Author Topic: 78 CB750K rescue / restomod / survivor build  (Read 1460 times)
Offline IndianaDave888
    • www.cb750.com
« on: December 04, 2018, 05:09:08 PM »
This is going to be a documentation of the rejuvenation, and eventual testification of this 14000 mile bike that's been sitting for 25-30 years.
This is the day I picked it up. The guy I bought it from bought it off the original owner. He had started to fix it up, but stopped.
Sent from my LG-K373 using Tapatalk
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 78 CB750K rescue / restomod / survivor build
« Reply #1 on: December 05, 2018, 09:52:24 AM »
As long as the engine turns freely there should be no need to tear down the motor. Looks like a worthwhile effort. Too bad he tore the carbs completely apart since the PD carbs can be a bit of a challenge.
Good luck!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #2 on: December 06, 2018, 09:43:18 AM »
Good luck!
If "tear down" equates to complete rebuild, I agree.  It may, depending on compression levels need a top end refresh.  Assuming it turns freely, run a compression test.  If compression levels are even and at nominal levels, then move on to looking at other things.  Does it have signs of weeping/leaking gaskets or seals?  Drain and inspect the oil and pull the pan off to look for any apparent glistening or metal bits that do not belong (indicating metal on metal wear, or shards from bearings or transmission gears).
Assuming you have good compression, no leaks, no apparent signs of internal metal wear, you might not need to crack the engine open.
