Author Topic: APE Ultra Cranks  (Read 13939 times)
Offline Big Jay
    • CBRzone
APE Ultra Cranks
« on: August 02, 2016, 03:08:52 PM »
APE Ultra Crank assemblies, complete with Carrillo rods,  ready to ship out. Two CB750 and one CB400F
Offline slikwilli420
  • Master of Disaster
Re: APE Ultra Cranks
« Reply #1 on: August 02, 2016, 03:19:11 PM »
How much? Might need to start considering one for the road racer. Could you cut the end of the crank off for the charging system?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: August 02, 2016, 03:22:52 PM »
That's just beautiful...  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Big Jay
    • CBRzone
« Reply #3 on: August 02, 2016, 09:19:18 PM »
The 750's are $1395.00. The CB400F is more because the rods are custom order.  We can cut the end off.
http://cbrzone.com/cranksrods.html
Online Don R
« Reply #4 on: August 02, 2016, 09:28:13 PM »
Very nice. Thanks for the eye candy.
« Reply #5 on: August 03, 2016, 01:12:12 AM »
« Reply #6 on: August 03, 2016, 03:26:44 AM »
It improved my CB750 more than I thought, APE stamped crank with Carillo rods. Very stable idle and quick throttle response. The CB750 SOHC should have had it from the very beginning. I see it as a corrective action.
I use a new cam (DP315) that surprised me to have such low and stable idle. I'm sure that the APE crank had a lot to do with it.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #7 on: August 03, 2016, 09:19:49 PM »
Well, lookee here!  ;D
« Last Edit: August 03, 2016, 09:21:47 PM by Bill/BentON Racing »
BentON Racing Website
BentON Racing Facebook
« Reply #8 on: August 03, 2016, 10:05:35 PM »
Damn shame you had to install the rods yerself LOL
    • BentON Racing
« Reply #9 on: August 04, 2016, 04:00:23 AM »
Hell,  I'd rather install them......then you know!
Offline Ilja
« Reply #10 on: August 06, 2016, 05:23:48 AM »
Ohhhh that would be nice for my turbo!
But I just closed the cases and put the engine back in.... :|
Offline AndyN
« Reply #11 on: November 15, 2016, 01:35:40 PM »
Sweet. That is my crank in the middle :-)
Thanks to Jay and team for the excellent work on this.
Andrew
Offline Captain
« Reply #12 on: November 16, 2016, 12:05:18 PM »
  Just so you know what a real "Extreme" crank looks like...............Finished weight 8kg (17.6 lb)
 Captain
Offline 01Thomas
« Reply #13 on: November 17, 2016, 01:26:24 PM »
drool... slobber...
 Captain
Offline bear
  • Leeton in Australia
« Reply #14 on: November 18, 2016, 03:55:47 PM »
From the Aussi master of performance cranks, Bill White.
A little heavier than your's Brent, because of the sidecar application.
Brian
« Last Edit: November 18, 2016, 04:04:23 PM by bear »
Offline kmb69
« Reply #15 on: November 18, 2016, 04:02:33 PM »
Puurrrrdy!
Are those Falicon rods?
Offline bear
« Reply #16 on: November 18, 2016, 04:20:41 PM »
Puurrrrdy!
G'day Keith,
They are indeed Falicons.
I haven't forgotten your gears mate.
The motor is on the bench, but I'm struggling to find the time/motivation to get out there and crack it open.
Brian
« Last Edit: November 18, 2016, 04:29:06 PM by bear »
Offline Captain
« Reply #17 on: November 18, 2016, 06:37:08 PM »
 Well it gets better.............Titanium Con Rods
« Last Edit: November 18, 2016, 06:51:14 PM by Captain »
Offline kmb69
« Reply #18 on: November 18, 2016, 07:02:49 PM »
Yes, indeed!  ;)
Been busier than a one armed paper hanger.
Will reply to your email over the weekend.
« Reply #19 on: November 18, 2016, 08:13:45 PM »
I'll bet you could pound a piston to bits without breaking that rod! I could see that rod cutting a circular swath through the lower case, clutch basket, cylinder block, and the cylinders if it ever parted ways with its piston...
Well, maybe it would break, but it would not go quietly!
TAMTF...
Wilbur
Projects:
Offline Captain
« Reply #20 on: November 18, 2016, 08:43:34 PM »
 My current engine has a stroke of 69mm and a current red line of 12000 RPM and this translates to a piston speed of 27.6m/sec (piston assembly weight of 185g).  In order to handle this and have further RPM capability the design brief was for Titanium Rod that was stronger than a steel Carrillo and rated to 13000 RPM (30m/sec).
 This picture shows both a Carrillo and my Titanium rod side by side for comparison purposes.   (The Carrillo is the smaller)
 You won't break one of these!!!!
    • BentON Racing
« Reply #21 on: November 18, 2016, 10:28:19 PM »
I didn't think I'd break a Carrillo .....first time for everything I guess, yes they become little saws!
Offline mick7504
« Reply #22 on: November 18, 2016, 10:58:51 PM »
You don't mess around Bill.
That is one Carrillo that can be called the sacrificial lamb mate.   ;D
If I was you
I'd be worried about me.
Offline teebee67
« Reply #23 on: November 19, 2016, 12:35:09 AM »
Did you make or have the titanium rods made or are they available generally, if so from where please?
I'm only old on the outside.
« Reply #24 on: November 19, 2016, 06:03:59 AM »
Crower will make them. They have the specs for 750 rods. I have always felt a Carrillo "A" beam rod would be a great piece for the CB750. It is lighter than the "H" beam (which is fairly light) and plenty strong enough. I run the A beam in my FJ
