Author Topic: Removing and Installing a CB750 Engine  (Read 3365 times)
Offline C317414
Re: Removing and Installing a CB750 Engine
« Reply #25 on: March 08, 2023, 10:15:32 AM »
I have  a  neighbor who has two sons, both of whom play varsity football (defense). Engine in and/or out and I enjoy a beer meantime.
LOL....   :)
I do something similar.  I have a riding buddy who is very big and strong.  I invite him over whenever I need to remove or install an engine.
« Reply #26 on: March 08, 2023, 06:36:26 PM »
Have a safe and fun trip.
I'm with Ujeni, I put the frame over the engine, I've even done it with forks on (no tire).
How did you keep from squishing the points cover?
Reason i ask: I just received an engine last summer for rebuild, and someone had apparently taken it out of the frame that way. It really flattened the cover!
Offline Ujeni
« Reply #27 on: March 08, 2023, 06:39:55 PM »
I have a sacrificial point cover.
Ujeni Motors
Sandcast #410
Sandcast #538 Watch the restoration!
Sandcast #6592 All original daily driver.
« Reply #28 on: March 09, 2023, 06:03:59 AM »
I have a thick, finned alloy “chopper” style cover. Damaged, but perfect for moving around.
« Reply #29 on: March 09, 2023, 06:18:24 AM »
I've seen posts on using 2x4 blocks to hold the engine off the floor to protect the points cover area.
« Reply #30 on: March 09, 2023, 06:35:05 AM »
+1.  And I set the motor on a heavy duty moving blanket folded over a couple times.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #31 on: March 09, 2023, 06:45:38 AM »
and a sacrificial advancer shaft...
Lower back pain and injuries are cumulative (i.e. they add up). A career in construction has taught me to use the proper tools for heavy lifting to avoid using up what little I have left of my lower back.   ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #32 on: March 09, 2023, 07:07:13 AM »
I also use a moving blanket and some blocks of wood, works great. I have an extra points cover too.
« Reply #33 on: March 09, 2023, 12:58:47 PM »
Like I said earlier, I have three installs and removals, from built motorcycles, planned for 2023. There will be a break for our upcoming trip, but I am determined to build my two person “stretcher”.
Updates in May.
« Last Edit: March 09, 2023, 01:15:46 PM by BenelliSEI »
« Reply #34 on: March 09, 2023, 02:20:18 PM »
Be sure to post pics, it should be great.
Offline Ujeni
« Reply #35 on: March 09, 2023, 02:52:55 PM »
Found a frame from my timelapse showing my wife and I putting the frame on the engine. Note how much of the engine is not mounted. This makes the lift far easier.
You can watch the timelapse if you need help sleeping :)
Ujeni Motors
Sandcast #410
« Reply #36 on: March 09, 2023, 04:18:03 PM »
I just never that methodical, or organized. The bike is usually rolling around on it’s wheels before I get the engine completed. This time is no different......
« Reply #37 on: March 09, 2023, 05:53:07 PM »
Here are a couple pictures of the blocks I've seen.
But I do like the idea of lifting the motor with a cherry picker to save my already broken back.
« Last Edit: March 09, 2023, 05:58:06 PM by newday777 »
« Reply #38 on: March 10, 2023, 04:59:09 AM »
I like the “L” hanger, with the adjustable centre lift point (that wasn’t quite long nough?). I tried something like that a few years ago and had two issues. It’s not easy control the angle (up and down of the back and front) of the engine and the legs of my folding hoist never fit properly under the lift table. A LOT of shimming and prep. I want something that installs in a couple of minutes, is easy to use, and gets put away just as quickly, and takes up little space.
Offline Remcod
« Reply #39 on: March 10, 2023, 05:20:00 AM »
Please send me their contact details :)
Verstuurd vanaf mijn SM-A536B met Tapatalk
Offline robvangulik
  • Honda Fourever
« Reply #40 on: March 10, 2023, 07:05:48 AM »
When you need help like that you can always call me, I've done it before ;)
« Reply #41 on: March 10, 2023, 07:08:23 AM »
I always love to see garages and work spaces that are really tidy and open. I'm sort of organized but I could not say my garage is a picture of clean and neat. We do too much out there.
« Reply #42 on: March 10, 2023, 07:18:37 AM »
BTW
The pictures I posted are not my garage...... they were in someone else's garage and post.....
But I have attempted to get a bit more on the organization side of the spectrum this past year, though the unorganized in me still prevails.....
« Last Edit: March 10, 2023, 07:20:52 AM by newday777 »
« Reply #43 on: March 10, 2023, 08:14:31 AM »
Solo motor install on the "Park Racer" project.
[engine color has been changed since]
Offline Geoff Hastings
« Reply #44 on: March 10, 2023, 10:43:43 AM »
I use a strap and a chain hoist to remove or fit the engine on my own. Just have to remember to move the straps to the outside of the frame once the engine is nearly fitted.
« Reply #45 on: March 10, 2023, 02:59:39 PM »
Hope you test fired her before going in the bare frame…
Be a lot of work chasing a small problem around in a frame let alone a roller....😇
« Reply #46 on: March 10, 2023, 05:56:18 PM »
Hmm...maybe I've finally found a use for that thing...it's been lying around here (somewhere) for years, now.
« Reply #47 on: March 11, 2023, 03:58:34 AM »
I’m not sure if you were referring to my post or not but….. After I fitted the engine I took it for its first run only to discover a spacer had been left out of the gearbox so the engine did indeed need to come back out.
« Reply #48 on: March 11, 2023, 06:00:10 PM »
Not you in particular. More rhetorical than personally directed..
With the different thickness head gaskets, orings, etc…a test fire will save some paint and work..
« Reply #49 on: March 12, 2023, 05:53:19 AM »
 I remember I painted up the engine cases etc. on an 836 and had it looking very purdy , mounted up the carbs etc. and when I turned on the gas a float got stuck and dumped gas all over my nice fresh new silver paint !  ;D  Note to self make sure drain hoses are connected.
