Author Topic: Hot Street Motor on a Budget  (Read 23065 times)
Offline stikman
  • Bit of an
Re: Hot Street Motor on a Budget
« Reply #100 on: December 05, 2016, 06:32:58 PM »
cool,what is the advantage of the cbx studs?I have heard of using diff bolts for the adj cam sprocket.have a buddy with a lot of cbx stuff,he may have a set for me.billp
Those four 6mm bolts under the nickle seals below the cam towers can't bite down very hard.  Replacing them with studs (CBX1000 exhaust studs as per MRieck) and smooth bottom flange nuts allows for decent torque on them, similar to the way the head studs and nuts work.  Credit goes to Mike for this mod.
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline stikman
  • Bit of an
« Reply #101 on: December 05, 2016, 09:04:49 PM »
So my brother has a set of NOS Honda K8 intake valves I could use, part #14711-300-015.  Can I use these in my K4 head?  Is there a difference between the K8 intake valves and the ones before (part #14711-300-005)?
« Reply #102 on: December 05, 2016, 09:38:03 PM »
Check the keeper groove the F and I think. Some late K used different keepers.
Offline stikman
  • Bit of an
« Reply #103 on: December 05, 2016, 10:27:26 PM »
Okay, thanks for that.  I'll have him measure them up.
Offline BPellerine
« Reply #104 on: December 06, 2016, 03:04:31 PM »
k8 uses diff keepers and retainers,if you can get the k8 stuff to go with the valves you can use them,but I think the early ones are preferred by perf guys?bill
1978 CB 750K ard and webers
another anfob
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #105 on: December 06, 2016, 03:15:57 PM »
That's correct. The later style K8 and F2 keepers had a nasty habit of pulling through the spring retainer caps. CycleX has replacement spring retainer caps for the later style that are stronger than stock. A.P.E. only does titanium spring retainers for the earlier style valve keepers.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline stikman
  • Bit of an
« Reply #106 on: December 06, 2016, 04:05:08 PM »
Ahh k, cheers for that info.  Guess those are out of the question then.  Good to know!
