Author Topic: Obvious sillyness (Oldest tires & sprockets contest)  (Read 6026 times)
« on: December 31, 2023, 10:26:56 AM »
  I might need new tires on my bike, the tread is OK but the sizes are some sort of letter code and the date stamps only have 3 digits?  Do they really need replaced?
« Last Edit: January 10, 2024, 02:39:22 PM by Don R »
Re: Obvious sillyness
« Reply #1 on: December 31, 2023, 10:36:51 AM »
If rubber feels not dry without cracks, test ride next.
Might work fine for cruising around in legal speeds.
Inspired riding where your knees or foot pegs will go close to the asphalt, fresh tires a cheap ensurance.
Online BenelliSEI
« Reply #2 on: December 31, 2023, 11:06:06 AM »
For tires: “when in doubt, throw them out”.
Online grcamna2
« Reply #3 on: December 31, 2023, 03:05:11 PM »
« Reply #4 on: December 31, 2023, 03:59:15 PM »
Done that to plenty of tires with no issues.  Your experience may be different.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: December 31, 2023, 04:29:22 PM »
For those that don't recognize the silliness, four-digit date codes were implemented in the year 2000 making any tire with a three-digit date code well over twenty years old!
Good one Don! This also would have been appropriate in the joke of the day thread.  ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Online newday777
« Reply #6 on: December 31, 2023, 05:02:39 PM »
Hey I have a couple tires on the parts bikes with 3 digi dates on them.
« Reply #7 on: December 31, 2023, 11:40:42 PM »
An old  bike with its original tires is worth more? ;D
« Reply #8 on: January 01, 2024, 10:16:50 AM »
 These tires have white letter sidewalls, they are pretty fancy to be honest. The seller thought they might be original but I'm pretty sure they have been changed once. They did make it a few miles on my test ride.
 I did keep the original front tire off of my sandcast. it looks OK but has a flat spot from sitting a decade or two.
 Thanks Wilbur, I guess the sillyness wasn't as obvious as I thought. lol.
« Last Edit: January 01, 2024, 10:18:25 AM by Don R »
Re: Obvious sillyness (Oldest tires contest)
« Reply #9 on: January 10, 2024, 02:23:52 PM »
 When figuring the sprocket ratio do you count where the teeth were, or only where they are?
Offline Kelly E
  • Geriatric Hooligan
« Reply #10 on: January 10, 2024, 02:28:06 PM »
You'll have to count them, they're mostly there. ;D
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #11 on: January 10, 2024, 02:31:21 PM »
 OK thanks.
Offline CycleRanger
  • No comment about being an
Re: Obvious sillyness (Oldest tires & sprockets contest)
« Reply #12 on: January 10, 2024, 03:38:19 PM »
I recently pulled an original front tire off my 1971 CL350. Still had plenty of tread left.  ;D
I've also got a original Bridgestone Superspeed that came on a rear wheel I got from a '73 750.
It has about half the tread left. I should put it on ebay as "vintage". ::)
« Last Edit: January 10, 2024, 03:41:18 PM by CycleRanger »
« Reply #13 on: January 10, 2024, 05:25:58 PM »
So...does that make this one a 16.75-tooth sprocket?
That will raise the RPM at hiway speeds...
« Reply #14 on: January 10, 2024, 06:03:36 PM »
My 1971 Suzuki T500 still has its original redline tires on it and only a couple thousand miles on it. Leaving them on for now since I still haven't decided if I want to keep or sell it. Already have had it a long time since 2017, tough decision when your a hoarder.  :D  Pic later when I change computers .
« Last Edit: January 10, 2024, 06:38:06 PM by ekpent »
Offline CycleRanger
« Reply #15 on: January 10, 2024, 06:55:46 PM »
That's a beauty!
« Reply #16 on: January 10, 2024, 08:39:28 PM »
That T500 is almost NOS! ;)
Online BenelliSEI
« Reply #17 on: January 11, 2024, 06:24:23 AM »
Don…. I’ve only seen one sprocket that worn and threw it away so fast I have no photo!
« Reply #18 on: January 11, 2024, 06:48:54 AM »
I bought a Kawasaki 750 4 cylinder 4 stroke once at a yard sale and it came with a new bearing because the guy said it had a clunk in the back. Well when I got it back to the shop and started looking it over the rear sprocket pretty much had no teeth and the chain was slipping. Guy must not have been to sharp to not notice !  I saved to somewhere in my shop for #$%*e and giggles.
« Reply #19 on: January 12, 2024, 03:52:35 PM »
I took a closer look 16.25 teeth.
« Reply #20 on: January 12, 2024, 03:56:39 PM »
 I had a T350 a while back but it was the opposite end of the spectrum from that T500. I'd like to get my brother an X6, he worked at an oldsmobile dealer that had suzukis for a while when they were new.
Offline Kelly E
« Reply #21 on: January 12, 2024, 05:58:35 PM »
Here's the sprocket that was on the 78' KL 250 when I got it. The bike has 15k miles on it and I think this is the original sprocket. ;D
1983 Honda CB 1100F
Online grcamna2
« Reply #22 on: January 12, 2024, 06:32:39 PM »
This sprocket is really worn;I've seen one in the past that was So badly worn that all the teeth were curved in one direction,like a circular saw blade.
The chain was just slipping over it every time the bike was shifted
« Reply #23 on: January 13, 2024, 02:06:37 PM »
 Here is an engine that I just opened. Has sat for so long it varnished inside but was awfully abused when it was running.
 The pump screen was pushed in causing oil to go through it, I assume a lot of this crud happened sitting in the barn but the crank oil holes are plugged solid. No way did that happen while sitting. A chip was gone off of a piston, I think the oil pump ate it.
« Reply #24 on: January 13, 2024, 02:08:37 PM »
 The screen.
