Author Topic: How to drill out spark plug wires?  (Read 816 times)
Offline stereosilence
  • 1975 CB550K
« on: November 22, 2014, 08:19:58 AM »
Is there a how-to somewhere for this? My coils were working by the wire is fraying right at the coil (so no splicing). I haven't been able to find any inexpensive replacements that don't require a custom bracket for my 75 cb550.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline faux fiddy
  • bike in a box
Re: How to drill out spark plug wires?
« Reply #2 on: November 22, 2014, 07:16:11 PM »
I followed a thread  here that used a stick of romex,
First  drill a pilot hole about 3 cm deep where you think the center of your old wires are. Drill it to the size of a small piece if stripped romex.
If you are lucky you will find some new copper plug wire, 7mm. Drill a hole 2cm deep that size, stick your piece of romex in the pilot hole and then stab the new wire on. I leave mine with a bit more length than stock, and I epoxied a small boot over it, but is that really necessary? .
You can drill the large hole to almost that exact size, or as tight as you can squeeze the wire in.
Use the search feature and see what you come up with...
Edit:oops  half that  deep ...
« Last Edit: November 24, 2014, 11:11:59 AM by faux fiddy »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #3 on: November 22, 2014, 07:17:05 PM »
its a fiddle,take your time.
Offline faux fiddy
  • bike in a box
« Reply #4 on: November 22, 2014, 07:38:34 PM »
Yeah, I put the epoxy in the windshield of a parked truck for a few sunny days. The epoxy kicked real well.
Offline strynboen
« Reply #5 on: November 23, 2014, 07:39:50 AM »
 dont drill...use a nife and cut inn 3 cm inside the coil...then the  old vire can be pulled back aut
dont kut up from the end..so the vire can be pressed in throug a hole..and be nice teight and hold ..
let some matrial stand ca 10 -20 mm..so the vire are hold in place...cut in to the veld point ca 3 cm..inside and cut in there..then there are only a small hole to glue... i use lego meldet in acetone..and then filled in the coil..as glue..
« Last Edit: November 23, 2014, 07:46:26 AM by strynboen »
i hate all this v-w.... vords
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #6 on: November 23, 2014, 01:37:17 PM »
This is how I do mine. Solder the ends and fill with RTV.
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #7 on: November 23, 2014, 11:07:29 PM »
that's a neat job!i use 2 pack epoxy though.
