Author Topic: New regulator/rectifier not charging  (Read 12803 times)
Offline rupaulpierce
Re: New regulator/rectifier not charging
« Reply #50 on: May 29, 2018, 05:32:09 PM »
Just checked before pulling sprocket cover... Jumps up to 35V AC around 4K rpm.
The AC voltage can't build if there is too much electrical load, particularly at idle.  What mods have you made to increase power loading for the bike?
None, other than it being a CB400F engine in a CB350F frame.
« Reply #51 on: May 29, 2018, 05:41:26 PM »
So, you don't have a brighter headlight or ignition "upgrade"?
I worked on a 400 once that had the headlight rewired to have both beam elements on with the high beam selection.  Yes, it struggled to keep the battery charged.
You might try switching the lighting off at idle while measuring the AC output.
Ac output needs to be double the battery voltage to drive current to the battery.  Only half is applied to each diode for Rectification.  The resulting DC voltage must be higher than the battery voltage for any restorative effect.
« Reply #52 on: May 29, 2018, 05:47:20 PM »
Nothing like that. These measurements were taken with the lights off.
« Reply #53 on: May 29, 2018, 05:52:01 PM »
My language may have been misleading. It “builds” to 35V AC at 4K rpm, no “jump”.
« Reply #54 on: May 29, 2018, 08:01:09 PM »
Sounds like you have an intermittent problem going on. With the white harness wire disconnected from the reg, measure the resistance between the wire and the negative battery terminal (the field coil resistance). Use jumpers with alligator clips so your hands are free. Do a "wiggle" test on the wires under the cover, and see if the reading jumps around.
« Reply #55 on: May 29, 2018, 08:36:36 PM »
4.7-4.8 ohms with the wiggle.
Offline Bodi
« Reply #56 on: May 30, 2018, 04:32:46 AM »
Something is weird, you should not have 30v anywhere. Stator wire voltage to ground is not a very useful measurement though. For this 3 phase system each wire pair works together, when one wire is positive to another there is a diode pair to let the power flow. With a low impedance battery, the voltages measured between yellows can not be much higher than the battery voltage, maybe 2V allowing for the diode drops and wiring. Measuring voltage between them, connected to the rectifier and battery with engine running, can diagnose diode failures. Measuring with them disconnected does not tell you much.
« Reply #57 on: May 30, 2018, 06:25:30 AM »
Something is weird
Most definitely.
AC voltage between yellows. Everything connected, stock components, engine idling.
A-B: 14-15
A-C: 14-15
B-C: 14-15
Offline Bodi
« Reply #58 on: May 30, 2018, 06:32:14 AM »
Do you have a meter that will measure DC Amps? 10A max is sufficient, many digital meters will do this. I believe your bike has two wires to the battery + terminal, fat one for the starter and a smaller wire for everything else. If you measure the amps between the smaller wire and the battery terminal, you can see the charging/discharging current. You should have an amp or two charging with the engine at ~4000 RPM if the battery is not fully charged. Do not try to measure the starter current unless you have a meter good for ~100A.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #59 on: May 30, 2018, 08:13:59 AM »
Your AC voltages look good per the manual.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #60 on: May 30, 2018, 09:02:21 AM »
So why am I not seeing charging voltage measured across the batt terminals?
Offline Bodi
« Reply #61 on: May 30, 2018, 09:23:04 AM »
Charging is amps, the voltage depends on the system load vs alternator output power... and battery condition. The alternator does not have a lot of excess power over what the ignition and lighting need, and at low RPM the battery makes up what it can't supply - alternator may be 100% good but the battery will discharge by holding system voltage as high as it can. At higher RPM the alternator should have enough wattage to power the bike and have a bit left over to charge the battery, but the battery condition and charge state will control the voltage. If you measure the current in or out of the battery you will see this, it "should" send an amp or two back to the battery until that battery is fully charged: its voltage would be 14.5V or so for a fully charged wet cell battery with correct acid SG. The regulator will reduce alternator output to match the system load then, so the battery should have no current in or out if all is well and it's over 4000 RPM..
« Reply #62 on: May 30, 2018, 09:51:51 AM »
I would be looking at connections, both ground connections to the frame as well as harness connections. Stator connections tend to be the highest amperage connections and suffer the most. Here is an example of some of the ones I've seen:
TAMTF...
Wilbur
Projects:
« Reply #63 on: May 31, 2018, 04:28:46 AM »
Thanks Bodi. I've seen the below test laid out several times, somewhere else by scottly I think. When jumping the white wire I'm not getting anywhere near 15V, so I don't think this is about the regulator limiting output. I'll check the amps though to be sure.
H - Assuming D, E, F, and G have not found faults. We can verify all the of the charging system minus the regulator is functioning correctly, by using a temporary jumper to connect the disconnected white wire (normally attached to the REGULATOR) and connecting the White directly to the the battery POS terminal.  Repeat the B and C tests.  However, if at any time the battery voltage rises above 15V, stop the test.  Such an indication would prove the charging system capable of maintaining a known good battery.  If this test never achieves 15V, then there is a wire/connector issue in either the ground path leading back to the battery NEG terminal, a wiring/ connector issue withe the rectifier RED path to the battery POS terminal, or you made a mistake in D through G.
Seems like madmtnmotors must be right about a bad connection somewhere. How much resistance is acceptable in the ground paths... for example, the green reg wire in the harness to the neg battery strap?
« Reply #64 on: May 31, 2018, 04:31:43 AM »
I previously cleaned the stator plug and hit each connection with dielectric grease. Maybe I've got a bad ground somewhere.
« Reply #65 on: May 31, 2018, 05:08:28 AM »
Electrical troubleshooting can be maddening. Many times it's a process of elimination figuring out what it's not…  ;)
TAMTF...
Wilbur
Projects:
Offline BRG-BIRD
« Reply #66 on: May 31, 2018, 07:20:21 PM »
Check your grounds. That was the fix for the charging issue on the 75CB550F, the green ground wire under the fuel tank was not tight.
“You are either on something or onto something.” The Comman Man
« Reply #67 on: June 02, 2018, 08:59:48 AM »
How much resistance is acceptable in the ground connections?
I'm seeing .3-.4 ohms at the stator, rectifier, and regulator connections.
« Reply #68 on: June 02, 2018, 09:16:18 AM »
Would testing amps between the fused loop in the small red wire and the batt neg terminal work?
« Reply #69 on: June 02, 2018, 10:16:37 AM »
Seemed like I was making power but it wasn’t getting anywhere, so I started checking resistances in the + wires. Bingo!
« Reply #70 on: June 02, 2018, 11:52:57 AM »
I love it when a plan comes together.  8)
I hope the single crimp connector is temporary? The double crimp connectors go a long way towards keeping future problems at bay.
TAMTF...
Wilbur
Projects:
« Reply #71 on: June 02, 2018, 12:06:00 PM »
Yes temp solution. Would like to repair the oem connector, but it would probably be easier to just run the wire outside the plug as it is now.
« Reply #72 on: June 02, 2018, 06:13:35 PM »
Yes, you can repair the connection with higher quality “double crimp” connectors and either use the original connector block or bypass the connector block with the connector of your choice. As long as you use quality connectors both methods will work reliably.
TAMTF...
Wilbur
Projects:
« Reply #73 on: June 03, 2018, 05:11:38 AM »
YUGE thank you to everyone who helped me troubleshoot this.
« Reply #74 on: June 03, 2018, 01:06:20 PM »
OK... not so fast. After doing some putting around today it appears that I'm back to the original problem, pulsing way above 15V. I think that's within the range of the stock regulator (and as someone mentioned, it can be adjusted). The chinese one was putting out over 17V. Is there anything OTHER than a garbage regulator that could be causing this?
