Author Topic: 1972 CB350 For the Daughter  (Read 74212 times)
Re: 1972 CB350 For the Daughter
« Reply #325 on: March 25, 2017, 06:25:53 PM »
Looking excellent.  8)
« Reply #326 on: March 26, 2017, 02:05:50 AM »
Nice!  I like the look.
That is some meat on that back tire.  How is the clearance in the rear?    I hope it stays on the positive side after adding weight of seat, other gear and rider.
Looking forward to the reveal of the tank and what you and she decided on that front.
I should have suggested you look at the legshield badge on a C70 Passport.  There is one that has Honda Wing with circle but it is not a circle medallion as the circle is interrupted on both sides with Honda... the wing is either silver or gold as is the letters, don't recall without looking it up again.  Or, it could be done by a vinyl sign shop for putting beneath the clearcoat, which I hope is a urethane for gas resistance/longevity.  I know an artist/vinyl sign specialist near Albuquerque how does fabulous work and paint masks or the decals in thin 3M vinyl or other appropriate uv stable outdoor vinyl would probably be around $20 and shipping.  Callie Graphics,  Callie does fantastic work and she is very quick.
David
with some work to mirror the wing this could be done in paint or could
« Reply #327 on: March 27, 2017, 02:11:31 AM »
The 78CX used Steel Spokes, they are the std Comstar and the '79 started using the reverse Comstar wheels. Larry mentions in this How to Polish Aluminum tutorial (EXCELLENT how too with some great techniques and tips... Like how to strip the anodized finish off your controls to polish them. Super Clean, by Castrol does the job...then buff the black/grey dull coat to bring them up to high luster as shown in the link below.  Larry has a great tip on how to get into narrow grooves too!)
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #328 on: March 27, 2017, 04:52:03 AM »
It is pretty much a stock size rear tire.  Well as close as you can get converting to metric sizing.  There is a lot of clearance.  I was worried a bit once I put the tail light assembly on which holds the license plate.  It looked like it might be a bit close.  However, I hopped up and down with everything I had to compress the rear end and the plate never gets closer than 2" inches to the rear tire.  Add in that I have the shocks at their lowest setting so when I adjust them to raise the back end some I will gain a little more clearance.  This is without a doubt the smoothest rolling bike I have.  When pushing it around it feels like it just floats.
However, I ran into a huge issue yesterday.  I started hooking up all of the wiring yesterday and adapting the controls I am going to use to attach to the stock wiring.  I was mostly done when I came to a show stopper.  When I dropped in the battery I noticed the problem.  I can't get the seat on with the battery in.  The bracket I welded in to anchor the front of the seat sits just in front of the battery.  With the battery installed I need about an inch of clearance for the seat to be able to slide in.  After a lot of thought I think I can get a smaller than stock size battery.  I currently have a Scorpion YT12C (180cca, 12a/h).  I looked at the lithium batteries, but great googly moogly are they expensive.  So I started looking for a smaller dimensioned AGM battery.  I found a Scorpion YT9C (130cca, 9 a/h) that should give me 1/16" of clearance at the top.  I will have to cut off the upper front piece of the battery box so that I can attach the ground wire to the battery, but I can live with that.  I will be running an LED headlight that uses 19 amps less than the stocker, no turn signals, and all other lighting is LED so I think I should be good with the a/h rating.
The icing on the cake yesterday was that none of the wiring works.  I have power at the connector in the headlight bucket, but nothing turns on.  Not a light, horn...nothing.  So I think I have a ground issue somewhere.
« Last Edit: March 27, 2017, 04:55:17 AM by Harsh »
Offline Harsh
« Reply #329 on: March 27, 2017, 05:18:04 AM »
Yah I know.  I just need to go back through everything and see what/where it is missing.  I am just starting to feel the pressure of getting it done so I can take it with me to Deal's Gap the first week in June.
Offline Harsh
« Reply #330 on: March 27, 2017, 01:19:18 PM »
One step closer.  Found a ground that wasn't connected.  Only one tiny light came on though so it looks like I still have some work ahead of me.  I think I am going to disconnect everything and hook them up one at a time to see what is going on.  I have a feeling something in the right control pod isn't correct.
Offline 540nova
« Reply #331 on: March 27, 2017, 03:38:10 PM »
If you do not go the rivnut way, just grind away some paint around your ground and slather liberally with conductive grease.
Offline Harsh
« Reply #332 on: March 27, 2017, 04:57:15 PM »
Yah I got the remove the paint stuff.  My issue was I didn't connect the ground wire that runs from the center of the frame to the headlight bucket.
Decided to disconnect everything and go through the complete hook up again vice one part at a time.  Finding the missing ground had a lot to do with the decision.  This time the headlight came on and so did the speedo gauge light, but that was it.  Noticed a couple of wires (brown and brown with a white tracer) that weren't hooked up.  The brown needs a jumper to power to turn on the tail light.  The brown with white tracer needs a jumper to power to turn on the tach gauge light.
A quick thumb of the starter button only caused the headlight to dim.
« Reply #333 on: March 27, 2017, 09:43:19 PM »
Bench test the solenoid with a 12V battery.  The C70 Passport (70CC step-through Honda MC) has instructions on disassembly, clean, and reassembly and they never have a problem again. Often bench testing or operating the solenoid can get them working properly after having sat for a while.
Have you looked at your ignition switch to test the black coming out of the switch to see your battery voltage is not dropping more than an acceptable amount through the switch? They can be a pita.
Have you disassembled and serviced the controls yet?  (Disassemble in a large clear plastic bag  that is taped closed around your wrists... It can save you searching and never finding a spring or tiny ball bearing used by the switch. )
You almost need a large plastic box like a blast cabinet to catch parts like this...with a set of gloves that give you a little tactile feel or you could have cloth sleeves on the container that you tape to a pair of latex disposable gloves you slipped on or cut the fingers off after putting on or before putting on.   Or just a good set of elastic cuffs on the cloth sleeves to allow you to have full dexterity with your hands.
I saw a small paint booth or blast booth made from a large plastic storage container where they put a clear glass window in it with a light installed to light the mini "cabinet".
You could fab up something like this.  Put it on a tilt so any small parts tend to end up in the bottom corner and you can see through the window easier.  The openings for your gloves or cloth sleeves to allow your arms to work inside the container without a lot of difficulty . This can mean using a bigger container than you would think, or larger openings to allow your arms to handle more positions.
For mini blast cabinets you install filtered air openings and fans to move air through the cabinet to clear the dust that accumulates blocking your vision.  For the mini blast cabinets you also need to accommodate replacement clear panels, sometimes a sheet of glass is better than plastic because of static electricity.
With your compressor setup  you can run a full sized blast cabinet non stop.  That is something to envy by many.
Good luck sorting electrical mess out, just like troubleshooting stuff in the Navy, one step at a time and you will isolate it to the problem.  Spot blasters are really nice for fixing nicks and scratches for auto body stuff (it is tough to make those repairs blended in but cutting the problem back to bare metal on deep scratches back to the metal.)  That would work great for blasting away the powder coat for your grounds. Also, your motor mount bolts will form a ground path for your motor.
Doesn't dielectric grease block air and prevent corrosion but allow the electrical connection to be made where it squeezes out the dielectric grease or wipes away the grease on a electrical disconnect.
David
Offline Harsh
« Reply #334 on: March 28, 2017, 05:09:57 AM »
Testing the solenoid, starter motor, and ignition switch are on today agenda.  I will look up that link today and see what it shows about taking it apart.
I am not running stock controls.  I have a set from a GSXR.  I may try and get a set from a Triumph Daytona like I have on my CB750.  They seem to have less wires and take up less real estate on the bars.
My grounds are now good.
That is pretty much the premise behind dielectric grease.
« Last Edit: March 28, 2017, 05:13:44 AM by Harsh »
Offline Harsh
« Reply #335 on: March 28, 2017, 03:06:15 PM »
Well it couldn't be something easy.
With the ignition switch off and the run switch off a subsequent shorting of the solenoid turns the starter motor. Not good.
The switched power wire (black) at the solenoid gets power when the ignition switch is turned on.
With the solenoid disconnected and the black and yellow/red hooked up to a battery the solenoid clicks what I feel is pretty strongly.
I am going to say that the solenoid it good and that I missed wired something when adapting the GSXR controls.
I think it has something to do with yellow/red wire in the bike.  In stock form that completes a ground when the starter button is depressed.  I am almost positive the GSXR controls use the starter button to route power and not a ground.
Jumpered the yellow/red at the headlight bucket to ground.  As soon as the ignition switch is turned to on the bike tries to crank.  Which simulated the stock starter button being depressed.
Not sure what else to try other than trying to get a set of Triumph controls since I was able to get those to work on the 750 with virtually no issues.  Plus they aren't nearly as bulky so they would look better.
« Reply #336 on: March 28, 2017, 09:59:39 PM »
At least you don't have magic smoke wafting about...that can get expensive.
David
Offline Harsh
« Reply #337 on: March 31, 2017, 06:06:39 AM »
The problem with the GSXR controls is that they jumper the incoming power to a number of the connection points internally of the housing.  I have tried everything except opening up the controls and cutting wires to get them to work.  So I have decided to ditch the GSXR controls and put on some from a Triumph.  I figure I can follow the wiring connections I did on my bike and it should work.  If not I am not sure what I will do.  I just have to order more bullet connector pins since I used most of mine on the GSXR wires.
The new clutch and throttle cables arrived and they look pretty good.  The clutch cable was billed as being 1" shorter than stock.  However, it is the same exact length as my stock cable.  I think I have to either modify or get a new throttle housing.  There is a lip on the inside that prevents it from closing completely around the bar.  The bar is your standard 7/8" and that is what the throttle housing is supposed to be for.  Completely over torqued there is still a gap on each side of the housing.
All I know is that I am ready to get this thing fired up.  It is driving me crazy just having it sit there.
I am having a hell of a time trying to match the color of the powder coat to a color in paint so I can print out the tank emblem/figure.  As soon as I get the color matched I can give the parts to the painter.  If I can't get the color to match I guess I will have to get him to paint it, which will cost a bit more.
Offline 540nova
« Reply #338 on: March 31, 2017, 06:46:53 AM »
Harsh, I may be interested in the GSXR controls if you want to sell them.
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #339 on: March 31, 2017, 07:32:07 AM »
That bike is looking great.  Really like how well the comstars look on it.  Being a painter myself.  That color would be a breeze to match.  Start with white, add Iron Oxide, and some yellow.  Small amounts until you get it.  Maybe a few drops of trans black.  But any painter with a mixing bank should be able to get that with in a half hour time.
Offline Harsh
« Reply #340 on: March 31, 2017, 07:40:28 AM »
We can probably work something out nova.
The paint I am referring to is the program.  I print my decals on waterslide paper.
Offline 540nova
« Reply #341 on: March 31, 2017, 08:38:55 AM »
PM sent
Offline Restoration Fan
  • My wife will never call me
« Reply #342 on: March 31, 2017, 12:52:20 PM »
TIL something new.  I had no idea such wizardry actually existed.
Offline Harsh
« Reply #343 on: March 31, 2017, 01:57:09 PM »
Yep, I used it for the girls on the side covers when I built the 750.  The only crappy part about using it is you have to cut out whatever picture or design you print.  The benefit is that it is extremely thin so it doesn't get the raised edges vinyl does when you clear over it.  You are only limited to the colors your printer can produce.
« Reply #344 on: April 01, 2017, 04:12:49 AM »
Maybe you need to consider a different program that can do the paint color from a scan codes obtained for mixing from the local auto paint place or home improvement center. The pantone number or RGB values....
I have Corel Draw X3...
Are you using clear or white decal paper?
David
Offline Harsh
« Reply #345 on: April 01, 2017, 04:58:08 AM »
All I have is ms paint and paint.net.  I have about zero artistic capabilities so there has never been a need to purchase a better program.  However, I do like the idea of getting the color scanned.  When I had everything powder coated I had an extra flat piece done to make it easier for me in the house to match the color.  I am going to take it up to the paint Store and see if the will scan it for me.
I use the white backed paper.  Printers don't print white and whatever background color you apply them over will show through when using the clear.
Offline Harsh
« Reply #346 on: April 01, 2017, 05:24:42 AM »
True, but it might get me closer than I have been moving the mouse around in the color wheel.
Offline Harsh
« Reply #347 on: April 01, 2017, 10:15:23 AM »
Managed to get the color matched.  I happened to be at Lowes this morning so I had them scan it.  That didn't do anything for me.  So I started comparing paint chips.  I found one that was really close.  A Google search for the RGB numbers was next.  Got those and plugged them into ms paint.  15 adjustments later I have it damn near spot on.  Since it will not be touching anything that is powder coated the extremely slight difference in color won't be noticed.
Thanks David for the suggestion.
Offline Harsh
« Reply #348 on: April 01, 2017, 01:24:52 PM »
Well, like has been the case lately as soon as I order something I either find the piece I was missing or I figure it out.  Upon the suggestion on another forum I as able to get the controls to work.  The suggestion was to take the black wire (switched power) on the solenoid and book it to a ground vice power then hook up the red/yellow wire like I had been.  Sure enough the bike turns over when the starter button is depressed.
So that is working.  Unfortunately, I bought a set of Triumph Daytona 675 controls off of eBay this morning.  If only I had read the suggestion prior to the purchase I could have saved $45.
Offline Harsh
« Reply #349 on: April 03, 2017, 07:29:29 AM »
Managed to get the color matched for the tank graphic.  I happened to be at Lowes this morning so I had them scan the extra flat piece I had powder coated.  That didn't do anything for me.  So I started comparing paint chips.  I found one that was really close.  A Google search for the RGB numbers for the paint chip was next.  Got those and plugged them into ms paint.  15 adjustments later I have it damn near spot on.  Since it will not be touching anything that is powder coated the extremely slight difference in color won't be noticed.  I must have looked like a goober when checking the color.  I laid the printed piece on my walkway with the powder coated piece on top and walked around to get different views at different angles and light/shade.  I got a few strange looks from people driving by.
And the horn doesn't work.  Finally remembered to give it a try on the bike.  When I had it out of the bike I remember hooking it up to the battery and all it would do is make a scratching noise.  When I pulled it out of the bike it was hot so there is definitely something wrong with it.
Took the dremel with a drum sanding bit and opened up the throttle tube housing.  It was almost 2mm too small and would not close all of the way.  Once that was done I was able to hook up the throttle cable and adjust it to get the carbs to open at the same time.  Got the clutch cable on and adjusted.  Air filters on and secured.  Headlight switch mounted in the triple.  I think it looks pretty good.  I was able to find a latching switch that had a cream colored top.  Rear sprocket is being made and I will order the front sprocket and chain tomorrow.
I ordered some more water slide decal paper so as soon as that gets here I will be making the call to my painter.
Well it appears I am the killer of the horn.  I was looking for a replacement when I noticed this:
Note: Adjusting or removing the nut that holds the horn to the bracket or the small set screw on the back will prevent the horn from working properly.
I had removed the nut that holds the horn to the bracket so I could direct mount it.  I guess I won't be making that mistake with the new one.
