Author Topic: K8 Highway Racer - Finished  (Read 30263 times)
Offline JoeCooley
  • Long time lurker, but now I'm a
« on: November 22, 2016, 02:11:59 AM »
Hello all! I'm a long time lurker and admirer of the sohc4. Decided to join and share my project after I finally took the dive and got my own.
So here it is! My newly purchased cb750 K8. It's had extensive work performed on it by the previous owner(s).
 I drove all the way to Irvine, CA after numerous texts and calls with the owner. It was in a bad running condition when I arrived to check it out but, I was already in love and committed to the bike. So I loaded it into the truck and hauled it back to San Diego.
The day I brought it home.
Here's the CL ad for some background info. I got it for a little less than the asking price.
It took quite a bit of cleaning and tuning but I've finally got the CR Special carbs running decently. There is still a small stumble in the mid range at certain load/rpm. I think it may the the 55 slow jets or a throttle cutaway change.
Look at those clean intakes ports!
DynaS ignition
My trick for a less messy oil change.
How the bike sits now with a new koso speedo/tach, clip on raised, add signals, led tail light, and cleaned.
My current stable of vehicles. 74 Jensen-Healey, K8, & 02 WRX Wagon (DD). Too may projects...
« Last Edit: January 07, 2020, 10:19:36 AM by JoeCooley »
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: My 78K Cafe
« Reply #1 on: November 22, 2016, 04:37:02 AM »
As long as you enjoy it and can ride it safely what's not to like? Good score on the CR carbs. As long as the other modifications don't create any unsafe conditions I'd say you did pretty well since the West coast prices tend to run a little higher than "back East". The funnel under the oil tank for draining is the same method I use. I also cut up a beer carton to use as a "diverter" underneath the oil filter housing to help keep oil off the pipes. It doesn't always work 100%, but sometimes it does!
Welcome aboard!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: My 78K Cafe
« Reply #2 on: November 22, 2016, 06:03:52 AM »
If you're running a 170 rear tire, likely there's offset sprockets front and rear. It would be advisable to pull the shift cover and inspect the cases in that area to insure there's no chain/case conflict or damage occurring. Too many folks install O-ring chains and they're too wide on the front sprocket which causes the chain to eat a hole in the case.
Holy cow, good eye. The high res pictures help a lot. Looks like a custom rear brake stay arm with a "dogleg" to clear the wheel. Well, mostly clear, since it looks like the scuffing on the tread aligns with the brake stay arm (or the inside of the swingarm).
Is the back side of that brake stay arm polished up shiny where it used to be painted at it's closest point to the rear wheel?  ???
« Last Edit: November 22, 2016, 06:06:38 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline JoeCooley
Re: My 78K Cafe
« Reply #3 on: November 22, 2016, 10:27:19 AM »
The bike is stable at speeds and rides quite well. It handles turns and stops very easily. The suspension geometry doesn't seem to be anything unsafe with all the part swapping. Thanks for the comments guys. I think I got a pretty good deal for all the work/time/money that has been put into it.
The bike does have offset sprockets. I haven't counted the teeth yet to see the ratio. The small sprocket cover has been drilled and clearance for the chain. I will have to pull it off to see make sure the chain isn't rubbing the case. I have a spare and need to replace it anyway. The PO did a pretty bad job of "clearancing" it with what I guess was a grinder.
No dog leg on the brake stay. It is curved a little to clear the tire. Not sure if that is factory or a modification.
The exhaust pipes are in pretty bad shape. They are leaking at the slip joints and many pin-holes that leak. The muffler baffles don't do much for sound reduction and the bike is quite loud. I will be replacing them with a MAC 4-1 canister setup soon. Just bought one used on ebay. Hopefully it shows up soon and fits the bike.
Eventually I'd like to weld in a frame hoop and put a brat seat on it. I really like the DimeCity seats with the flip up on the end. I just have to save my pennies because the are pricey.
Re: My 78K Cafe
« Reply #4 on: November 22, 2016, 10:38:34 AM »
The "curve" is the "dogleg" that I refer to. The stay arm should be straight due to the dynamics of the forces involved under braking. Under hard braking the rear brake panel is going to be pulling hard on that stay arm and the resulting effect is the forces exerted on the stay arm will be trying to pull it back out straight. This stay arm could easily deflect under hard braking and be rubbing the rear tire under braking. Any evidence of the tire touching the inside of the stay arm? (i.e. paint rubbed off the backside of the stay arm where it is closest to the tire?)
TAMTF...
Wilbur
Projects:
Offline JoeCooley
Re: My 78K Cafe
« Reply #5 on: November 22, 2016, 11:33:37 AM »
Oh I understand now. I was thinking something different. I will have to check it after work. I'll report my findings.
On another note: I received my mac 4-1 today. I love when parts show up! It's like Christmas! Haha
Re: My 78K Cafe
« Reply #6 on: November 22, 2016, 12:01:17 PM »
Indeed!  8)
TAMTF...
Wilbur
Projects:
Re: My 78K Cafe
« Reply #7 on: November 22, 2016, 02:32:38 PM »
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
Re: My 78K Cafe
« Reply #8 on: November 22, 2016, 04:18:58 PM »
Nice score, I recall seeing this on the OC CL. It looked like a good bike in the ad when I saw it last. Does the head have port work done on it? It does look really clean in there. Cheers! Rick.
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline JoeCooley
Re: My 78K Cafe
« Reply #9 on: November 27, 2016, 10:23:51 PM »
Not sure on the port work. It does look really clean in there....
Small update:
Got around to installing the MAC 4-1 I got off eBay. The pipes were previously installed on a dohc bike. So a few changes were in order.
As you can see, there are major differences in the early and late exhaust clamps. I picked up a set of 77-78 clamps fromy a local moto junk yard along with some new gaskets.
Late sohc left, dohc right
How they fit. Don't mind the small dent in the muffler. It'll be replaced with a reverse cone from coneng.com and angle up a bit more to tuck a little better. It sounds good and isn't nearly as loud as the 4-4 that was on the bike.
I also have some old school Honda tank badges that I'm thinking of using. Not sure where to mount them. I have a couple options. These will be nice to break up the black & polished look and throw a little bit of color into the mix.
Overall happy with the bike. I have a quick video I'll post up also.
Offline JoeCooley
Re: My 78K Cafe
« Reply #10 on: November 28, 2016, 11:05:42 AM »
You might want to invest in a pair of rear sets for your bike. With the front end changes, you will likely find the footage changes more comfortable and better suited for your riding posture.
I agree. Rear sets are in the near future. Any recommendations for an economic bolt on kit? It's really not that bad riding posture the way it is currently.
Offline JoeCooley
Re: My 78K Cafe
« Reply #11 on: November 28, 2016, 09:04:03 PM »
Offline rickmoore24
  • I <3 SOHC4's
    • Rosenbard Films
Re: My 78K Cafe
« Reply #12 on: November 28, 2016, 09:32:25 PM »
I don't know about economical but....
http://www.fastfromthepast.com/rearsets/honda
1995 EG6
Re: My 78K Cafe
« Reply #13 on: November 28, 2016, 10:01:17 PM »
 What are you doing with the old pipes ?
Offline JoeCooley
Re: My 78K Cafe
« Reply #14 on: November 28, 2016, 10:52:16 PM »
Not sure. Probably just put them in storage for a future project. The head pipes and spigots are in great shape but the other half with the mufflers welded on are in bad shape. Leaking welds and shifty craftsmanship went into making them. I might use them to build a nice 4-2 setup.
Offline JoeCooley
Re: My 78K Cafe
« Reply #15 on: December 03, 2016, 10:06:11 PM »
Took the bike for a 50mile ride today and met up with my gf for dinner. This is my first real ride with the new exhaust. I love the new sound of the 4-1 Mac setup. Loud enough to sound sporty but not obnoxiously loud and making my ears ring. Super happy with my eBay purchase.
She snapped a quick action shot...
Offline JoeCooley
Re: My 78K Cafe
« Reply #16 on: December 04, 2016, 08:53:13 AM »
So maybe you guys can help me. I've installed a Koso TNT tach/speedo gauge. The tach is very jumpy. I've seen people build tach filters for this tach with other bikes but nothing CB750K specific. Does anyone have any info to fix this tach problem?
Here's a quick video.
« Last Edit: December 04, 2016, 08:58:35 AM by JoeCooley »
Offline rickmoore24
  • I <3 SOHC4's
    • Rosenbard Films
Re: My 78K Cafe
« Reply #17 on: December 04, 2016, 10:23:34 AM »
Check the ground and all connections, if they are good you can install a resistor but I'm not sure what size. Half watt maybe?? Inline of the tack signal of course.  :)
*edit: this will smooth out the signal.
« Last Edit: December 04, 2016, 10:25:22 AM by rickmoore24 »
1995 EG6
Offline JoeCooley
Re: My 78K Cafe
« Reply #18 on: December 04, 2016, 02:45:25 PM »
I didn't use the plug wire method. I tapped into the coil positive lead  (blue wire). The instructions had both methods.
Offline JoeCooley
Re: My 78K Cafe
« Reply #19 on: December 05, 2016, 04:21:23 PM »
Isn't the Blue wire a negative? The BLK/WHT should be positive.
Yes you are correct. I didn't realize that but just looked at the diagram again. The tach can be set to either coil positive or negative. I currently have it set for positive but have switched the tach to negative coil input and the tach reading was way off. I will try tapping into the black/white wire and see if it make a difference. Thanks for the input.
Offline JoeCooley
Re: My 78K Cafe
« Reply #20 on: January 16, 2017, 02:06:28 PM »
Ok so time for an update. I picked up more parts for my bike. "My name is Joe and I have an addiction..."
So I was searching CL and found a great deal for a running K2 836, extra set of cast 836 pistons, and a flat brat seat.
[IMG]https://imageshack.com/i/pnz01RS7j[/img
[IMG]https://imageshack.com/i/po2Ia7Ddj[/img
The "836" is kinda unknown. It is supposed to have a hi-po cam in it. I'm going to tear it down and see if it really is an 836 w/ upgraded cam. If not, I have a piston kit. It does need some love tho. The po used red rtv on everything, including the headgasket.  >:(
So yeah, it's leaking oil from a couple places. I'm going to get a full gasket kit from cycleX and replace most gaskets. Not sure if I will split the cases. They don't appear to be leaking.
The seat will be used later but will require some fab work. The engine came with some chrome and finned covers. The stator and clutch covers are near perfect and already made it onto my bike. The points cover is damaged and needs a little work but I think I can fix it.
[IMG]https://imageshack.com/i/pmNpbBLEj[/img
[IMG]https://imageshack.com/i/plv1sMTMj[/img
« Last Edit: August 23, 2019, 01:11:03 AM by JoeCooley »
Offline JoeCooley
Re: My 78K Cafe
« Reply #21 on: January 16, 2017, 02:23:43 PM »
If this is an 836, can I use the cylinders and head on my k8 cases? That way I don't have to worry with the sprockets not lining up. Ive read that the early k engines had the front sprocket 10mm further inward and I don't think I can make things line up with my bike due to the large rear tire and offset sprockets required.
Offline JoeCooley
Re: 78K Cafe - Engine build
« Reply #22 on: January 16, 2017, 03:59:14 PM »
Started tearing into it. So far I've found a couple curious things.
Three different bolts and nut that don't seem Honda. They are all also 11mm head.
And a missing bolt under the #1
Hmm... let's see what I find.
« Last Edit: January 16, 2017, 10:20:34 PM by JoeCooley »
Offline JoeCooley
« Reply #23 on: January 16, 2017, 10:01:09 PM »
Well I dug deeper into this "hot cam 836" and guess what? It's not an 836 at all. But no fear, I have a set of 65mm pistons and will just have the cylinders bored.
Also the cam appears stock k2 from what I can tell by looking at other stock cams? Maybe someone can look at it and surprise me with good news?
The head appears to have some polishing in the chambers but it's pretty crude. It also looks like the intake valves have kissed the pistons. So they are probably bent. I will rework it with a little port work, new cycleX valves and springs, and a good Polish in the chambers. Good for a couple hp.
I'll keep you guys updated with the progress.
« Last Edit: January 16, 2017, 10:14:27 PM by JoeCooley »
Re: 78K Cafe - Engine Build Time!
« Reply #24 on: January 17, 2017, 03:55:41 AM »
Those bolt heads are not "11mm" but are 7/16" and are SAE grade 5. Quite the abomination you got there....
TAMTF...
Wilbur
Projects:
