Author Topic: Rear Comstar Swap Help  (Read 3713 times)
Offline sethmcalister
« on: May 14, 2015, 06:18:16 AM »
Hey All,
I just fitted a 78 GL1000 front end on my bike.  While this is the more uncommon swap due to the comstar, it was available and I seem to be really digging the comstar on the front.  For consistency, I'd like to swap a comstar on the rear of the bike.  My two options seem to be a rear comstar off a 750A or a comstar off an F1 or F2, correct?  The trouble with the latter is that the supersports were rear disc brakes.  The 77-78 750A's, however, were spokes and not mags.
Can you guys offer your opinions up on what you think would be the best option for the swap and why?
Re: Rear Comstar Swap Help
« Reply #1 on: May 14, 2015, 06:22:03 AM »
I seem to be missing what your goal is  - do you want disc in back?
« Reply #2 on: May 14, 2015, 06:31:32 AM »
The goal is a mag wheel in the back to match the comstar now on the front, I don't necessarily care if it's a disc or drum.  It would seem that more work would be involved to convert to disc though, from what I've read on the forums.
« Reply #3 on: May 14, 2015, 06:56:00 AM »
Of course, I am slow, sorry  :)
I done the comstar with disc for my K3F project.  You would need late swingarm to accomodate the wider wheel, extend the rear left top shock mount, install a rear master cylinder and resolve the brake pedal.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: May 14, 2015, 07:00:19 AM »
Or lace your front Comstar hub to a spoke rim?
http://motosynthesis.blogspot.com/p/products.html
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #5 on: May 14, 2015, 07:50:41 AM »
I have a K8 now, so the swingarm should be good, right?  Why extend the left rear top shock mount?  What did you do for the rear master cylinder and brake pedal on your conversion?
« Reply #6 on: May 14, 2015, 07:52:03 AM »
Thanks, Wilbur.  I prefer the look of the mags though.
« Reply #7 on: May 14, 2015, 08:02:52 AM »
The K8 swingarm should be wide enough (I would have to measure, I've got both 78 "F" and 78 "K" models), but the mounting point for the F2 disk brake caliper stay arm is on top of the swingarm on the "F" model. The brake hub stay arm on the "K" model attaches to the bottom of the swingarm.
TAMTF...
Wilbur
Projects:
« Reply #8 on: May 14, 2015, 08:12:01 AM »
In that case, you should be fine  refer to Wilbur, I never saw K8 in my life :)
Here is the brake pedal:
http://forums.sohc4.net/index.php?topic=115305.250
The master cylinder is somewhere earlier  in the project, basically a flat bar welded on the frame.  I used cylinder from newer Honda, it was used on many later bikes, this one is from 900RR if I recall correctly.
« Reply #9 on: May 14, 2015, 08:30:08 AM »
The 1978 CB750A had a rear comstar with a drum brake:
http://www.sohc4.net/cb750a-model-guide/
TAMTF...
Wilbur
Projects:
« Reply #10 on: May 14, 2015, 06:01:37 PM »
I thought I had seen somewhere the 78 750A's were comstars.  As I started looking today, I found a reference article to the 77 and 78's being spoke though.  Thanks for pointing that out.
That being said...is the 78 750A a direct bolt up to a 78 750K?
« Reply #11 on: May 14, 2015, 06:13:32 PM »
Well..... a quick reference to the parts fiche reveals that the 78K and the 78A share the same part number for the rear swingarm...
52100-405-000ZA
TAMTF...
Wilbur
Projects:
« Reply #12 on: May 14, 2015, 07:28:47 PM »
Wilbur,
Did you pull that from cmsnl or do you have a different reference point?
Sent from my A0001 using Tapatalk
« Reply #13 on: May 15, 2015, 03:42:36 AM »
I find this link to Service Honda's parts lookup pretty user friendly:
http://www.servicehondapsn.com/fiche_select1.asp?cat=Motorcycles&mfg=Honda
TAMTF...
Wilbur
Projects:
Offline trueblue
« Reply #14 on: May 16, 2015, 02:46:40 AM »
The 650's were comstar and drum brake ;)
1979 CB650Z
Offline cb650
« Reply #15 on: May 16, 2015, 02:55:05 AM »
Yed but different style.
Offline trueblue
« Reply #16 on: May 16, 2015, 03:00:16 AM »
Not all ;)
1979 CB650Z
Offline cb650
« Reply #17 on: May 16, 2015, 04:44:04 AM »
No but not many like your in the states right?
Offline trueblue
« Reply #18 on: May 16, 2015, 05:50:25 AM »
I've seen a number of the 650 standards with the normal comstars on them advertised over there. They may not be the most common but they are there and an option.
1979 CB650Z
Offline cb650
« Reply #19 on: May 16, 2015, 02:16:26 PM »
I have yet to see one.  Even the Canadian models are like the US ones just with KPH speedos.   the "standards" here have wire wheels.   No standard in 79Z's only the one model.
« Reply #20 on: May 16, 2015, 02:25:19 PM »
So it would seen that the best and easiest solution would be to find a rear 750A wheel?
