Author Topic: Flow Bench  (Read 3233 times)
Offline Matt Hubbell
Flow Bench
« on: May 16, 2011, 12:16:22 PM »
I was at a friends house over the weekend and he was showing me his brand new flow bench. What exactly does the flow bench do for you and how does it make you go faster. Ok go.
  • Moderator
Re: Flow Bench
« Reply #1 on: May 16, 2011, 12:25:20 PM »
Did your friend not tell you, does he know how to use it. ::)
Sam ;)
Re: Flow Bench
« Reply #2 on: May 16, 2011, 01:09:38 PM »
Would your friend happen to have a Spiderman figure next to the flow bench ;)
  • Moderator
Re: Flow Bench
« Reply #3 on: May 16, 2011, 01:24:20 PM »
« Last Edit: May 16, 2011, 01:25:57 PM by SamCB750A »
Offline turboguzzi
Re: Flow Bench
« Reply #4 on: May 16, 2011, 01:37:56 PM »
What model bench flow was it?  Like Sam says, kind of strange he had the time to show it to you but not tell you what good is it for.
On the other hand, didnt Mike just bought one ;)
TG
  • Moderator
Re: Flow Bench
« Reply #5 on: May 16, 2011, 02:31:12 PM »
Who's Mike ? ;D ;D ;D ;D ;D
Sam. ::)
Offline turboguzzi
Re: Flow Bench
« Reply #6 on: May 16, 2011, 03:52:42 PM »
mike the bike  8)
Re: Flow Bench
« Reply #7 on: May 16, 2011, 05:07:04 PM »
Sorry but I wanted some additional info, yes Mike explained a little about what it does , but I want to know more of how it works. I understand that it measures flow, but what do you get from that. Obviously none of you guys know anything about it, so I will just wait for Mike to fill me in further :)
Offline Bill/BentON Racing
    • BentON Racing
Re: Flow Bench
« Reply #8 on: May 16, 2011, 05:21:47 PM »
Well....kinda like the more you flow
the faster you go.
Sorta like a dyno for the cylinder head.
Or carbs etc.
you measure,make changes ,measure,make changes, again and again etc.
Almost as much fun as 71 dyno runs! ;) ;D Bill
BentON Racing Website
BentON Racing Facebook
Re: Flow Bench
« Reply #9 on: May 16, 2011, 05:46:26 PM »
so during the porting process the flow bench is  measuring  what is done. Is that all it does?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Flow Bench
« Reply #10 on: May 16, 2011, 06:11:28 PM »
the faster you go.
+1
If I'm not mistaken it can also be used to bench sync the carbs...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: Flow Bench
« Reply #11 on: May 16, 2011, 08:55:03 PM »
the faster you go.
Well, not necessarily; there can be too much of a "good" thing. ;)
Re: Flow Bench
« Reply #12 on: May 17, 2011, 04:44:05 AM »
the faster you go.
A sewer pipe flows very well but it doesn't work very well as an intake or exhaust port. ;)
    • BentON Racing
Re: Flow Bench
« Reply #13 on: May 17, 2011, 05:05:40 AM »
OK,you can go too big!(I knew I left that one open ;))But the flowbench tells you what effect your work had.
Dyno then tells you more.
But the track is KING!!! ;) ;D
Offline BLUE71TURBO
Re: Flow Bench
« Reply #14 on: May 17, 2011, 08:42:57 AM »
              Here ya go Matt ............http://en.wikipedia.org/wiki/Air_flow_bench    ;)
              Wikipedia is a real good friend.   :o   8)
