Author Topic: Need help finding a gasket  (Read 1771 times)
Offline Bennie1977
  • will jump that bridge when i get to it.
« on: February 16, 2018, 10:43:01 AM »
Need help finding the seal for the plate around the shifter, and it probably wouldn't hurt to do the seal for the shifter as well. Just started leaking, i though it was the clutch cover, but the gasket doesn't look right. Any help would be appreciated.
Burn rubber
Re: Need help finding a gasket
« Reply #1 on: February 16, 2018, 10:53:55 AM »
 EBay or Honda dealer.
 Easy bits to mail if you are using ebay.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: February 16, 2018, 11:11:07 AM »
I though it was the clutch cover, but the gasket doesn't look right.
That is the transmission cover. The clutch cover is on the other side at the kick starter.  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Airborne 82nd
« Reply #3 on: February 16, 2018, 11:40:54 AM »
[/quote
(Back at you it works both ways) Maybe I missed it what bike and motor? Not meaning to be rude. I've. done it myself
« Last Edit: February 16, 2018, 11:52:15 AM by Airborne 82nd »
Offline rocket johnny
« Reply #4 on: February 16, 2018, 02:06:05 PM »
vintage cb750
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
« Reply #6 on: February 16, 2018, 02:45:26 PM »
 If it is the seal on the cover where your shifter spindle goes through one of my places,Paw Paw Cycle shows it as part number 91206-286-013. It measures 14x28x7 and costs a whopping $2.21. The cover gasket is $11.59 but you can probably find one cheap on E-bay maybe.
Offline Bennie1977
« Reply #7 on: February 16, 2018, 10:55:36 PM »
Not to worried about the price. Just want it to make sure i have quality parts going onto the bike. I dont want to ever have to replace new parts for at least another 40 years. Lol. I have to much into this bike to sell it. So i should till have it by then. Hopefully its worth more at that point. Honestly, im not sure what motor name is. Its a 77 cb750f. Its leaking oil from the trans cover. Should i do both of them? Im not sure what the one to the left(front of the engine) is called either. And i don't know if id have to take the trans cover off to replace it as well.
Burn rubber
Offline Bennie1977
« Reply #8 on: February 16, 2018, 10:57:08 PM »
2AM here. Probably not making  a whole lot of sense. Lol.
Burn rubber
Offline Yamahawk
« Reply #9 on: February 17, 2018, 03:01:59 AM »
Bennie,
  If the transmission cover is leaking, just replace that. The seal for the shifter is probably good, if it isn't leaking, don't worry about it. The alternator cover is in front of the transmission cover, and you don't have to replace that if it isn't leaking. They CAN be done separately from each other. Have a great day, brother!
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline DJ_AX
« Reply #10 on: February 17, 2018, 06:52:29 AM »
I've been happy with the service and selection from PartsNMore.com ...
In fact I just ordered these exact parts (N More) from them.
« Reply #11 on: February 17, 2018, 11:43:30 AM »
Transmission cover gasket is easy, just remove the shift lever, remove the transmission cover, clean the gasket surfaces well, and put a new gasket in place. Since you already have the trans cover removed go ahead and pop the shift shaft seal out and pop a new one in.
EZPZ
TAMTF...
Wilbur
Projects:
Offline Bennie1977
« Reply #12 on: April 30, 2018, 06:35:54 PM »
alternator cover is leaking around the bolts. Well, the cover in front of the picture I posted last time. If it's the alternator, why is it leaking oil....?
Burn rubber
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #13 on: April 30, 2018, 06:41:44 PM »
bennie, took a look thru my previous post here. http://forums.sohc4.net/index.php/topic,170906.msg1990127.html#msg1990127 most importantly look at goldarrow's response about 1/3 of the way down and subsequent posts there after.  your's is a 750 right?
cb750 k6 - ugly
Offline Bennie1977
« Reply #14 on: April 30, 2018, 07:06:17 PM »
Yes. I have the 750f. I like your covers. How'd you get the to shine like that? Also, where did you get your gaskets?
Burn rubber
Offline Bennie1977
« Reply #15 on: April 30, 2018, 07:07:38 PM »
Last owner painted everything black, I want to take the paint off, but it's pretty oxidized underneath.
Burn rubber
Offline evinrude7
  • not a kung-fu
« Reply #16 on: April 30, 2018, 07:15:50 PM »
#0000 steel wool, blue magic and elbow grease.
make sure you check that plug between the stator and transmission cover.  hondabond 4 was helpful here once it was all cleaned up.  i think i bought my gaskets from david silver spares.  no need for sealant on them.
cb750 k6 - ugly
« Reply #17 on: May 01, 2018, 05:43:45 AM »
F2 and F3 engines came from the factory painted black so some of the paint you have is probably factory original and may be tougher to remove.
Offline Bennie1977
« Reply #18 on: May 01, 2018, 05:54:18 PM »
Ahh, well, I don't know I the engine was painted or not, I do know that there was a rattle can paint job done on the rest of the bike, so I assumed.
Burn rubber
