Author Topic: What did you do to your bike today ?  (Read 3729131 times)
0 Members and 14 Guests are viewing this topic.
Offline oldhatt45
« Reply #19700 on: April 29, 2015, 06:21:01 PM »
Only goes to prove the old saying.
If you can't play with it and you can't eat it,
Poop on it and walk away.
Charlie
PS:  Rubber handles Gooooooddddddd!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19701 on: April 29, 2015, 07:06:27 PM »
Got my new rear tire in the mail...
Same as before, just not worn down! Bridgestone Spitfire 130/90-17. Going to my father in laws to change it on the weekend (he has tire changer!)
Also checked the fluid level in my battery... almost all bare! No wonder my smart charger was bleeping at me! Filled with distilled... going to do a load test tomorrow.
--Evan
1975 CB750K "Rhonda"
Offline edwardmorris
  • Youngish
« Reply #19702 on: April 29, 2015, 08:33:51 PM »
12 hour marathon, but I got my K2 engine 95% buttoned up.
Offline Jo3f1sh
  • Still don't have a jacket, even though I'm a
« Reply #19703 on: April 30, 2015, 07:59:07 AM »
Fixed my flat.
1974 Honda CB350 Four
Build thread: http://forums.sohc4.net/index.php?topic=138848.0
« Reply #19704 on: May 01, 2015, 04:43:27 AM »
  So working to get a K2 road worthy. Have it running and ready just need a gas tank. Tank interior and cap was quite rusty, forgot pic. I am a 'The Works" guy. Put in some nuts and bolts and sealed the bottom petcock holes with a plate and rubber strip. Put in a bottle and a half of the works and installed an expandable rubber plumber plug at the filler. Had already put a coat of unbuffed wax on tank and also kept wet with a hose in case of a leak. Shake baby shake, sideways, upside down shake shake shake. Let the acid do its thing. Carefully took off top bung, there will be pressure. Emptied works through petcock hole, thoroughly flushed with water along with a baking soda rinse.
  The key to success is drying quickly so hooked up my reversible 165mph shop vac and quickly blew it dry. Installed petcock, added a gallon or so of gas with a dash of two stroke oil. Boom baby done in around 2-3 hours and ready to move on to the next little project.  ;)
« Last Edit: May 01, 2015, 04:53:57 AM by ekpent »
Offline evanphi
  • Apparently I'm an
« Reply #19705 on: May 01, 2015, 06:08:40 AM »
Zing! Shiny!
I rode to work today... Only 1 degree C out today. Fingers almost fell off by the time I got there... And I got cut off while making a left hand turn... Good day so far!
Going to get my tire changed tomorrowwwwww
« Last Edit: May 01, 2015, 07:07:57 AM by evanphi »
--Evan
Offline Davez134
« Reply #19706 on: May 01, 2015, 07:16:51 AM »
You know if you throw your hand up like that with all your fingers, he probably just thinks you're waving. Got to let them know they are #1! ;D
Offline MoMo
  • Ride like you're invisible
« Reply #19707 on: May 01, 2015, 07:38:52 AM »
Yep, always use the universal sign of ill will
Offline evanphi
  • Apparently I'm an
« Reply #19708 on: May 01, 2015, 07:41:48 AM »
Thanks! I forgot! ;D
We hit a red light about a KM later... pulled up next to him, but decided against exchanging words. Not worth it.
All new motorcycles should come with horn buttons on both sides of the bars... that way we can lay on the horn AND flip the bird!
--Evan
« Reply #19709 on: May 01, 2015, 10:45:22 AM »
New rod holder with pilot lamps for K6 from z1-parts-inc.
No HONDA text, but correct order of pilot lamps with highbeam for K6.
The other replicas for the older bikes with Honda text, Beam instead of Highbeam look cheap.
The HONDA text should be relief, text that a blind person can read with finger. Strange that NOS can not be found
« Last Edit: May 01, 2015, 10:15:32 PM by PeWe »
Offline kap384@telus.net
« Reply #19710 on: May 01, 2015, 02:31:49 PM »
Installed the new Seat Concepts seat on my CRF450x and installed new sprockets.  Need to bleed brakes
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline eigenvector
« Reply #19711 on: May 01, 2015, 05:28:08 PM »
Think I found the source for the blown fuse when I use my turn signals.  The grab bar was rubbing on the fender - pinching the turn signal wires and shorting them out. :'(
Now I have to repair and re-wire the turn signals.  No big deal - just more work than I wanted.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #19712 on: May 01, 2015, 06:00:16 PM »
That should be the SOHC motto.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #19713 on: May 01, 2015, 10:13:14 PM »
Sure it is when the bike project become more and more serious as time goes by and getting new ideas on this forum.
« Reply #19714 on: May 01, 2015, 11:54:21 PM »
funny you should say that... to me sohc's are less and less work...they are so rock solid dependable, I hardly have to do much to them
Offline eigenvector
« Reply #19715 on: May 02, 2015, 04:18:45 AM »
It took me a while to get my bike to a place where I too don't have to do much to it.
My bike was rode hard and put away wet when I got it, so it had lots and lots of issues.  I've slowly but surely chipped away at those issues.
I have a lot of incidental tweaks, but some of those are probably not really necessary - the fact that the bike's mainly mechanical rather than electronic probably encourages me to do more than I normally would.
Rob
1977 CB550K
1983 VF750S Sabre
Offline joeyvans
  • Definitely not a
« Reply #19716 on: May 02, 2015, 06:37:48 AM »
I completely agree, Sean. Once I get to the point of being happy with how my bike is set up, it should be very little work. Being a perfectionist, the journey to that point is at times frustrating. Happy weekend!
1976 CB550 K2
« Reply #19717 on: May 02, 2015, 01:47:50 PM »
Repaired thread for a cam stud with helicoil I knew was rising.  Big-Sert thread insert went in, Loctite 272 to keep it in place. New stud sealed with teflon high temp sealer.
Ended up by mounting another cam and timed it. It has recently been in so adjusted IN open/close as I know it should be.
« Last Edit: May 03, 2015, 12:28:02 AM by PeWe »
Offline InAquaVeritas
« Reply #19718 on: May 02, 2015, 02:52:59 PM »
Started putting my engine back together! Finally got to that stage!
Pulled the needle bearings from the main shaft. Tried with brute force, but ended up taking out the needles and cage, and using a regular bearing pulled to get the out. Tapped the new ones in with an alu spacer that's the same diameter.
Replaced the chains and a few bearings, still would like to do the big one but it's hard to find.
One half of the gear box works well!
I'm stuck with the neutral switch though, I can't get it back together. I have a 1978 F2 and the neutral switch is a lot more complex than the Hondaman book shows:
How does this go together and am I even correct that this is all neutral switch? It's been a while since I pulled it and didn't take pictures...
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
Offline JeffM
« Reply #19719 on: May 02, 2015, 03:49:57 PM »
Pulled the carbs, bench synced, put them back on, put on my new Uni air filter, vacuum synced the carbs, went for a little ride and then washed the bike. :D
1976 CB550K
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #19720 on: May 02, 2015, 04:17:09 PM »
Casting an intake manifold for a supercharged cb550
I like berries.
Offline jerry h
« Reply #19721 on: May 02, 2015, 04:52:56 PM »
Wow!  Do you have a project thread going?  If so what's it called, if not get one going.  Would love to see more ..... ;D
Offline mystic_1
  • 1970 CB750K
« Reply #19722 on: May 02, 2015, 05:45:05 PM »
Holy crap!  I love how casually you toss that out there, too.
Other dudes are like "I changed my oil" or "I fixed my tire" and you're like "Oh yeah, I did some work too..." than then KABLAM you drop that on us.  8)
I managed to find this post from late last year:
supercharge this....
But we Want To Know More!
mystic_1
- John Augustus Shedd
Offline DaveBarbier
« Reply #19723 on: May 03, 2015, 06:00:56 AM »
Trie to finish up wiring in some new switches...
Then this happened...
Note to self: Don't substitute the motorcycle lift with 9 year old daughters arm...
Oh no! You owe her so much ice cream! She seems to be taking it well enough. I don't see tears rushing down her face...in the picture at least. I don't even know how many bones I broke as a kid her age. On the bright side, they heal quick and it gives her some street cred. "Broke my arm while working on the motorcycle. Just a day in the life of a badass."
1978 Honda CB550K
Offline eigenvector
« Reply #19724 on: May 03, 2015, 06:48:50 AM »
Jesus that's a terrible break.  Both bones.
Rob
1977 CB550K
1983 VF750S Sabre
