Author Topic: Carb cleaning experimentation  (Read 1447 times)
Offline Derby City
« on: August 06, 2018, 05:00:14 PM »
Has anyone here tried submersing their carbs in Evapo-rust to aid in the cleaning?  I have 3.5 gallons of Evapo-rust and a set of dirty carbs that have been sitting for 7+ years.  Hoping one of you have already tried this and would be willing to share your results.
Thank you!
1974 CB 550
Re: Carb cleaning experimentation
« Reply #1 on: August 06, 2018, 05:03:26 PM »
 I would not do it personally but maybe somebody else has. I would be worried about a bad chemical reaction with the pot metal they use on those. There is this stuff in a big metal can called carburetor cleaner that seems to work real well  :D
Offline Derby City
« Reply #2 on: August 06, 2018, 05:05:51 PM »
Tried and tested carb cleaner????  Where's your sense of adventure ;D
1974 CB 550
Offline eigenvector
« Reply #3 on: August 06, 2018, 05:09:45 PM »
Not really necessary to experiment.
30 minutes in a heated ultrasonic cleaner will get them as clean as they're gonna get.
Just finished a spare set for my 550K.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: August 06, 2018, 06:46:04 PM »
Evapo-Rust will remove any rust on the plated pieces, but won't do diddly for the varnished gas or other gunk in the passages. Net-net, probably a waste of time from a "cleaning perspective". Ultrasonic cleaning is by far the best "no touch" method.
+1
Results with ultrasonic cleaner with simple green:
Before (yuck):
After (suhweet):
30 minutes max with simple green. After that the parts start to darken.  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #5 on: August 06, 2018, 07:02:26 PM »
or use gunk carb cleaner, done in 5 minutes, no darkening...
« Reply #6 on: August 07, 2018, 03:07:49 AM »
2 minutes with high pressure cleaner.
Offline Derby City
« Reply #8 on: August 07, 2018, 03:59:23 PM »
Thanks for all the suggestions!  I'm going to use carb cleaner.
1974 CB 550
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #9 on: August 08, 2018, 07:39:52 AM »
Brilliant!
--Evan
1975 CB750K "Rhonda"
