Author Topic: oil gallery bung  (Read 1689 times)
Offline kezz32
oil gallery bung
« on: January 11, 2017, 01:14:27 PM »
I have managed to lose the oil gallery bung that is fitted to the transmission side oil gallery just below and forward from the main shaft oil gallery , are they available, or what makes a suitable replacement .
thanks Kerry (uk)
Re: oil gallery bung
« Reply #1 on: January 11, 2017, 03:48:23 PM »
What bike?
Offline disco
« Reply #2 on: January 12, 2017, 01:57:37 AM »
If for a 750, it looks like this. No longer available, but wouldn't be difficult to make from silicon. It measures approximately 5mm deep into the hole. It's 10mm (dia)x 1mm then steps down to 9mm (dia) x 4mm.
I think you definitely need this gallery plug. Hondaman talks about the importance of renewing the little o-ring under the counter shaft bearing holder to maintain oil pressure to the clutch & transmission. I think you would be losing some oil pressure without this plug also.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline drumstyx
« Reply #3 on: January 12, 2017, 07:15:38 AM »
Can't help you with an OEM replacement, but I was definitely paranoid about this -- I've heard of people modifying rubber stoppers to work. The problem is it can only go a few mm in, because the gallery joins another right inside.
Offline kezz32
« Reply #4 on: January 12, 2017, 09:22:42 AM »
Thanks for the info Disco , gives me something to work with. I managed to fire it across w/shop with a puff of air ;D
sorry guys part is for a Honda cb750 sohc
Offline drumstyx
« Reply #5 on: January 12, 2017, 10:42:49 AM »
Excuse to clean the shop then I'd think...
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: January 12, 2017, 10:45:41 AM »
If it's anything like my shop then I might be inclined to buy a new bike instead!  :o  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #7 on: January 12, 2017, 11:33:41 AM »
That!  ;D ;D
Offline kezz32
« Reply #8 on: January 12, 2017, 01:54:52 PM »
w/shop actually pretty clean and tidy , its a very small part , I felt it ping off my shoulder and fly toward window , I have emptied tool box and roll cab but no joy , suppose gonna have to make new
Offline disco
« Reply #9 on: January 12, 2017, 03:16:56 PM »
If you've got a drill press it would be fairly simple to make a timber 'mold' using a couple of spade bits. Lightly grease, then just silicone away!
« Reply #10 on: January 12, 2017, 06:00:56 PM »
The rubber plug is redundant, as the shifter cover and gasket provide a positive seal. My K1 motor doesn't have the plug, nor my K7 motor.
Offline disco
« Reply #11 on: January 12, 2017, 08:01:00 PM »
The rubber bung first appears in the K6 parts fiche. Your K7 may not have it, but it is a listed part for the K7. I see your point Scottly, but I'm still going to leave it in.
« Reply #12 on: January 12, 2017, 08:33:34 PM »
Wait a week or two...we have motors stripped for parts..someone will have one..
Offline Kevin D
  • SE Michigan
« Reply #13 on: January 13, 2017, 04:58:19 AM »
Here is a couple pages of reading, some part numbers, photos, and a fair amount of disagreement from 2011. ;D
http://forums.sohc4.net/index.php/topic,99721.0.html
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #14 on: January 13, 2017, 06:34:09 AM »
searched again in vain for missing oil gallery bung  >:(
Make one.
Many suppliers of viton cord in the UK (google search)
check www.corseal.com.uk
Offline drumstyx
« Reply #15 on: January 13, 2017, 06:57:05 AM »
And fortunately, it's just under the shifter cover, so worst case one could try without it, and if it weeps some oil, deal with it later.
