Support the site. Your contributions keep this site running.
on the 750, the cam towers have studs and bolts, is there any reason not to run all studs? bolts can pull the threads so studs are usually better
You can run all studs, but all studs makes cam install a little tougher. Not impossible, just less room for fanagalin'...
Quote from: fireman1073 on March 14, 2019, 07:15:00 AMon the 750, the cam towers have studs and bolts, is there any reason not to run all studs? bolts can pull the threads so studs are usually betterQuote from: madmtnmotors on March 14, 2019, 07:25:47 AMYou can run all studs, but all studs makes cam install a little tougher. Not impossible, just less room for fanagalin'...ALL STUDS? Be tough!Maybe, but you will have to assemble and disassemble it all as a set, with the rockers and cam "installed" on account of the 4 bolts that go through the rocker shafts.Plus one on what Wilbur said if you mean just the 8 camshaft cap bolts.
