Author Topic: Remove throttle push cable  (Read 4916 times)
Offline jebon
« on: July 26, 2016, 07:18:37 AM »
Hi!
I'm changing the throttle cables after replacing my handlebars.
Can't figure out how to remove the throttle push cable from the controls.
Seems it should go up through the controls but how?
"Don't let schooling interfere with your education"
CB750 K0 1971
Offline TomsK8resto
Re: Remove throttle push cable
« Reply #1 on: July 26, 2016, 08:13:29 AM »
Have you removed the nut on the bottom of the control housing where the 90* tube enters the housing?
Tom
'69 CB750 long gone
'76 CB750F gone
'78 CB750K in progress.....
'09 H-D Roadglide
Offline Steve_K
« Reply #2 on: July 26, 2016, 08:14:12 AM »
Should be a nut or knurled ring which you should be able to loosen to remove it. (on the cable side)
You have turn the cable to unscrew it.
Steve
Steve_K
Offline jebon
« Reply #3 on: July 26, 2016, 08:14:43 AM »
Tom
Yes
CB750 K0 1971
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #4 on: July 26, 2016, 08:18:27 AM »
The whole 90deg pipe unscrews
--Evan
1975 CB750K "Rhonda"
Offline jebon
« Reply #5 on: July 26, 2016, 08:37:25 AM »
This is the push one without the threads. It's the 90 degree pipe I can't get off.
It seems I should be able to just pull it out but when I look up in the hole where the pipe is attached and turn the pipe, the area around the pipe doesn't rotate. Pretty odd.
CB750 K0 1971
« Reply #6 on: July 26, 2016, 09:23:07 AM »
^^^+1
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: July 26, 2016, 09:27:10 AM »
The elbow must be removed from the housing. One elbow pushes in and is captured with a nut. The other elbow threads into the housing itself and is locked in place with a jam nut. You're not doing something right.
Post a picture of the underside of the housing in its current state.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline jebon
« Reply #8 on: July 26, 2016, 10:10:25 AM »
CB750 K0 1971
« Reply #9 on: July 26, 2016, 11:29:58 AM »
What happens when you rotate the elbow counter clockwise (looking from below) ten or twelve turns?
TAMTF...
Wilbur
Projects:
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #10 on: July 26, 2016, 11:40:39 AM »
If he is going to loosen it, wouldn't it be counter-clockwise? Don't want him to snap it off :) That cable has a lock nut that looks like it was removed? Just twist the elbow back and forth until it loosens up. Might just be stuck as 40 year old stuff tends to be.
« Last Edit: July 26, 2016, 11:44:15 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #11 on: July 26, 2016, 11:43:49 AM »
What's the difference between "counter clockwise" and "counter-clockwise" besides the dash?  ???  ;)
TAMTF...
Wilbur
Projects:
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #12 on: July 26, 2016, 11:45:16 AM »
Just the dash! Sorry reading without glasses over the age of 50 can be hazardous to my health.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #13 on: July 26, 2016, 11:47:09 AM »
LOL! Yep, I am there and do that!  8)
TAMTF...
Wilbur
Projects:
Offline jebon
« Reply #14 on: July 26, 2016, 01:41:53 PM »
The elbow doesn't have threads
CB750 K0 1971
« Reply #15 on: July 26, 2016, 02:01:43 PM »
did you rotate it?  does it not rotate?
There is no other way to get that end installed without turning the elbow out of its hole.
Offline przjohn
« Reply #16 on: July 26, 2016, 02:50:48 PM »
LOL Sometimes it's tough for us, "Experienced" Guys.  8)
Offline jebon
« Reply #17 on: July 26, 2016, 03:16:14 PM »
After wiggling and wiggling it came out and I got the new one in. Any comments on my cable routing? I guess I could go between the headlight and clocks and also the return cable could maybe be lifted and enter the carbs from a little higher. Do you know the low bars factory routing?  The old cables with the higher bars went on the right of the frame but these shorter cables are too long for that
CB750 K0 1971
« Reply #18 on: July 26, 2016, 03:20:29 PM »
What holds it in? Does that one have the threaded collar/nut to hold it in place? Surely it's not just a "press fit"?
I know, I know, "Don't call me Shirley"!  :o  ;)  ;D
Cable routing looks similar to mine, except that mine roll down and under the fuel tank on the right instead of the left. The most important thing is that as you swing the bars from stop to stop left and right that the cables don't bind and they don't snag anything.  8)
« Last Edit: July 26, 2016, 03:23:22 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline jebon
« Reply #19 on: July 26, 2016, 03:38:15 PM »
The reason it seemed odd was that the collar on the elbow was loose and didn't turn with the elbow. That made me think that it was fastened with a circlip or something.
CB750 K0 1971
