Author Topic: Taking off your sprocket cover — WTF?!!!  (Read 3029 times)
Offline SKTP
« on: May 22, 2018, 10:47:12 AM »
Is it just me, or is taking off the sprocket cover harder than a Rubic's cube?
Sometimes I can take it off in seconds....last night i tried for half an hour then gave up!
What is the trick? SO FRUSTRATING (1978 CB750K)
I tried every possible angle with the bike on the center stand and turned the wheel in tiny increments to hopefully find the magic spot that allows it to come out...please help
I have done it before multiple times...but somethings............
« Last Edit: May 22, 2018, 10:52:58 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline BobR
Re: Taking off your sprocket cover — WTF?!!!
« Reply #1 on: May 22, 2018, 02:47:35 PM »
   Well I took mine off (K4) in a snap. A few weeks later (after some maintenance)  it did take me a bit to find the right angle to get it back on, lol!  I just reminded myself that it came off easily soooo it should go back on easily...ish...Bob
Reality is merely an illusion, albeit a very persistent one. Albert Einstein
 CB750K4(F2 engine)
Offline rotortiller
« Reply #2 on: May 22, 2018, 03:03:21 PM »
Couldn't have put it better LOL!
Offline SKTP
« Reply #3 on: May 22, 2018, 03:11:21 PM »
Ok...I feel slightly better knowing that I am not alone
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #4 on: May 22, 2018, 06:09:28 PM »
I think the 77/78 bikes are a little bit harder because of a slight change to accomodate the wider countershaft bearing, I can't quite remember why though, seems like there is a case bolt that just overlaps the top edge or something and it doesn't do it on the 76 and earlier.  You just have to pull it straight out until it clears the dowels and shift shaft but it is hard because until it comes loose a little there is nothing to grab onto.  No need to mess with the back wheel.
Offline gareyc
« Reply #5 on: May 22, 2018, 06:31:18 PM »
Don't feel bad; I pulled my motor last week and after about 30 minutes of trying to get the sprocket cover off I pulled harder in frustration and broke a piece off.
Offline johans
    • corporate leather
« Reply #6 on: May 22, 2018, 07:21:55 PM »
I recall on my 78 i actually "removed" some of the tab inside the cover to make the r&r a bit easier. i would post a pic but my son has the bike out of state.
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
« Reply #7 on: May 22, 2018, 09:52:49 PM »
 I know someone that actually ground part of the frame off on a 78 K.
 Myself I would cut the cover before cutting the frame.
 For some reason they can be real tricky and then sometimes, they just slide in or out..
« Reply #8 on: May 22, 2018, 09:57:15 PM »
The M8 bolt that keep cases together near the final shaft has a wide head that usually will be an obstacle. CB750K6, guess the later has same thing.
You have to swing the cover under it. The K2 cases has a thin M6 bolt here.
Offline brewsky
« Reply #9 on: May 23, 2018, 04:26:19 AM »
I have to wrangle with the wire harness to get enough clearance.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #10 on: May 23, 2018, 04:57:03 AM »
There is only one way. If I haven't done it in a while I have to "retrain" myself. Once the screws are removed I use the following steps:
>Slide the sprocket cover straight back towards the rear wheel. The rear of the cover will be behind the frame tube between one half to one inch
>Twist the front bottom of the cover outward and upward at the same time, kind of rolling the cover out from behind the frame at the rear of the cover
If you did it right the cover will be freed, often without even touching anything on its way out. Once I figured this out I was amazed at how easily it worked. From the shape of the cover and the adjacent frame makes it seem like the rear of the cover would come out first, or at least move outward at the same time as the front of the cover. It wasn't until I slid the cover to the rear and used the twist/rotate on the front edge of the cover that I discovered how easy it can be. I repeated this over a dozen times until I had committed the motion to memory. Reverse the procedure to install.  ;)
EZPZ!  8)
Edit: Oh, and this does seem to be more of an issue on the later models. I don't think the early models were quite so bad. I think Sean is right about the later models having the output shaft extended outward probably being the contributing factor.
« Last Edit: May 23, 2018, 05:16:49 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline SKTP
« Reply #11 on: May 23, 2018, 12:29:00 PM »
Thank you everyone...I will try again tonight
I have successfully done it multiple times in the past...such a strange design for removal
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline piefairy
« Reply #12 on: May 23, 2018, 07:18:20 PM »
I pulled mine the other day thinking that I lost the ball at the end of the neutral switch (dont ask).... It was sticky, but I used a putty knife and went around the back half of the casing slowly to get it free. It took me a bit to re-seat it though, it really is picky on where it wants to be.
Offline Erny
« Reply #13 on: May 23, 2018, 10:11:08 PM »
madmtnmotors, can't you try to make short video?
I have exactly the same problem on my 750 K7... Did 3 times, 1 ezpz, other 2 spent really long time with it.
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline SKTP
« Reply #14 on: May 24, 2018, 10:08:51 AM »
I was able to remove it last night...thanks for all of your tips. Mostly I think I just got lucky
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #15 on: May 25, 2018, 04:30:12 AM »
yeah, I done that with the cover on the F2 engine.
Also the F2 cover has a safety feature - aluminum cast point against the sprocket bolt - makes removing it harder.
