Author Topic: Screwdrivers  (Read 3907 times)
Offline beemerbum
Screwdrivers
« on: May 10, 2017, 02:47:21 PM »
Just curious. How many out there use JIS screwdrivers vs ordinary Phillps?
Offline drumstyx
Re: Screwdrivers
« Reply #1 on: May 10, 2017, 02:52:33 PM »
I use a high quality hollow ground gunsmithing bit set, and the phillips bits from there work great -- about $20 from pachmayr.
If not for that, I'd definitely have a JIS set, but the lock I get on the screws from using the correct sized hollow ground bit is like no other.
Offline kerryb
  • Not a very
Re: Screwdrivers
« Reply #2 on: May 10, 2017, 02:55:22 PM »
Now that I have them, I wish I had em sooner.  But I always used my impact driver the first time loosening a screw in anything.  I got the vessel jis impact drivers...they are wonderful.  Before those I found a deck screw bit that fit well enough to not cause damage, but I still worried.
Re: Screwdrivers
« Reply #3 on: May 10, 2017, 02:57:50 PM »
JIS!
Offline beemerbum
Re: Screwdrivers
« Reply #4 on: May 10, 2017, 03:46:52 PM »
What is a good source for a set of JIS drivers?
Offline Ridem32
Re: Screwdrivers
« Reply #5 on: May 10, 2017, 03:55:42 PM »
I use JIS got a set from Ebay vessel brand
Offline whitjonw
  • Motorcycle Maniac
Re: Screwdrivers
« Reply #7 on: May 10, 2017, 05:32:22 PM »
I use JIS  as well. Once I learned that there was a difference, I ordered them pronto  8)
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Re: Screwdrivers
« Reply #8 on: May 10, 2017, 05:44:50 PM »
about 30 seconds with the bench grinder turns your philips japanese...I mostly just use the impact driver and/or a oem tool kit screwdriver and the only time I have a problem is when that puppy ain't comin out in one piece no matter what you use.
Offline CycleRanger
  • No comment about being an
Re: Screwdrivers
« Reply #9 on: May 10, 2017, 06:02:53 PM »
JIS all the way!
It really makes a difference with the smaller screws, especially carb screws.
I got a nice 4 piece set from Mcmaster Carr a few years ago for about $15 but they no longer carry that set/brand any more.
Offline b52bombardier1
Re: Screwdrivers
« Reply #10 on: May 10, 2017, 07:02:32 PM »
Definitely JIS.
Rick
1972 Candy Yellow CL100 K2
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
Online PeWe
Re: Screwdrivers
« Reply #11 on: May 11, 2017, 02:55:43 AM »
Removed all X heads replaced by allen screws.
Re: Screwdrivers
« Reply #12 on: May 11, 2017, 06:00:47 AM »
In your controls, headlight and carb bowls too?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Screwdrivers
« Reply #13 on: May 11, 2017, 06:21:07 AM »
JIS screwdrivers as well as JIS impact driver bits. Anything else (when dealing with stock fasteners) is an exercise in futility.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Bankerdanny
  • Endeavor to persevere
Re: Screwdrivers
« Reply #15 on: May 11, 2017, 07:45:09 AM »
I have a set and I really need to add a set of JIS impact bits to my tool box.
  • I'm back
Re: Screwdrivers
« Reply #16 on: May 11, 2017, 08:45:48 AM »
JIS is a must for those tiny screws when you're at the carb slides to change the needle position (if you must).
Replace the 16 crosshead screws that hold the floatbowls by ss allen screws by all means.
Furthermore I have replaced two of the 4 screws that hold the left crankcase cover (sprocket cover) by allen bolts.
For the rest, believe it or not, I haven't changed anything (studs at the headers excepted). Even the chain adjuster lock nuts in the rear are still the ones the bike came with, although now, after hundreds of adjustments, they get a bit round.
An impact driver is an useful tool in your workshop.
I wonder why people change all for allen, it's a waste.
Best advice I ever had, you can read in Zen and the Art of Motorcycle Maintenance. Robert M. Pirsig who deceased last month at the age of 88, tought me about the correct state of mind you have to be in when you do maintenance and when it is time for a cup of coffee.
« Last Edit: May 11, 2017, 08:49:14 AM by Deltarider »
Offline Jarrett_Honda
Re: Screwdrivers
« Reply #17 on: May 11, 2017, 08:50:18 AM »
JIS is the way to go.
Sent from my SM-G930T using Tapatalk
Online PeWe
Re: Screwdrivers
« Reply #18 on: May 11, 2017, 09:01:50 AM »
YES!! :) Carbs are newer with allen heads from the beginning.
The small adjuster screw for headlight rim and rear lamp still small x-screws, though.
Re: Screwdrivers
« Reply #19 on: May 11, 2017, 02:37:44 PM »
I just ordered socket head screws for the Mikuni carbs I am rebuilding....
http://www.ebay.com/itm/Stainless-Steel-Float-Bowl-Carb-Top-Screw-Set-Mikuni-VM33-BCM-9004-/262945363584?hash=item3d38c3d680:g:JI8AAOSwXYtYvHgk&vxp=mtr
Offline jonda500
Re: Screwdrivers
« Reply #20 on: May 11, 2017, 04:25:34 PM »
A JIS screwdriver is on my long wish list - but me and all my crosshead screws have survived over thirty years of wrenching without one so it's not urgent! (I'd never even heard of 'em until I joined the forum!)
All three of my bikes have all 100% original screws and I use a $3 impact driver with the tip ground down to crack them loose.
An inexperienced person could quickly wreck all their screws with some ham fisted use of a phillips head screwdriver!
John
A starter clutch thread:
Re: Screwdrivers
« Reply #21 on: May 11, 2017, 04:26:48 PM »
$3 impact driver with the tip ground down...
That's JIS!!
Re: Screwdrivers
« Reply #22 on: May 11, 2017, 08:50:05 PM »
I bought a JIS set from Vessel and recently picked up an older Vessel Impact driver that has the blue steel box...the driver has chrome in a couple places and blue body.
I have an old Sears impact driver but it weighs a ton and the Vessel was at an incredible price 2nd hand.  Just the later came with no JIS bits.
Started a conversation with Vessel US distributor about ordering the set that came with it as they had long versions of the bits which are handy for giving you a tad more reach when using.
I would recommend you buy the replacement bits that Motion Pro sells  in 2-packs for each size...they came out with a new T wrench with JIS #1, #2, #3 bits that are 1/4 hex driver bits about an inch long.  Perfect for ratcheting screwdrivers or a screwdriver bit socket...they have a locking ball and magnet so they don't fall out if the mechanical part does not hold them.
Vessel sells a replacement bit set for their impact driver handles as well, if you have an impact driver and don't need another...  they can be the 5/16" hex bits and ou can replace the bigger JIS bits or buy them.  They are not cheap.  Might just be better in long run to buy the Vessel set or a Megadora with the impact driver technology they sell built in.
Offline Darren Jakal
Re: Screwdrivers
« Reply #23 on: May 12, 2017, 07:05:36 AM »
Thanks for that information RAF!
I have my fathers old vessel impact driver, but without JIS bits and was looking for these. Looks like I can get them through FortNine Canada so easier for us Canucks. Anyone have an opinion on FortNine for service and stuff?
Oh and as for the OP: yes get the JIS and save your old fasteners.
cheers dj
Cheers, dj
