Author Topic: 1977 750K rear rim  (Read 1045 times)
Offline 3457fl
1977 750K rear rim
« on: April 06, 2021, 07:13:14 AM »
Anybody have a lead on where I can find a new 17" rear chrome rim for a 77-750K? Seem to have trouble locating one.
Offline goodtryer
Re: 1977 750K rear rim
« Reply #1 on: April 06, 2021, 07:59:27 AM »
Man... not easy to find. Had to look at a few places and had to look at different bikes it fits on. Not cheap either!
But found one advertised for a 1981 CB650:  https://www.ebay.com/itm/1981-81-HONDA-CB650-REAR-WHEEL-17-INCHES/264669587228?hash=item3d9f89671c:g:Ge4AAOSwoJ5eb7V3
Good luck!
EDIT: Ignore that listing! Just saw that it's "not straight"! But hopefully you can use the info to find a better alternative.
« Last Edit: April 06, 2021, 08:02:52 AM by goodtryer »
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline 3457fl
« Reply #2 on: April 06, 2021, 09:17:47 AM »
Yea, found a few used ones but really looking for new if possible.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: April 06, 2021, 01:40:42 PM »
As an aside, you can use a new 18”, but you will need the spokes and tire to match!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: April 07, 2021, 07:27:15 AM »
Polished aluminum might pass for chrome?
http://www.buchananspokes.com/products/excel_dimpled_aluminum_rims.asp
Or get a 19" aluminum front rim to match! 8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline flybackwards
« Reply #5 on: April 08, 2021, 04:55:11 PM »
I just went through this process with my 77 restoration, front chrome rims are pretty easy to find but the rear was impossible - I looked everywhere - if you can find a structurally sound used item there are places which will restore/re-chrome but it will be very expensive and time consuming. I ended up ordering a new correct size 2.5 X 17" DID alloy rim from Buchanan's - they will polish the anodizing off so its silver but it might be hard keeping it that way - I kept the anodizing and used stainless spokes and nipples - it looks quite good and you don't see very much of the back wheel with all those mufflers in the way.
« Reply #6 on: April 08, 2021, 06:03:41 PM »
Look for an auto 750 rim, its aluminum.. i think  early Goldwing had it too
« Last Edit: April 08, 2021, 06:09:58 PM by 754 »
Offline 3457fl
« Reply #7 on: April 17, 2021, 07:56:30 AM »
So I found a nice early Goidwing 17": x 2.50 rim, would the stock 77 rear spokes work with it?
Offline Alan F.
« Reply #8 on: April 17, 2021, 08:46:43 AM »
They might, but 750A and GL1000 used special domed washers between the spoke nipples and rim. I bought the kit from:
https://www.ebay.com/itm/Honda-CB750A-1976-77-Hondamatic-Full-Rear-Wheel-Spoke-Set/292270931377?hash=item440cb47db1:g:aEEAAOSw905Zypt4
« Reply #9 on: April 17, 2021, 08:55:39 AM »
Its a suck it and see as the goldwing hub was a lot bigger the spoke angles may be different as well
Offline Alan F.
« Reply #10 on: April 17, 2021, 09:15:38 AM »
Good point there, but nope it's the same rim for both bikes: https://www.cmsnl.com/honda-cb750a-750-hondamatic-1977-usa_model488/rim-rear-wheel_42701371003/
Offline 3457fl
« Reply #11 on: April 17, 2021, 10:13:37 AM »
Thanks for to spoke link, I also just found a very nice Honamatic rim also.
Offline 3457fl
« Reply #12 on: April 17, 2021, 02:03:31 PM »
Went with the Hondamatic rim and spokes, can't believe how hard it was to find a replacement rim for this project.
