Author Topic: CB750K8 stock tach reading 2x rpm?  (Read 3627 times)
Offline Pyroviking
« on: April 14, 2018, 06:49:33 AM »
Greetings,
I've had my CB750K8 for about 2.5 years now, and have used it exclusively for cruising around town, stop light to stop light and have never paid close attention to the tach, other than that it moves up and down when it's supposed to. So, I took it on the highway for the first time last weekend and at 70mph/7500rpm, went for the next gear only to realize that I was already in 5th. I took the next off & on-ramp to count the gears and confirmed 5th gear.
All of my long distance riding in the last decade or so has been on twins, and the last Honda 4 I had was a 954, so I don't really have an ear for revs on SOHC4 bikes.
I set up a dwell/tach meter to compare, and was hoping some of you more experienced with the SOHC4 bikes could chime in to either tell me what I'm doing wrong, or confirm that my tach is reading WAY high.
If I'm calculating correctly:
Std. 8 cyl = 8 pulses/2 rev (4:1)
Std. 4 cyl = 4 pulses/2 rev (2:1)
SOHC4 = 2 pulses/2 rev (1:1)
So, if I'm comparing the RPM reading on the dwell meter to the stock tach, I need to multiply the Std. 8 cyl reading by 4, right?
This gives me 400 x 4 = 1600 rpm vs 2950 and 1025 x 4 = 4100 rpm vs 7200. If my logic is correct, then this would explain why it shows such high rpms on the highway, but I sure would appreciate being corrected if I'm missing something. Thanks in advance.
Andrew
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
Re: CB750K8 stock tach reading 2x rpm?
« Reply #1 on: April 14, 2018, 07:27:43 AM »
This is a cable driven tach, correct? If so, the magnetic cup drive may have some dirt and lube causing it to drive faster from friction, than it should from the magnetic force. Either that, it it may need lubrication, and the easiest way to do that, is to remove the tach, get a couple cotton balls dipped in kerosene, and stick them into the bulb sockets in the tach. Remove the lights when you take the tach off the bike, and stick the soaked cotton balls into the holes, and set in a Warm place, out in the sun is good on a warm day. Be sure the tach sits upright, so the kerosene doesn't get a chance to drip on your lens. In a day, the kerosene will evaporate and lubricate the tach mechanism. If this doesn't do it, time to disassemble the tach for thorough cleaning.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: April 14, 2018, 08:26:48 AM »
Sounds like a slipping clutch at highway speed leading to a rise in RPMs, unless you're running some crazy sprocket ratios like 16/52 or something.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline rotortiller
« Reply #3 on: April 14, 2018, 09:12:25 AM »
What bike did the tach come from?
Offline Pyroviking
« Reply #4 on: April 14, 2018, 09:26:26 AM »
Thank you. Yes, it's a cable driven tach. I will certainly try that immediately.
Thank you. As far as I know, the sprocket ratio is stock. Would a slipping clutch account for the discrepancy with the dwell/tach meter in neutral, though?
As far as I know, it's the original one, but I really have no idea. Is there an easy way to determine if it is or isn't?
« Reply #5 on: April 14, 2018, 09:36:57 AM »
Is the tacho new on this bike or bike is a new purchase for you?
CB500 tacho runs much faster on a CB750. I know since I have tried it. 3-4000 instead of 2000 rpm something
Tacho gear ratio http://mostynindustries.com.au/speedo-tacho-ratios
CB750 4:1
CB500 7:1
Offline Pyroviking
« Reply #6 on: April 14, 2018, 10:41:18 AM »
CB750 4:1
CB500 7:1
Thank you. The bike is a relatively new purchase for me and I have not changed the tach.
This is very interesting. If my experimental data is correct, then my tach is reading high by almost exactly 7:4. That would be quite a coincidence. In addition to this, is there any easy way to confirm definitively that I do have the wrong tach? Are there any clues in the pics in my first post? Redline, maybe?
« Reply #7 on: April 14, 2018, 01:25:32 PM »
Possibly. My K8 CB750's redline at 8500 RPM.
TAMTF...
Wilbur
Projects:
« Reply #8 on: April 14, 2018, 02:00:19 PM »
+ the faces are a different color. Speedo looks green and the tach blue as well as the redline markings being too high.
Offline Yamahawk
« Reply #9 on: April 14, 2018, 02:47:15 PM »
Yep, just noticed the tach redline too, it's likely the wrong tach the PO substituted to sell it.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline Pyroviking
« Reply #10 on: April 14, 2018, 04:55:51 PM »
I think the mystery is solved. Thank you all very much. You guys are the best.
Andrew
Offline Yamahawk
« Reply #11 on: April 15, 2018, 01:18:19 AM »
Andrew,
   Had the same thing on the K1 I have, the PO had substituted CB400 gauges and seat on the bike, and the tach had a redline of 9500rpm, seemed like it wasn't revving as high as the tach indicated, so I got a set of CB750K3 gauges on it and all is well. These guys here are really a great help for us all!
Charlie
Edmund Burke
Romans 8:28
Job 13:15
Offline brewsky
« Reply #12 on: April 15, 2018, 04:12:12 AM »
Just for reference, I'm at 4000 at 60mph, so that would make it 4666 at 70mph...(K8 with stock gearing and 130/90-17 rear)
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Pyroviking
« Reply #13 on: April 16, 2018, 09:44:25 AM »
Again, thank you all. I purchased the correct tach on ebay without breaking my wallet. I'm really relieved that the issue wasn't something more serious.
Andrew
