Author Topic: unknown (for me) electric part  (Read 4009 times)
Offline grisu
« on: December 07, 2015, 02:18:51 AM »
Hi,
I am finishing the bike. Now I "only" need to fix the electrics but I have a problem. I have a piece that I don´t have idea what is it for and how connect it.
is this one
Offline Tews19
  • I am no
Re: unknown (for me) electric part
« Reply #1 on: December 07, 2015, 05:31:15 AM »
Turn signal relay?
1970 Honda CB750 survivor.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: December 07, 2015, 06:21:47 AM »
OMG! That's the flux capacitor! Don't drop it!  :o
AKA the turn signal beeper...  ;)
Typically mounts inside the left fork ear behind the headlight. "Beeps" when the turn signal is on. Mine was non functional and was eliminated a long time ago.
I'm not so sure now...
« Last Edit: December 07, 2015, 08:21:04 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline carnivorous chicken
« Reply #3 on: December 07, 2015, 06:57:01 AM »
Yep. I remove them first thing on a new (to me) 550. Annoying as hell and completely unnecessary IMHO. others like em. Either way, up to you.
« Reply #4 on: December 07, 2015, 07:11:54 AM »
It mounts to the left headlight ear....
Offline grisu
« Reply #5 on: December 07, 2015, 07:17:31 AM »
Then it´s not necessary.
Thanks one more time :)
« Reply #6 on: December 07, 2015, 07:23:02 AM »
I'm not real familiar with the smaller bikes, primarily just the 750's, but the buzzers I am familiar with only have two wires while yours has four. Maybe a 550 guru can chime in?
TAMTF...
Wilbur
Projects:
Offline mrfish2
  • I might be a
« Reply #7 on: December 07, 2015, 07:51:02 AM »
That's not a turn signal beeper. If it was then it would look like a tiny speaker, and as madmtnmotors said it would only have 2 wires instead of 4.
This is a buzzer:
« Last Edit: December 07, 2015, 07:53:30 AM by mrfish2 »
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #8 on: December 07, 2015, 08:20:19 AM »
This is a buzzer:
The rubber mount on the one that grisu posted is different too. What the heck is that?  ???
I'll have to retract my earlier observation...   :o
TAMTF...
Wilbur
Projects:
« Reply #9 on: December 07, 2015, 08:48:00 AM »
Aftermarket Starter Solenoid. Stock solenoid mounting rubber. I'm getting ashamed of some of you all!
Hey, in our defense it does appear to be "non stock". It was a trick question!  ;)
TAMTF...
Wilbur
Projects:
Offline grisu
« Reply #10 on: December 07, 2015, 11:11:41 AM »
 :o
Thanks calj737
Offline grisu
« Reply #11 on: December 07, 2015, 11:20:08 AM »
but...I thing this is not a starter solenoid
« Reply #12 on: December 07, 2015, 12:07:04 PM »
That is definitely an odd item. The casing looks like some sort of relay or solenoid, and the bullet connectors look like factory connectors...
maybe from a completely different motorcycle? Anyone ever seen a turn signal relay with a "pigtail"?
Is there any markings on the casing at all?
TAMTF...
Wilbur
Projects:
« Reply #13 on: December 07, 2015, 12:21:06 PM »
I vote for fetzer valve bypass line.  I'm going to need some pliers and a set of 30-weight ball bearings.  It's all ball bearings now days!
« Reply #14 on: December 07, 2015, 12:22:51 PM »
I'm still sticking with solenoid, but from a non-CB. Notice the wire colors: GRN, RED, BLK, R/BLK? Those are almost exactly the same for late model 550s. Now I grant you, the absence of the "studs" is concerning, but given the OP provided ZERO detail on his bike, I'm still going with my gut. (Kind of have to really, it precedes me by several steps anywhere I go...)
The absence of the "studs" seems to rule out starter solenoid, since the wire gauges don't look like they would support the amperage of the starter draw. Maybe a relay for the headlight circuit? If a halogen or HID headlight bulb were used it might have been an effort to take the load off the switches...
Bust out the ohmmeter and start testing continuity across connections.
TAMTF...
Wilbur
Projects:
Offline hsas.69
« Reply #15 on: December 07, 2015, 04:25:13 PM »
Flasher relay. Doesn't seem robust enough for starter solenoid
Sent from my SM-N900P using Tapatalk
78 CB750 F3
78 CB550 K4
« Reply #16 on: December 07, 2015, 06:35:10 PM »
+1, and it is from another kind of bike than Honda...check op's coils out, not from an sohc4 either...Grisu, you sir, appear to have a Frankenbike
Offline hsas.69
« Reply #17 on: December 07, 2015, 06:38:00 PM »
I have seem some coils for sale like that labeled for the cb's. But im pretty sure they're more or less a universal 5ish ohm coil that will fit/work on many era jap bikes.
78 CB750 F3
78 CB550 K4
« Reply #18 on: December 08, 2015, 09:31:25 AM »
Guilty as charged -- shoulda looked closer.
Offline grisu
« Reply #19 on: December 08, 2015, 12:14:12 PM »
The colors are
black
orange
strong red
brown-red
This week I will go to a electric specialist...I will tell you but THANKS for your help.
The bike
Online CycleRanger
  • No comment about being an
« Reply #20 on: December 08, 2015, 06:13:14 PM »
Colors look like black, green, red, and brown in photos.
« Reply #21 on: December 09, 2015, 04:06:51 AM »
OMG...
I hope you are not the one using all those "dime store" electrical connectors. Quite the mish mash of el-cheapo crimped end connectors, butt splices, and even those hideous "pinch" type splice taps. These are all rarely dependable, often loose, and corrode quickly. You can do it right once, or be chasing gremlins for a long time.
I see a package of double crimp connectors there on the floor, I highly recommend the proper crimp tool. They also have male and female spade connectors too, if you are replacing the marginal connections, I would replace all of the cheap connectors.
Here is a copy of my post from another thread, ironically titled "Electrical Connectors":
Strip it. I usually strip about a 1/4" to 5/16". Three-eights is a bit much and not necessary:
Don't forget the insulator! (ask me how I know):
I finally figured out (after about three tries) that it's easier to load the connector in the crimp tool first. Note the stepped jaw. The trailing end has a higher relief so as not to over crimp the insulation:
Ratchet down on it just enough to hold it:
You only need about a 1/4" of insulation extended into the connector. Too much and you get into the part of the crimp that should be catching wire only. The jaws are pretty wide and hard to see inside, so I use my thumbnail as a guide when inserting the wire:
Crimp it!:
Voila' (as opposed to "Viola" which everyone knows is a musical instrument):
And finally, the insulator:
Procedure is the same for other types of connectors, just be sure to use the right insulator. Here we have the insulator for the female bullet:
Load the tool:
Crimp it... crimp it real good... and voila'! (as opposed to "viola" which everyone knows is a musical instrument):
Slide the insulator into place:
Dang! This is how they must of looked when the bike was new!:
Give the wire a tug when you're done. Occasionally I will get a loose crimp, but most of the time it is a result of smaller gauge wire. In those cases I will strip 1/2" of insulation and double the wire back on itself to mimic a heavier gauge wire. These are my go-to connectors for all things automotive.  8)
When done properly, these crimps are "gas tight" and are highly resistant to corrosion at the crimp. Provided you don't submerse them in saltwater (or acid!) regularly, should last another forty years.
« Last Edit: December 09, 2015, 04:14:50 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
