Author Topic: PAMCO ISSUES!  (Read 2016 times)
Offline cb500kawi305
PAMCO ISSUES!
« on: July 09, 2017, 01:45:41 PM »
Alright guys I've had my ignition timing done for a while now, until the other night when i was going to start up the bike and it would only fire on coil 1-4. i pulled plug caps and tried arching to my engine but no spark. (did the same with 1-4 and worked) checked wiring everything is fine, pulled ignition cover and ran a test light on my red wires and got power. did the same on my green wires (go to coils) and only got the light to work on 1-4 when trying to start the bike. my timing is still set. no advancer issues. Is it possible soldering have gone bad or anything?? it was working fine one second the next its not. where is pamco Pete??
Re: PAMCO ISSUES!
« Reply #1 on: July 10, 2017, 03:35:26 AM »
Strange, always 2-3 that get problems?
Re: PAMCO ISSUES!
« Reply #2 on: July 10, 2017, 11:02:27 PM »
yes im sure.
Re: PAMCO ISSUES!
« Reply #3 on: July 24, 2017, 04:55:49 PM »
I have gotten my unit warrentied and same issue. could it be my advancer? its so weird to me! maybe could my bike come out of complete timing for those cylinders cause i tried starting 1-4? could that have messed 2-3 up?
Offline Scott S
Re: PAMCO ISSUES!
« Reply #4 on: July 24, 2017, 06:21:09 PM »
 So, Pete replaced the unit under warranty and you're still having the same issue? Maybe you should change the name of the thread.
 The advancer wouldn't make either side fire or not fire.
 Check continuity on the wiring for the 2/3 side. From where you attached the Pamco wires, all the way up the main harness to the coils.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: PAMCO ISSUES!
« Reply #5 on: July 25, 2017, 05:00:56 AM »
+1
+1
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
