proper protection (goggles, gloves etc).  Pull all your foul plugs. Grip each plug with some pliers and torch the electrode tip until it becomes about red hot. Let that rest until they cool down to touch.
After you have some clean plugs, make friends with this link:
http://forums.sohc4.net/index.php?topic=5410.0
Offline aminemed
« Reply #16 on: January 28, 2018, 09:07:35 AM »
Hank you for your help I will try that after solving a much bigger iasue: my spark plugs is stuck in cylinder 2..it fell inside..can't pull it from there
Offline minimo
« Reply #17 on: January 28, 2018, 09:09:09 AM »
Can it be pulled out with a telescoping magnet? Needle nose pliers? Chopsticks?
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #18 on: January 28, 2018, 09:38:16 AM »
how did the spark plug fall inside?
cb750 k6 - ugly
Offline aminemed
« Reply #19 on: January 28, 2018, 09:41:22 AM »
That is a very good question, now it is lying horizontally..
Offline minimo
« Reply #20 on: January 28, 2018, 10:17:50 AM »
Be careful not to force the spark plug too hard on its way out; you might bend the electrode. Be sure to check the gap before reinstall.
It’s helpful to provide photos here too whilst describing issues. Gives us a better sense of what we’re trying to mentally picture.
« Last Edit: January 28, 2018, 12:29:56 PM by minimo »
« Reply #21 on: January 28, 2018, 12:12:22 PM »
Now it is lying horizontally..
Holy cow, I didn't even think that was possible. Take your time, try to shift it around a little bit, both side to side and front to back until it is lying loosely. Maybe use a thin probe between the fins to get it standing up, just don't force anything. A small inspection mirror and a small telescoping magnet might help.
TAMTF...
Wilbur
Projects:
Offline setdog
« Reply #22 on: January 28, 2018, 12:49:13 PM »
i want to know too.  this seems impossible unless is broke apart
76 CB 200T. (sold)
Offline strynboen
« Reply #23 on: January 28, 2018, 12:51:48 PM »
is it the senter elektrode and keramic islator vho is falled in the engine??..the threddet part is komming nice aut???
this happend if you use a vrong Tool ..the orginal Honda plug Tool is thin valled..and do no pressure on the plug.. remove the tank helps too..
« Last Edit: January 28, 2018, 12:54:28 PM by strynboen »
Offline jgger
« Reply #24 on: January 28, 2018, 02:51:10 PM »
OK, me too, me too. I'm having trouble picturing this in my mind, I think we ALL need to see a photo.
