Author Topic: 4 into 1 headers  (Read 1592 times)
Offline pjandrew99
4 into 1 headers
« on: January 20, 2022, 02:56:22 AM »
Please help me identify these headers. I bought them online for my K1. After a quick look, it doesn't seem like they would fit.
Thanks
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Re: 4 into 1 headers
« Reply #1 on: January 20, 2022, 03:10:39 AM »
They might if you remove the exhaust spigots and fit studs plus get the finned collars and split collets from an F1 or later
« Reply #2 on: January 20, 2022, 03:50:04 AM »
Buy a new low priced Delkevic 4-1.
Offline WhyNot2
  • I'm finally an
« Reply #3 on: January 20, 2022, 03:57:48 AM »
^^^^^^^^^What PeWe said^^^^^^^^^^^.......i just bought a set for my 750.
Also have the same system on my CB350F......
Offline newday777
« Reply #4 on: January 20, 2022, 04:01:57 AM »
Thanks
1975/76 CB750F Super Sport headers
Stu
My current rides
Prior bikes....
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: January 20, 2022, 04:59:30 AM »
They definitely look like CB750F model headers. They will probably bolt up, but I believe the F models use a different rear brake pedal to clear the pipe. The K model brake pedal may interfere with the pipe.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #7 on: January 20, 2022, 06:00:28 AM »
Thanks
Nope, not 75/76 750F
Offline pjandrew99
« Reply #8 on: January 20, 2022, 06:39:28 AM »
Thanks guys! Looks similar to the 77/78 cb750f. Will they bolt up to the K1 using the studs and clamps? If it interferes with the brake pedal that could be a deal breaker.
I think Delkevic is a great header. Trying to save a few bucks which usually cost me more. lol
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
« Reply #9 on: January 20, 2022, 07:59:28 AM »
Header is worthless if you don't have the correct split collars and finned clamps and studs in the head. Would need to round up that stuff for starters if not included. Not sure on the fit, may depend on the muffler which you would need also. Best bet would be to find a cheap header that slips over your stock spigots if you still have them and secures with the stock clamps. K models 70-76.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #10 on: January 20, 2022, 09:49:56 AM »
Is it just me or does the one pipe seem a little bent out of alignment.  Photo angle visual trickery?
Delkevic uses some nice materials.  Though their tube sizes and claims are suspect.
Popular here so at least they get cb systems right.
« Reply #11 on: January 20, 2022, 10:21:05 AM »
  If the collector outlet is 2 1/2" it's f0 or f1, if it's closer to 2" it's F2,3 which does not hit the brake pivot, in my experience F0,1 does hit the brake pivot.
  That collector looks like f2 to me. that's a 4-2-1 design and gives good ground clearance.
Offline pjandrew99
« Reply #12 on: January 20, 2022, 11:25:46 AM »
  I believe you are correct. One pipe is out of alignment. Hopefully I can bend it back.
Yes its a 2 inch collector. Finally some good news! lol
I read somewhere that some guys intentionally buy the Delkevic F pipes for the K because they prefer the way its bolts on to the motor. If that is true and I can bend the one pipe back into place it may be worth keeping...?????? All in all its in pretty decent shape.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
« Reply #13 on: January 20, 2022, 12:01:51 PM »
I  accidentially ordered K7 4-1 to my K6 end of 1979. My bike is registered as a 1977 so that was the order back then.
I had to find  the later fittings to head and make brackets for passenger foot pegs. Looked OK.
The much newer Hindle 4-2-1 ordered 2017-18 has similar angle by design fitted into the stock frame hole.  Hindle has its own spigots to bolt into the head. Only stock gaskets needed.
It got frame mounted passenger foot pegs.
« Last Edit: January 20, 2022, 12:07:47 PM by PeWe »
  • Holy Cow! I'm a
« Reply #14 on: January 20, 2022, 01:37:16 PM »
Repairing that header might be a bit difficult.
Not that it can't be done.  Just has to sit properly on the head to seal.
Offline pjandrew99
« Reply #15 on: January 20, 2022, 02:40:12 PM »
That looks great!
That's what I'm afraid of. Mostly likely will give a shot.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline Tracksnblades1
« Reply #16 on: January 20, 2022, 02:51:54 PM »
+1
« Last Edit: January 20, 2022, 02:53:43 PM by Tracksnblades1 »
Age Quod Agis
« Reply #17 on: January 20, 2022, 04:38:29 PM »
It could be that the #1 pipe rotated at the clamp to the collector. The #1 and #3 pipe clamp to the collector so I would loosen both of those when test fitting to the head.
TAMTF...
Wilbur
Projects:
  • Holy Cow! I'm a
« Reply #18 on: January 21, 2022, 12:16:53 AM »
Oh cool!  Had to squint to see the clamps on my tiny pocket screen.
So uh, yeah.  Nevermind.  I'll be off to the optometrist now.
« Last Edit: January 22, 2022, 11:47:18 PM by BomberMann650 »
Offline pjandrew99
« Reply #19 on: January 21, 2022, 01:56:04 AM »
I'm hoping that will do it. To me its looks like #2 is the issue and that has no clamp. I guess I really won't know until I start installing it. I'll be sure to loosen both clamps first.  Thanks
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
