Author Topic: Manufactures cup: Valdosta- April 8-10, 2016  (Read 14959 times)
Re: Manufactures cup: Valdosta- April 8-10, 2016
« Reply #50 on: April 12, 2016, 06:06:57 PM »
Wilbur, you make it sound like you have a F2/F3 head/engine?? The pistons you are using HAVE to be above 9:1 or 9.2:1 stock CR. Most of the kits with the flat tops are 10.25:1 or 10.5:1 with the K style/early F engine. The 392 head may also measure less volume = more compression.
How are your carbs working now?
What cam are you running? BIG difference at small $$.
Guess you'll be working a deal with Mike now!! LOL.
Are you wearing big fat boots?
Wish I coulda been there to watch!! Congratulations.
Congrats to Frank also and EVERYONE. See you guys in November.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #51 on: April 12, 2016, 07:30:21 PM »
No, just a K8, but the K8 pistons have a raised dome, while the C.I. pistons do not. Rerunning the numbers shows that the 836 flat tops should maintain a compression ratio very close to the stock compression ratio of 9.2:1. My original calcs were off just a tad.  :-[
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Bill/BentON Racing
    • BentON Racing
« Reply #52 on: April 12, 2016, 08:42:26 PM »
Well, I'm just all discombobulated! Didn't notice qualifier so yes, my bad. Frank, I thought that's what you meant. Sorry about the miscommunication. I'll get your check and battery out tomorrow. Though I still need your address. You won $400.00 for best MPH and ET Saturday and Sunday. $100.00 for Sunday's R/T. Jays mailing me the run sheets so I can check Saturday's R/T times. Congratulations. Maybe Rockingham will be different. We shall see. Your 10.36 was impressive. See you in the lanes,Bill
« Last Edit: April 13, 2016, 04:08:51 AM by Bill/BentON Racing »
BentON Racing Website
BentON Racing Facebook
    • BentON Racing
« Reply #53 on: April 12, 2016, 09:02:05 PM »
« Reply #54 on: April 12, 2016, 09:42:24 PM »
How far up with the stroke do they both go? Did the stockers piston edge and crown top go up as far as the 836's? Bigger bore with same chamber volume should equal higher CR??
« Last Edit: April 12, 2016, 09:46:53 PM by Jerry Rxman Griffin aka MuthaF'er »
« Reply #55 on: April 12, 2016, 09:45:05 PM »
I want to see how far down in the 10's Frank can go once he gets used to the new engine and it gets broken in. AND I want to see how Bill does too. This will be fun.
« Reply #56 on: April 13, 2016, 04:07:46 AM »
Yes, that would be true if the stock pistons were flat top. The piston edges are the same, but the crown of the stock K8 piston extends into the combustion chamber, making the combustion chamber smaller with the stock (domed) pistons. Flat tops make for a larger combustion chamber, but the bore increase to 65mm (836cc) offsets this by almost exactly 1:1, so the compression ratio would remain near the stock value of 9.2:1.
The conservative volume of the dome is nearly 2.73cc (it might be a tad more). The volume of each cylinder has increased by 25cc. That extra 25cc is being compressed into the extra 2.73cc of chamber volume, so 25/2.73=9.1575.  ;)
EZPZ
TAMTF...
Wilbur
Projects:
Offline POPS 911
« Reply #57 on: April 13, 2016, 04:45:29 AM »
FRANK IN THE 10.30's  got a NEW MOTOR ????? Better check on that Jerry = I thought it was the OL WORN OUT motor of years pass. Better be careful LOCKING UP IN A DRAG RACE, maybe in road racing you can say that and not show up or their bike fails to run = but if that happens at a drag race you lose the money on the LOCK UP RACE. But no way could it ever be a heads up race with a old tired 10.30et  motor against a big COBRA MOTOR bike = 60' - 330' - 660' -1000' 1320' numbers plus mph do you really think that would be fair ?????
WILBER : Great time under your pop up = sitting and talking...... again you proved to ME it not about all the talk and it's all about those win tickets and NO RED LIGHTS !!!!!  How about those three in the row leaving on the second yellow, not you = you be the man with that best RT to get that bye.
POPS sitting under the pop up with Wilber WAITNG 5-6-7 hours next pass.
    • BentON Racing
« Reply #58 on: April 13, 2016, 05:11:35 AM »
POP'S,  Frank's engine is 1030, mines been 836/915cc.His engine is his old one. 1030cc, my new build is 1062, 32cc difference, nuff said, see y'all in Rockingham, Bill
Offline jweeks
« Reply #59 on: April 13, 2016, 09:57:52 AM »
Yes, I was the one who left 3 times on the second yellow. (-.319, -.087, -.062) 6 passes total on that bike. The first bad launch was affected by my inconsistent pressure on the rear brake lever. The bike moved forward, helping the big red light. If I had a test and tune session, I might have done better. I will T&T at Rockingham ;)
« Reply #60 on: April 13, 2016, 10:28:08 AM »
Pops/Frank, I thought Frank freshened up the top end??
Offline dragracer
  • CB750F Dragbike
« Reply #61 on: April 13, 2016, 10:48:45 AM »
Sam engine I ran last year Jerry. I haven't touched it in 3 years now and I'm getting worried she might come apart. I was running out of time in the offseason due to working in the wife's drag bike and other projects so I left the Honda alone. I didn't want to get caught up at the last minute trying to get the bike together to race. I think we've seen enough example's of that process in the past. I'll pull the engine off soon and completely disassemble it. The crank was wearing the last time I freshened it up and the margin on those those Honda valves was getting thin. I ordered a set of stainless steel valves from Dynoman and some lash caps from Mike. I'll have the head redone completely and install another crank, new rings and bearings before Rockingham.
Offline kmb69
« Reply #62 on: April 13, 2016, 11:12:11 AM »
What chu talkin bout Willis?
Past, present, I get confused!   ???  ;)  ;D
Offline dragracer
  • CB750F Dragbike
« Reply #63 on: April 13, 2016, 02:44:56 PM »
Hahaha!!! Well, there's at least a few of us that will admit to the trap.
Offline dragracer
  • CB750F Dragbike
« Reply #64 on: April 13, 2016, 02:58:49 PM »
I think you all should have figured out by now that its not about the money for me, but my contribution in trying to get more SOHC bikes out to race at the Man Cup. I committed to not accepting my challenge money from the World Finals last season so it could be put into increasing the SOHC winners bonus pot. I only see it fitting to once again turn my winnings for the challenge in April 2016 back over for a new challenge at the Rockingham race in June. This allows anyone on an SOHC based street ET bike a fair chance to win money from the ET, MPH and Reaction time challenge.
So hold onto that money Bill and be sure the winner of the June challenge understands that I donated the funds this time. Maybe the winner of the April race Saturday reaction time will also generously donate their winnings as well towards the Rockingham race so we cover the items for both days.
Lets get it together fellas- we need more bikes. Stock or otherwise, pro or rookie. Come on out and get into the fun. Its always a blast for everyone to get together. Or as our friend/forum member Pops described us- "the clown show". Oh yeah, I'm bringing my pointy shoes and hat to the next race just to make things complete. Lol!!!!!!!!!!
Online seanbarney41
« Reply #65 on: April 13, 2016, 03:10:46 PM »
You guys should post how easy tech and safety gear requirements are...wayyy less of a time and money investment than road racing!  If all the racing was not 1000 miles away, I would be there.  If you have the geographic opportunity, go run your bike down the 1320'!
    • BentON Racing
« Reply #66 on: April 13, 2016, 03:52:47 PM »
Well, Frank as usual, you da man, check went out in today's mail, but you can tear it up, etc. AND I will tell the winners who's money  they won in June at the Rock!  ......Oh so close,  less than 24 hours after getting home... the rh starter button works 12v with the 1100F starter! Now getting ready for 24 volts. ...damn it Gumby, we going be READY!  Lol, Bill.
« Last Edit: April 13, 2016, 03:54:33 PM by Bill/BentON Racing »
Offline dragracer
  • CB750F Dragbike
« Reply #67 on: April 13, 2016, 05:30:48 PM »
Bill, I surely hope you've got the stock timing advancer on the bike. It'll make it much easier to crank against the compression. Put light springs on the arms so it goes full advance after start up.
Personally, if you were having that much trouble cranking a mere 1062 as you called it, I'd temporarily remove that rotor and install the outboard starter plate and nut. I'd run it a few time that way til that tight motor begins to loosen up. Tight ain't good in drag racing to make horsepower.
Just my 2 cents with my worn out motor.
Looking forward to getting the machine work done on my new 72mm high compression F engine build so I can begin test fitting everything. It'll definitely be 24 volt starting. I'll see you in the lanes in June. Old motor, or new doesn't matter to me.
Offline BPellerine
« Reply #68 on: April 13, 2016, 05:36:21 PM »
maybe bill needs one of those guys behind him with big boots on the kicker like rc in one of georges pics of rc,he was not going to get bit by a big motor!!!! :) :) :)billp
1978 CB 750K ard and webers
another anfob
« Reply #69 on: April 13, 2016, 06:41:20 PM »
Yeah, where's Neal?
Offline dragracer
  • CB750F Dragbike
« Reply #70 on: April 13, 2016, 11:22:52 PM »
Here's a few of my time slips that show the .005 reaction time that earned me a much needed bye run and allowed me to make a solo pass that netted the included  10.36  ET  slip.
In Bill's words- nuff said!!! See ya'll at the ROCK.
« Reply #71 on: April 14, 2016, 01:29:12 AM »
By the way, could you feel any difference in the power with the bigger bore once the rings seated in??
Most definitely an improvement. Over a second off of ET when compared to November, plus the tendency for the front wheel to "reach for the sky". The "big bore" gains are a little muted as a result of using flat top pistons in the later model engine, so compression is not quite what it would be with an earlier head. Of course, lower compression pistons lend themselves well to supplemental compression (i.e. turbo or supercharger?)....  ;)
Overall, I am happy with it. Next performance mods will be suspension related, and a rev limiter for peace of mind. Stretch and lower the rear, along with lowering and stiffening the front, combined with some fine tuning of the A/F ratio (dyno time!) ought to gain another .5, and I'll be in the 12 second neighborhood!  8)
Maybe an ignition cutout to permit full power shifting (per the resident guru POPS)?  ???
I'll be building another motor throughout the season to campaign next year!  ;D
Wilbur - congrats on a great weekend! You might give a thought to lowering your bars too to help you get out of the wind (you're a big Galut to drag down a track).  ;)
I'm glad someone brought that up, I didn't want to hurt Wilbur's feelings... ;D ;)
Offline POPS 911
« Reply #72 on: April 14, 2016, 03:07:43 AM »
I'm no guru = ask Trey why the PURPLE HAZE did not shift ONE TIME with a AIR SHIFTER ???  Gave Wiber the simple kill button and with a hour or two and two pieces of metal he will be shifting full throttle open. Bars are to high and take off the mirrors and I will make him a strap to pull the front end down. Funny thing is I brought my hand made practice tree down to the race [ not some hand held game ] that cost $$$$ w/handle bars, clutch lever, and throttle that can be clutch tensioned  adjusted to your feel and roll out to your own setting = no one seem to want to practice. A race is not the place = track rental, make many leaves , which a dyno will not tell you your lights.
« Reply #73 on: April 14, 2016, 04:03:41 AM »
LOL  ;D
I have a set of flat bars, with an ever so slight pull back, that are on the short list of improvements. Hopefully they will remind me to get down out of the air! Found myself sitting upright at the finish line more than once...  :o  ;)
TAMTF...
Wilbur
Projects:
    • BentON Racing
« Reply #74 on: April 14, 2016, 04:17:46 AM »
Congratulations to all, we all had big fun. It is 1062cc, stroker crank would be next plateau, I ain't climbed this one yet! Yes to stock advancer, springs are light,  in the process of checking it out. We'll see what we find. We will be in the lanes next to Frank on sumpin. ......cause its just too much fun not to be! K. POP's,  keep up the dialogue,  we all benefit,  even if does sting at times! LMAO.  Who's going be at the Rock, the clown show goes on!  You ain't seen nuttin yet!  May your lights be green and your rounds be wins!  C'mon and play, Bill
These are what's inside it now. ;D Old pic as they came out of the old Cobra motor.
« Last Edit: April 14, 2016, 04:20:36 AM by Bill/BentON Racing »
