Author Topic: C-Hook Engine Removal & Rotisserie Engine Stand  (Read 93185 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: C-Hook Engine Removal & Rotisserie Engine Stand
« Reply #100 on: May 17, 2015, 05:47:20 PM »
How long did it take to pull?
I can start with a fully assembled, running motorcycle, and have the engine on the stand in about an hour and a half.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline RandyBMC
« Reply #101 on: May 19, 2015, 04:44:32 PM »
Here's what I came up with.  It worked great.  Glad to have this forum!
Hope that helps!
Randy
« Reply #102 on: May 19, 2015, 06:18:10 PM »
Nice!
TAMTF...
Wilbur
Projects:
Offline oldskullero
« Reply #103 on: April 12, 2016, 03:36:54 PM »
Nice one. Ill make sure to get this on my to do list
Sent from my SM-N9005 using Tapatalk
Offline kixbox
« Reply #104 on: June 18, 2018, 08:31:56 AM »
Thank you for an amazing how-to post.
This is a shot in the dark but thought I'd ask anyway.  I am wondering if this was produced for forum members as I would not mind buying the hook? Will make life much easier than trying to find a shop to do it for me.
Offline Sketchy Bikes
    • Sketchy Bikes Home Page
« Reply #105 on: March 07, 2024, 05:44:23 PM »
If anyone is interested I finally used a C-hook and made a YouTube video of pulling my motor with it.  Worked pretty good!  Needed different straps for install.  I have some ideas to use a ratchet strap, or bike tie down strap.
Let me know what you all think!
From Rusted and Busted to Custom!!!
Offline gearsoup
  • Maine, USA
« Reply #106 on: March 10, 2024, 10:04:49 AM »
If anyone is interested I finally used a C-hook...
Thanks, that finally sparked my motivation and I modeled one up in Fusion. If my Static Stress Simulation is correct, we should be able to use 38" thick steel and have (at most) about 1.5mm of deflection out at the end (this was also with a load of 350 pounds). I'll check in with some Simulation folks that I know and double check my values tomorrow, and then it's off to some plasma shops to get a price on 1, 5 and 10
Current Project: CB750-K6 (hoping for OEM look)
Future Project: CB750-K8  (likely go wild on this build)
Offline willbird
« Reply #107 on: March 15, 2024, 06:40:47 PM »
I scrounged up some 1.5" square tubing to make one from. Making the design so that it nests will save money for sure. Unless the shop is able to cut them out of material that would just be scrap anyway.
« Reply #108 on: March 16, 2024, 10:37:43 AM »
Cool glad I could inspire ya!!   My static load test was...  "I hope this holds!!".  Lol!  Worked good.
« Reply #109 on: March 23, 2025, 09:17:00 PM »
  Here's my version of the engine lifter. I put one in tonight by myself in a few minutes. After I set it into the frame, I move the strap between the frame tubes lift again and line it up with a couple big Phillips screwdrivers. No, not JIS.
 I have a roll around stand made from a wrecked frame and a harbor freight furniture cart. Film at 11.
« Last Edit: March 23, 2025, 09:19:03 PM by Don R »
