Author Topic: Purple Rain Bill's CB750/900 Turbo 1972  (Read 58467 times)
Online madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Purple Rain Bill's CB750/900 Turbo 1972
« Reply #125 on: August 22, 2015, 03:12:58 PM »
Sure,but that won't fix the rod bearing!!
Yeah, that will require a little more effort.  :(
You don't know where the line is til' you cross it!  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #126 on: August 22, 2015, 03:16:07 PM »
double washer
Had it been the finals we probably totally would have. But we think the motor is still solid despite the downfall after the pass. I'm super stoked, boost is a thoroughly unforgettable experience.. I can't thank bill enough for the opportunity and the confidence to let me at it.
I'll return to Atlanta shortly to help Bill rebuild the motor again. But we will do it better this time and address the few little gremlins we had to deal with this week. Bills racing tomorrow! ;)
Also.. I'm looking for a ATP kit or parts to try and put one together ;)
Offline BPellerine
« Reply #127 on: August 22, 2015, 05:15:36 PM »
knew getting on that thing would change things trey!wonder what kind of rods were in the bike?billp
1978 CB 750K ard and webers
another anfob
« Reply #128 on: August 22, 2015, 07:28:47 PM »
Lucky you, Trey.  That must have been a blast!
Offline Bill/BentON Racing
    • BentON Racing
« Reply #129 on: August 22, 2015, 07:31:36 PM »
Steel, not RC or stock, we'll find out! Laŕry McBride just ran 5.82,record, his, is 5.76!! Jimmy  just took down Jeremy Teasley  and Ben Knight back to back! He is good! Fletcher didn't have his usual day. We having fun. Bill
BentON Racing Website
BentON Racing Facebook
    • BentON Racing
« Reply #130 on: August 23, 2015, 05:43:50 PM »
Haha.
« Reply #131 on: August 23, 2015, 06:12:46 PM »
Whut chu talkin bout, Willis??? Was the rod knocking loudly, or was the only indication the closed plug gap?
« Reply #132 on: August 23, 2015, 08:19:57 PM »
I clearly heard a clanking noise slightly from the motor after the pass that I had never noticed on a motorcycle before. After I got my time slip the bike wouldn't fire back up and I had to get a push back the pit.
The plug was closed and you can see the mark on the piston.. Either way we have plans to get this bike running fast times, consistently.. And we need a top and bottom end built with parts that we know we are comfortable with. Not to mention assembled by Bill so we know its done right  ;)
« Last Edit: August 23, 2015, 08:36:10 PM by TreyAllen »
Offline hotdog
« Reply #133 on: August 23, 2015, 08:51:57 PM »
Good to see wisdom told you to pull it up Billy - engine parts chompin thru turbo gets ugly real fast.....
Looking forward to see the tear down - compare notes etc for what you have in mind...
DB
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
« Reply #134 on: August 23, 2015, 09:06:49 PM »
You would have to have over .028" bearing clearance to have the piston hit the plug, if there was any clearance between the piston and the plug to begin with. The only way I can see that happening is with an improperly torqued rod cap fastener. (Had a buddy that was pulling off a late night trash putting together a 440 Mopar, and after fitting the last piston assembly, set the oil pan on the upside-down block to keep the dirt out and called it a night. The next day, he bolted down the pan, forgetting that he hadn't torqued that last rod. The motor lasted about 30 seconds. :o)
How do the other three plugs look?
    • BentON Racing
« Reply #135 on: August 24, 2015, 03:49:09 AM »
4 was the one hit. Pulled 1 looked fine. I'm guessing a rod nut improperly torqued etc. We'll find out! Tranny shifted great. K,  At least .030 in this case  ;) ;D, Bill
Offline Jim F
  • go baby go
« Reply #136 on: August 24, 2015, 11:07:25 AM »
Rocking ham is a very hard track to figure out
David ran some of his quickest times until the end of the 1/8th
then it just fell over on its rear end
its just not the super-comp guys either
Top gas had the same problem, either lane and after the 8th
everyone slowed and not a lot of break outs either
very hard to dial in using past info
we still made it to the final 7 out of 33 riders (?)1 getting a bye
Mr Curtis hit the number more close than we did (8.90 index)
and that was the end of the day
LONG TRIP HOME pulled in around 2:30 this morning
6 am got here way too soon
hope everyone got home ok
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Fastbike
« Reply #137 on: August 24, 2015, 05:08:13 PM »
Talked to a friend of mine today who was the tech director for Scooter Kizer in the Prostar days.  Told him of our problems this past weekend.  He told me they did some measurements and found that one lane is longer than the other one.  Also, the starting line is not perpendicular to the center line of the track, meaning the starting line is crooked!  I found that the right lane was funky.  I would light the prestage light, move no more than one inch, and the stage light came on?  Never had that happen at ANY other track, and I have raced at quite a few.  My best lights were .040, most slower, and my pro tree lights are usually in the .005-.015 area.  And the shut down is downhill!  Needless to say, I am not impressed with this track, like it matters.  The only good thing is it had good traction.   Now, I am not trying to make excuses, but Jim is correct.  Other people than me were having the same issues.  I will be trying to noodle this race out for quite awhile.  Still better than being at work! ;)
I'm not as smart as I look, but I am pretty.
Offline Jim F
  • go baby go
« Reply #138 on: August 24, 2015, 05:25:20 PM »
A bad day of racing is always better than a good day at work...............:)
Online MRieck
« Reply #139 on: August 24, 2015, 07:34:44 PM »
That is some interesting stuff. Will Dragbike.com comment?????????
    • BentON Racing
« Reply #140 on: August 24, 2015, 09:27:52 PM »
Our top fuel bike, haha, when ignition becomes detonation! MSD MC4 here we come,  Bill >:( ;D
A couple washers ought to fix it! ;D
« Last Edit: August 24, 2015, 09:30:54 PM by Bill/BentON Racing »
« Reply #141 on: August 24, 2015, 10:38:00 PM »
So I'm guessing the problem had nothing to do with the rod? ::)
« Reply #142 on: August 24, 2015, 10:44:54 PM »
Obviously not.. ;)
« Reply #143 on: August 24, 2015, 10:46:26 PM »
How much boost?
« Reply #144 on: August 24, 2015, 10:51:48 PM »
Too much, even with a decent amount of timing pulled. The turbo and waste gate are gonna be sent to be examined and serviced to make sure the housing is sealed properly for oil leaks and the waste gate is set where we want it. Bill has seen as much as 17lbs before so id assume it made that much or slightly more. I was too busy trying not to miss the last turn off to pay attention to the gauge before it settled
« Reply #145 on: August 24, 2015, 10:54:58 PM »
I cringe when I ask what ignition system?
Offline dragracer
  • CB750F Dragbike
« Reply #146 on: August 24, 2015, 11:20:45 PM »
I think Trey told me it was a Martek.
« Last Edit: August 24, 2015, 11:24:34 PM by dragracer »
    • BentON Racing
« Reply #147 on: August 25, 2015, 12:15:35 AM »
Nope, a Dyna S with Martek coils. Simple , not one like Johno's , but same result, Bill  ;D
  • Moderator
« Reply #148 on: August 25, 2015, 02:45:11 AM »
Is the crank OK then Billy or have you not been down there yet ?
Offline Fastbike
« Reply #149 on: August 25, 2015, 03:53:46 AM »
Wow Bill, nice ashtray!  That won't buff out.  Did it tear up the liner?
Mike, Dragbike wouldn't have any say so about the track.  On top of problems I mentioned, the right lane timing light at 1000' was not operating.  This same friend said the track owner does very little maintenance.  I would guess the track personnel are not to concerned with accuracy in the timing system.  IF that is the case, it makes it very hard to dial in a vehicle.
