Author Topic: Permanent remove starter  (Read 1824 times)
Offline Bikedane
« on: May 21, 2015, 11:15:42 AM »
Hi All
I want to permanently remove my starter and do Kickstarter only.
Any suggestions what to do with the entry hole in the starter chamber.
Should I close it or not worry about it?
Re: Permanent remove starter
« Reply #1 on: May 21, 2015, 11:21:21 AM »
You could take some gasket material and secure it with Permatex, or do nothing.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: May 21, 2015, 11:58:18 AM »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Bikedane
« Reply #3 on: May 21, 2015, 12:21:04 PM »
Genius. Just bought it.
Thx a million n
Offline Trad
« Reply #4 on: May 21, 2015, 12:53:58 PM »
Here is the on I got from member 754 on here. Just an FYI, the plug for the 750 is the same for the 500/550.
Tach Plug 2 by tradart101, on Flickr
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #5 on: May 21, 2015, 01:26:49 PM »
LOL! MY KZ400 is the "S" version - kick only, and basically has a kit like that installed from the factory under the starter cover. Never even crossed my mind to keep party favors in there :)
« Reply #6 on: May 21, 2015, 03:32:52 PM »
Stash box for  . . . .  ;)
Online scottly
« Reply #7 on: May 21, 2015, 06:40:38 PM »
or do nothing.
Well, only if he doesn't mind a massive oil leak. :o
When I first removed my starter, I used an expandable rubber freeze plug, which I later replaced with an aluminum plug I made.
 Bikedane, have you removed the reduction gears under the alternator cover, as well as the starter clutch on the back of the alternator rotor (assuming a 750)?
« Last Edit: May 21, 2015, 06:42:24 PM by scottly »
