Author Topic: Tank badge  (Read 1118 times)
Offline beemerbum
Tank badge
« on: April 08, 2021, 10:23:37 AM »
The new OEM tank badge does not fit completely flush with my tank. I would like to not remove it for fear of damaging my beautiful new paint. Is there any way of getting it to conform to the curve of the tank without removal? I understand that Honda went to one part number for these badges for both sides of the tank rather than a left and right
Offline caluser2000
Re: Tank badge
« Reply #1 on: April 08, 2021, 10:26:29 AM »
Rubber mallet. Put sone mastkng tape around the edges first.
« Last Edit: April 08, 2021, 10:33:06 AM by caluser2000 »
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
Offline 74CB750K4
Re: Tank badge
« Reply #2 on: April 08, 2021, 10:36:52 AM »
Take a pic further out so we can see it more, I'm sure it looks fine without messing with it.  I think it will be noticeable to only you :)
1974 CB750 K4 Flake Sunrise Orange
Offline goodtryer
Re: Tank badge
« Reply #3 on: April 08, 2021, 10:39:17 AM »
Looks great as is.
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline 69cb750
Re: Tank badge
« Reply #4 on: April 08, 2021, 10:46:42 AM »
Remove badge, bend to fit.
Offline caluser2000
Re: Tank badge
« Reply #5 on: April 08, 2021, 11:34:12 AM »
My first post was a bit touge in cheek. The bagdes where never perfectly contured to the tank originally iirc. It looks fine.
Offline flybackwards
Re: Tank badge
« Reply #6 on: April 08, 2021, 04:40:16 PM »
Be real careful with any bending activity - the originals bend a bit but any replicas will likely be made of cast zinc alloy - they don't bend they break - I know this....
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Tank badge
« Reply #7 on: April 09, 2021, 04:01:39 AM »
Ignore it long enough and you will forget all about it. Looks fine.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: Tank badge
« Reply #8 on: April 09, 2021, 07:06:49 AM »
K2 badge is for one side only when Honda stopped making them.
Bend it for the other side easier said than done. Mine was not that good.
It will easy bend sharply between the letters, not a soft bend.
Offline Kevnz
Re: Tank badge
« Reply #9 on: April 09, 2021, 04:50:55 PM »
I bought a set of replica badges for my 550; the supplier\manufacturer advised bending to fit the contour of the sidecover by heating badge in hot water. Seemed to work.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline jonda500
Re: Tank badge
« Reply #10 on: April 09, 2021, 07:12:21 PM »
Don't try to hit/tap it in - rather than the badge ending up flush, the tank will bend in - I know! :(
I agree with what madmtnmotors said: "Ignore it long enough and you will forget all about it. Looks fine."
John
A starter clutch thread:
Offline Little_Phil
Re: Tank badge
« Reply #11 on: April 10, 2021, 08:10:21 AM »
Agree. Either leave it or remove. Couple of layers of masking tape over paint and gently lever off. I made a wooden former (mostly cut out with jigsaw) that fitted each side and pressed badges into it.
