Author Topic: Placement and function of oring  (Read 1949 times)
Offline _mark
« on: December 01, 2020, 03:11:35 AM »
Hi guys
What is the real aim of this oring (91304286000 part) ?
I just pushed it into the groove but the groove is deeper than the oring.
so I assume no sealing between cylinder bottom flat and upper flat of crankcase to prevent external oil leakages. Further the paper seal is thick 0.5 mm and around such seal, therefore one more reason to be doubtful..
thanks
« Last Edit: December 01, 2020, 03:14:27 AM by _mark »
Offline Progas
Re: Placement and function of oring
« Reply #1 on: December 01, 2020, 05:28:49 AM »
Those orings keep oil from creeping up between the sleeve and cylinder block. You can just seal that groove with Hondabond and save the cost of the orings if you want.
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« Reply #2 on: December 02, 2020, 06:43:11 AM »
I've been wondering about this myself.  What can happen if oil gets between the sleeve and the casting?  Anything bad?
Offline 69cb750
« Reply #3 on: December 02, 2020, 07:38:12 AM »
If the oil catches fire there will be a terrific explosion blowing the head off the engine, through the frame tubes, gas tank and possibly killing the rider if he fails to bail in time.
Online Don R
« Reply #4 on: December 02, 2020, 08:04:58 AM »
My old big bore motor has a flycut case and the rings slid down the sleeve. They ended up chewed up and stuck to the oil pump screen.
Offline corky
« Reply #5 on: December 02, 2020, 09:50:15 AM »
I would donate a spare motor to see this!  Without the rider on it, of course.  ;-)
Offline DaveBarbier
« Reply #6 on: December 02, 2020, 10:16:20 AM »
Absolutely zero percent chance of that happening. But would be fun to watch!
Offline Flyin900
« Reply #7 on: December 02, 2020, 10:19:50 AM »
I got the popcorn when is the show!!! :)
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline DaveBarbier
« Reply #8 on: December 02, 2020, 10:26:41 AM »
Who would be best suited to set this up? Maybe Cal can do it then we send the motor up to JWilde and film it. I’m in for $100 for a spare motor.
Offline DaveBarbier
« Reply #9 on: December 02, 2020, 10:28:34 AM »
Didn’t JW say he can do 80mph in his 350F in second gear? When this motor goes off he could do 80mph vertically.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #10 on: December 02, 2020, 11:23:23 AM »
At 25,000rpm no less!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #11 on: December 03, 2020, 04:38:53 AM »
I put my money on Fenders  ;D
