Author Topic: Bearing retainer tool - CB750  (Read 1391 times)
Offline boaf
« on: November 27, 2022, 11:26:53 AM »
I’ve googled many terms and can’t seem find a tool for the rear wheel bearing retainer on the 750.
It’s the larger of 2 retainers, part 41231-283-000.
Does Motion Pro make a tool for this?
Thanks!
Build Thread '78 CB550K Four 'Phoenix' - http://forums.sohc4.net/index.php/topic,171255.0.html
Re: Bearing retainer tool - CB750
« Reply #1 on: November 27, 2022, 11:36:41 AM »
Check this seller that sell the tools for both hubs + clutch.
Paper copy of CB750 shop manual too.
I have one, in my living room, far away from oil ;)
https://www.ebay.com/itm/254652243320?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=8uuBLBV_Q4y&sssrc=2349624&ssuid=XgCEg0CPSya&var=&widget_ver=artemis&media=COPY
Offline boaf
« Reply #2 on: November 27, 2022, 12:43:05 PM »
Thanks! I’ll check that out.
However I really only need to one tool as I already have the a clutch tool and tool for smaller retainer.
I’m not actually working on a 750 just have a rear hub I’m using on a different project.
And yes I definitely also have paper manuals that don’t go to the work shop.  If I need a reference while working there I just print the relevant pages ;)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: November 27, 2022, 06:42:00 PM »
Go to that seller in UK own website, he sells cheaper and individual, als does stainless caliper pistons, i buy regularly from him.
Offline Alan F.
« Reply #5 on: November 27, 2022, 07:29:54 PM »
You might not need a tool to remove the bearing retainer if you drill out the staking deep enough.
Last one I did was on a drill press and it's very easy to tell when you've drilled completely through the threads. After removing all of the chips my retainer unscrewed with only finger pressure.
« Reply #6 on: November 27, 2022, 08:23:59 PM »
I made mine using a simple aluminum bar from Home Depot. I drilled the 2 holes and inserted a bolt with an OD almost the ID of the holes in the retainer through each hole with one end of the bolt protruding out with a nut on each side of each bolt leaving bar at both ends to leverage.
Offline boaf
« Reply #7 on: November 28, 2022, 04:44:01 AM »
Done!
Offline Deltarider
« Reply #8 on: November 28, 2022, 11:56:11 AM »
There's nothing special about Honda's "special" tool. You can make one yourself.
« Last Edit: November 28, 2022, 01:26:06 PM by Deltarider »
CB500K2-ED Excel black
« Reply #9 on: December 03, 2022, 04:48:44 AM »
Old wrench from angle grinder.  Drill holes where you need them and insert spring pins.
Offline stocky
« Reply #10 on: December 03, 2022, 10:26:45 PM »
Stand on the center to keep in place and hammer the ends to back the retainer out.
