Author Topic: Bike popping out of gear? Update!  (Read 8406 times)
Offline 75 super sport
« on: April 03, 2016, 02:35:02 PM »
Well after 5 years of building this piggy (1975 cb750f) I took her for the first spin today. She is popping out ofgear. I only got up to 2nd but did it in both 1st and second. Any ideas would be amazing.  Thank you
« Last Edit: April 07, 2016, 06:31:27 PM by 75 super sport »
"Smoke em if ya got em"
Offline goldarrow
  • one day, i'll be an
Re: Bike popping out of gear?
« Reply #1 on: April 03, 2016, 02:49:36 PM »
Worn gear forks and drum
CB550 K0
« Reply #2 on: April 03, 2016, 03:08:14 PM »
Really? This is horrible news. It couldn't be something as simple as clutch adjustment?
« Reply #3 on: April 03, 2016, 03:14:57 PM »
The bike only has 13,000 original miles too
« Reply #4 on: April 03, 2016, 04:45:02 PM »
anyone who has been through an issue similar to this? How long would it take to replace shift forks and drum? What years will be compatible with the 75cb750f?
Online scottly
« Reply #5 on: April 03, 2016, 05:59:49 PM »
More information is required. What is the history of the bike? Is this the first time you have ridden it? What has been taken apart? Did it pop out of gear when under hard acceleration? Don't panic yet.. ;)
« Reply #6 on: April 03, 2016, 06:31:24 PM »
History of bike: the bike sat for 12 years. I purchased the bike 5 years ago. I have been building it ever since. It has 13,000 original mikes, and in the inside of the top end looked brand new. Did an 836 top end rebuild, did not mess with bottom end. This is the first time I have ridden it. It pops out of gear even at very light load. I took apart clutches to clean them and reassembled them. The clutch cable adjustment bolt on the clutch side is all the way out ( only a couple threads into clutch cover). Clutch actuator set screw is all the way in, 1/8th turn out. Let me know if you need any other information.
Online scottly
« Reply #7 on: April 03, 2016, 06:35:35 PM »
Did you have the shifter cover removed?
Online scottly
« Reply #8 on: April 03, 2016, 06:37:52 PM »
Does the neutral light work properly?
« Reply #9 on: April 03, 2016, 06:44:57 PM »
I did have the cover off to replace the final drive sprocket. I am no longer utilting the neutral light
« Reply #10 on: April 03, 2016, 06:47:44 PM »
I guess that wouldnt be the cover you were referring to would it? Lol
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #11 on: April 03, 2016, 06:48:18 PM »
This sounds disturbing. The clutch "actuator", or "lifter" should be adjusted as follows:
>Loosen the locknut and turn the actuator adjustment out until there is no load
>Slowly turn the adjuster screw in until it just touches the throwout bearing. Then back off 1/8 to 1/4 turn. If you go past the point of engagement then you are disengaging the clutch. I have done this more than once, it is easy to go too far.
>Then adjust cable slack.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Online scottly
« Reply #12 on: April 03, 2016, 06:52:55 PM »
Did you try to shift to 3rd?
« Reply #13 on: April 03, 2016, 06:53:42 PM »
That's what I meant, I apologize. The set screw was all the way out, screwed in until it just touches the throwout bearing, then back out 1/8 - 1/4 turn
« Reply #14 on: April 03, 2016, 06:54:30 PM »
I did not try to shift it to 3rd
Online scottly
« Reply #15 on: April 03, 2016, 07:04:36 PM »
So, as far as you know, the shifter cover and the neutral switch haven't been messed with?
Can you take a pic of the external shifter lever?
« Reply #16 on: April 03, 2016, 07:08:50 PM »
Yes, as far as I know they have not been messed with. The bike is in a friend's garage so I am not able to take a picture of the external shift lever at the moment. I did use a shift lever from a 1978 cb750f, I don't know if that makes any difference
Online scottly
« Reply #17 on: April 03, 2016, 07:15:03 PM »
I don't know the difference, if any, but at this point it's something to keep in mind...
« Reply #18 on: April 03, 2016, 07:17:47 PM »
The only thing I noticed when installing that shift lever was that if I pushed the lever all the way to the case, the bolt that screws through the lever wouldn't clear the shaft, so I had to back the lever off just a bit so the bolt would go all the way through
« Reply #19 on: April 03, 2016, 08:07:34 PM »
Is anything coming to your head scottly?
Offline Kickstart
« Reply #20 on: April 03, 2016, 08:15:29 PM »
Can you provide a detailed description of the popping out of gear situation?
i.e., does it shift fine into gear and you can drive for a few minutes and then it pops out, or does it pop out of gear immediately?  Popping out under heavy throttle, or any time, etc.
- Chris
75' CB750F Blue (Project)
No Reserve Racing #171 AHRMA
Offline goldarrow
« Reply #21 on: April 03, 2016, 08:19:04 PM »
Only split the cases to Change the shift forks and drum, top end doesn't have to come apart.
CB550 K0
« Reply #22 on: April 03, 2016, 08:26:55 PM »
It pops out almost immediately, under any throttle condition.
« Reply #23 on: April 03, 2016, 08:28:30 PM »
It seems to shift fine into gear, can find neutral easy. I tried holding the lever down into first while acceleration and it still popped out
Online scottly
« Reply #24 on: April 03, 2016, 08:40:29 PM »
Two things come to mind:
1. You are not fully shifting the bike into gear.
2. I hesitate to post this, but perhaps the reason the bike sat unused for so long was due to the same shifting problem. Some bikes came from Honda with improperly installed snap rings on the transmission shafts, which could pop out of their grooves and allow erratic transmission operation. I was unfortunate to have one of these, which decided to shift into gear by itself while cranking the motor, folding up the kick-stand and falling on top of me. The fix was to split the cases and re-install the snap rings in the proper direction. Hopefully your problem is #1.  ;)
