Author Topic: Where does the horn actually touch ground?  (Read 3579 times)
Offline dgilling
« on: April 12, 2015, 09:52:40 PM »
My horn was working fine, then i had to remove my controls to troubleshoot my headlight.  Now the horn won't work and it's a grounding issue.  I can remove the horn button assembly and connect it to ground and then the horn works.  However when assembled in the control it doesn't work.  Where does it actually get it's connection to ground?  It has to be through that screw some how but I don't see a wire coming in for it to touch???
Offline mystic_1
  • 1970 CB750K
Re: Where does the horn actually touch ground?
« Reply #1 on: April 12, 2015, 10:26:00 PM »
The button grounds via the switch pod housing, which is grounded to the handlebars.
mystic_1
- John Augustus Shedd
Offline dgilling
« Reply #2 on: April 12, 2015, 10:34:36 PM »
So the bigger metal piece that hold most of the wires down on the bottom half, touches the handle bar, and the handle bar touches the triple tree? I guess the powder coat on my new handlebars is messing up the ground or I had that bolt/plate tighten too tight and there wasn't contact.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: April 12, 2015, 10:37:18 PM »
It's actually the little locating pin inside the pod that normally sits in a locating hole drilled into the bars next to the slot for the cabling, that provides the ground.
Powder coated bars will definitely interfere with proper grounding.
mystic_1
Offline MickB
« Reply #4 on: April 13, 2015, 01:39:07 AM »
 When does the horn actually touch ground? When you drop the bike.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: April 13, 2015, 05:25:36 AM »
Yes, remove the powder coat where the housing contacts the bar. Powder coating disrupts the grounding (as you've suspected).
AND where the bar clamps to the top tree!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline dgilling
« Reply #6 on: April 13, 2015, 10:34:43 AM »
mystic_1
Where is this locating pin you speak of?
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: April 13, 2015, 10:45:52 AM »
Inside the switch housing, in the lower half, there should be a brass-looking pin sticking up.
Visible here just to the left and below the leftmost phillips screw:
Alternate view:
mystic_1
« Reply #8 on: April 13, 2015, 11:13:35 AM »
Only the earlier models used the locating pin. It would align with a hole in the bars and prevent the switch assembly from rotating if it happened to loosen up a little. The later K7/K8/F2/F3 did not use this pin, which I happen to prefer since I can rotate the switch housing to my preferred location (I guess you could drill another hole if you had the pin style). The horn button simply grounds through the housing to the bars. The bars are then supposed to be grounded through their connection to the top tree at the handlebar clamps.
TAMTF...
Wilbur
Projects:
« Reply #9 on: April 13, 2015, 11:48:53 AM »
Or add an additional ground wire that connect the switch housing to the top tree. I removed my locating pin, the hole for it might be Ok for a screw holding a ground wire. (New control from VintageCB750 bought 2012)
My ground connection might been weak. Chromed bar but no pin. Horn button could control a relay that activate the A hungry dual snail horn. No relay only some clicking sounds.
Offline dgilling
« Reply #10 on: April 13, 2015, 12:07:06 PM »
Sounds, good.  I think i'll probably pull a ground from the clutch switch wire.  It will be easy to add something to that.
Offline dgilling
« Reply #11 on: April 22, 2015, 08:44:56 AM »
Here's my work around so I don't have to worry about any contact issues.  I borrowed the clutch switch ground connection.
solder extra wire to green ground on clutch switch
Probably not as clean, but this works just fine and you can't see the wire when the levers are in turned down correctly.
« Reply #12 on: April 22, 2015, 12:50:30 PM »
It look good, as it was designed that way!
