Author Topic: CB750 Dual disc front end swap (with GSXR1000/600/750 parts)  (Read 165654 times)
Re: CB750 Dual disc front end swap (with GSXR1000/600/750 parts)
« Reply #275 on: April 11, 2010, 04:19:18 PM »
Gday Brian, did you see what Terry did to mount his front guard?
http://forums.sohc4.net/index.php?topic=61168.1525
Edit: probably won't work with upside down forks....... ???
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #276 on: April 11, 2010, 04:22:58 PM »
yeah, I liked his custom fender mount.
but the only way I can mount a fender (that doesn't look like I'm on a dirt bike) is to attach it to the fender mounts on the base.
it's not the most attractive piece on the bike, but it does the trick 'till I can think something else.
« Reply #277 on: April 11, 2010, 04:28:22 PM »
IC, your bending under fender looks good. I  just feel that if the 2 strips were tied together, like right below fender, it would cut down the vibration. I have seen some very stout brackets break repeatedly on a big stroker.
 A few yrs back an old customer got me to make a fender brace for a l-o-n-g wideglide..he was running an FXWG fender, similar profile to yours but narrower and for a 21 incher..Anyway we formed a 3 in x 1/4 aluminum brace, that fit the fender very well.. a bit of work to pull off, and get to look even. He said it helped quite a bit cleaner than a tweakbar..
  • Like a well oiled
    • Undead Asphalt
« Reply #278 on: April 11, 2010, 04:32:29 PM »
I wanted to do that, but I can't weld aluminum right now.
as soon as I get a setup, I'll brace it up better.
« Reply #279 on: April 11, 2010, 04:38:57 PM »
If you weld it, it looses strength..
 If you drill tap and brace it, may work..keep bolt tiny..#8 might do.
 Or you run a strip and sandwich it to connect the 2 bars, but excess weight, will probably concentrate vibration in that area.
 Mounting, older style fenders  to the USDs is a real chore..
  • Like a well oiled
    • Undead Asphalt
« Reply #280 on: April 11, 2010, 05:00:43 PM »
I think I might try to make one out of a single sheet instead of bending little planks.
forgive the crude drawing, I used paintbrush with a track ball.
  • Like a well oiled
    • Undead Asphalt
« Reply #281 on: April 12, 2010, 08:38:45 PM »
there's somethin about your headlight ears that doesn't sit right with me ...hmmmmm...  i know ...   they're not full o' holes yet  ;D ;D
Is this what you mean Spikey?
« Last Edit: April 12, 2010, 08:40:59 PM by Industrial Cafe »
Offline Zaipai
    • My Home page
« Reply #282 on: April 13, 2010, 05:08:21 AM »
Now its starting to look like an IC part...!!!  ;D
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Really?
« Reply #283 on: April 13, 2010, 08:32:15 AM »
That would be a good place to mount a fuse box!
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #284 on: April 13, 2010, 09:00:18 AM »
*breathes sigh of relief*   AHHHH  ...much better    ;D ;D
  • Like a well oiled
    • Undead Asphalt
« Reply #285 on: April 14, 2010, 01:07:14 PM »
so I did some more grinding on the rotors and the brakes only grab the tiniest bit, enough to live with for now.   I think I can work it out some more, but I'll do that later. I don't have Harley parts for my make-shift grinding jig and it's VERY time consuming without it.
also-
I got the headlight brackets drilled and remounted.
The 1 inch hole takes some filing to get perfectly round because the drill bit is so big and the piece is so thin, it makes a sort-of triangular hole at first.
I ran out of sandpaper so I'll shine em up later.
the headlight bucket needed some modification because the clutch cable was rubbing the paint off it,  so I heated it up with torch and rolled it on a 1 inch rod to get a curved shape in it.
 A little paint matching and the lines aren't all cramped up in there anymore.
 (I put some protective stickers on there)
  oh, and I made the wiring hole a lot bigger.
Still wanna graft my old lever onto the new master cylinder. but that can wait.
  • Like a well oiled
    • Undead Asphalt
« Reply #286 on: April 14, 2010, 01:15:01 PM »
Offline Zaipai
    • My Home page
« Reply #287 on: April 14, 2010, 03:58:23 PM »
Dude, that looks #$%*ing fantastic! Great work.. Well worth the wait.. Nice work Bob.. er Brian.. ;)
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #288 on: April 14, 2010, 04:22:31 PM »
Hey Bri, what size is that rear tire? Front turned out great!
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
« Reply #289 on: April 14, 2010, 04:23:47 PM »
genius  !!!!! your a freakin genius
 ...seriously, i'm impressed  ;D
« Reply #290 on: April 14, 2010, 04:54:19 PM »
He is a clever little fellow isn't he.... ;D   Nice job Brian..
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #291 on: April 14, 2010, 05:12:39 PM »
sooo..... im going to come down to your place and take your bike for a spin...... just giving you a heads up.
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline ev0lve
« Reply #292 on: April 14, 2010, 05:24:26 PM »
You magnificent bastard  ;D
That profile is the poop. Compact and low. I was thinking of getting something with a loop to glue on to stop the clutch cable from wearing on the headlight bucket. This though... so much better.
  • Like a well oiled
    • Undead Asphalt
« Reply #293 on: April 14, 2010, 05:39:35 PM »
thanks people!
   I forgot another thing, I need to make the bars wider by 5 inches total.
16x4.25 aluminum akront rim with a 130/90/16.
 I don't like it anymore, after I put it on it didn't look like I thought it would.
I wanna go to a bigger wheel, either 17x4 or 18x3.5 with a lower profile 130 or 140 tire
OK ;D
Offline Zaipai
    • My Home page
« Reply #294 on: April 14, 2010, 05:47:49 PM »
I thought it was steel like most 16" drop center rims.. Shows you what I know..
Oh.. yea I smell a road trip to Bob.. I mean Brians place to take turns on his bike..  ;D  ::)
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline HedNut
  • Underwater Basket Weaving
« Reply #295 on: April 14, 2010, 06:29:29 PM »
Wow... top notch work IC! I'm learning a lot from yoU!
Love it!
  • Like a well oiled
    • Undead Asphalt
« Reply #296 on: April 14, 2010, 06:36:09 PM »
Offline YogiBear
« Reply #297 on: April 14, 2010, 08:05:05 PM »
Wow, I gotta say, Well Done IC.  :o Your bike looks amazing.  ;)
1974 Honda CB750K4        1973 Honda CB500 Four
Offline Zaipai
    • My Home page
« Reply #298 on: April 14, 2010, 08:08:02 PM »
Video?
Its my Avatar..
75 CB550F  |
  • Like a well oiled
    • Undead Asphalt
« Reply #299 on: April 14, 2010, 08:18:42 PM »
not yet.    soon.
