Author Topic: Spark advancer '73 CB750 - Help!  (Read 822 times)
Offline Mark K
« on: September 06, 2022, 01:28:52 PM »
Rebuilding the engine, removed the spark advancer, did not remove the tiny shaft. Do I need to replace the tiny o-ring behind the tiny shaft?
Also, does the collared shaft go over the spark advancer and if so, how does it fit? When I disassembled the engine a year or more ago, I don't remember removing the collared shaft and I don't see it in the parts diagram.
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
Offline WideAWAKE
Re: Spark advancer '73 CB750 - Help!
« Reply #1 on: September 06, 2022, 02:15:07 PM »
I can’t comment to the little o ring.
But to get that collar back on you basically spread the weights and align the notches of the collar so it slips down under the weights. There should be a very thin washer that sits between the advance body and the collar.
If it was mine, I’d complete disassemble it, clean it, oil the pivot posts and the collar.
You will notice there is a small mark on the collar, that align with the hole on the advance body. If you put it on the opposite way, your moped will be pedals only haha
Offline Bigmant
« Reply #2 on: September 06, 2022, 08:17:24 PM »
+1 to the above
Totally agree with taking apart and lubricating everything you can. You’ll be surprised with the results. You can actually feel it even when it’s off the bike.
‘73 CB750 K3 Owned by my father and now me
Build post: http://forums.sohc4.net/index.php/topic,190516.msg2216419.html#msg2216419
Offline Mark K
« Reply #3 on: September 07, 2022, 11:45:06 AM »
Thanks for your help.
Former bikes
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #4 on: September 07, 2022, 02:53:03 PM »
In all likelihood your springs are weak due to age and heat. This causes early advance, and poor running.
Tell me about it!
Hondaman has discussed this at length, get his book pronto! It’s my savior.
On at least one spring, cut off one winding and re-form the loop.
When the motor is running check total advance with a timing light. About 2500-3000 rpm for full advance
Link
http://forums.sohc4.net/index.php?topic=131339.0
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #5 on: September 07, 2022, 03:58:35 PM »
^^^ That^^^
I shortened advancer springs on Dorothy and it made a huge difference.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: September 09, 2022, 07:06:06 PM »
Make sure you get the "collar" (A.K.A. points cam) oriented correctly. The procedure for indexing this points cam properly can be found in the shop manual. Getting the points cam oriented properly is necessary for proper ignition function.  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #7 on: September 09, 2022, 11:33:26 PM »
Both my CB750 got both springs cut. My K6 advancer had a huge play with full advance kicking in too early. Not possible to adjust.
Found thread about cutting springs were Hondaman  recommended it.
That solved it. I usually adjust F to line up at idle, full advance happen at 2600-2700 rpm.
I like smooth running engine at take offs and at low rpm.
Here my first cut of the springs solving the problem.
http://forums.sohc4.net/index.php/topic,131339.msg1464986.html#msg1464986
