Author Topic: Machine Shop in Atlanta GA  (Read 7284 times)
Offline CB750 SS
« on: January 19, 2016, 12:05:25 PM »
Guys, I'm in the process of rebuilding my CB750 motor and need a good machine shop in Atlanta GA. Any recommendations?  I'm thinking about having the cylinders bored and valves lapped.   In the past I've gone the cheap way and just replaced the rings and seals and that's fine. Typically, I'm a little unhappy as something isn't perfect.  I've got a couple of options and wanted to know the forum's thoughts.
1 - have the cylinders measured and valves lapped, just cross hatch the jugs if OK and bolt it back together.  what is the cost for a machine shop to inspect and lap?
2 - have the cylinders bored to the next size (+.25mm) and buy new pistons (@ $300 from Vintage CB750). what is the cost (guess) or boring to the next size?  +.50mm oversize parts are the same cost.
3 - 836?
Will I have to change the carb and cams for the 836?  I'm not interested in making it fast, just right and tight.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Machine Shop in Atlanta GA
« Reply #1 on: January 19, 2016, 12:18:14 PM »
Reach out to member Bill Benton ( Bill/BentON Racing ), he's an fanatical engine builder in North Atlanta.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline joesmotos
« Reply #2 on: January 19, 2016, 01:15:17 PM »
Call Star Racing in Americus,Ga.....
worth every penny,dont scrimp,best finish,super precise...
they do all my motorcycle stuff and i have regretted in the past when i tried to *save* money elsewhere..
« Reply #3 on: January 19, 2016, 04:42:50 PM »
No, you wont.  My K4 is a 836, and it pulls from a stock 750.
$50/hole is the cost of boring 'round these parts, recently had my [three] H2 cylinders done.
Offline Restoration Fan
  • My wife will never call me
« Reply #4 on: January 19, 2016, 05:45:21 PM »
CB750 SS,
What part of Atlanta?  I'm in Woodstock, GA myself.
Also, I happen to know the Star Racing people in Americus from many years ago when I to school there.  Good people.
« Reply #5 on: January 19, 2016, 10:24:07 PM »
If you cant take it there and have access to tablesaw.. Make boxes to protect head and cylinder.. .
If you dont , you will wish you had.. And you use them over and over..
« Reply #6 on: January 20, 2016, 03:43:03 AM »
Cruzin Image now also has +.5mm (62.5mm 2nd over) and +1mm (63mm 4th over) at $100 for the set of four.  8)
and yes, Bill is a builder, not a machinist, but I figured if anybody knew machinists in Atlanta he would.  ;)
« Last Edit: January 20, 2016, 03:44:41 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline CB750 SS
« Reply #7 on: January 20, 2016, 06:28:26 AM »
Americus, GA is a few hours away (2.5hr according to Google).  I'm near Decatur Ga.  Sounds like I should reach out to Benton and see if he knows anyone in Atlanta.  If I can can get holes machined for $50 each ($200 total) and piston sets for $100 ($188 for 836cc), that's pretty cheap. Any pros or cons I should know about? Bigger is typically better, and given modern oils, mild setup, mature driving...the sleeves thickness shouldn't be an issue.   Also, what (if anything) should I do about the valves?  ...or should I just ask Benton? :)
Offline CB750 SS
« Reply #8 on: January 20, 2016, 02:40:33 PM »
How do I get a hold of Mike Rieck?  Does he have a machine shop?
« Reply #9 on: January 20, 2016, 02:47:40 PM »
MRieck is a member here.
Yes... in Massachusetts.
TAMTF...
Wilbur
Projects:
« Reply #10 on: January 20, 2016, 05:37:53 PM »
Bill lives in Alpharetta.  Unless he's found one he likes within the last year, he doesn't have a machine shop here in Atlanta he trusts.  When Logan broke off the screw in the engine case on Stella this time last year, I took it to one I found because Bill didn't have one he recommended.
As cal stated, he sends his heads to Mike Rieck to have them done.
I doubt you'll want to drive down to Americus.  From you, it is indeed about a 2.5 hour drive (down I-75 to Cordele then turn west to Americus).  But there isn't a whole lot to do there unless you want to go visit Plains (about 10 - 15 miles away).  You'd do better to ship it there (or to MRieck) and just wait on it to be shipped back.
Offline CB750 SS
« Reply #11 on: January 21, 2016, 05:45:52 AM »
Sounds like I'm shipping this thing. I was hoping to hand deliver locally. What's the best way to ship?  Build a wood box? UPS?  never shipped a motor before.
Offline CB750 SS
« Reply #12 on: January 21, 2016, 06:14:29 AM »
If I'm going with an 836cc setup, sounds like I need to buy the piston first. ...and ship with?
« Reply #13 on: January 21, 2016, 06:27:34 AM »
Yes, definitely.
« Reply #14 on: January 21, 2016, 06:40:20 AM »
I shipped a disassembled motor last year.
The absolute best way is to use a heavy duty plastic storage container. I used rigid foam insulation [very inexpensive] to surround and separate the parts, be sure there is no movement of parts within the container, use additional shipping matierals as needed.
Finally, install the lid and secure with zip ties.
I used UPS and insured the shipment for full value.
Offline CB750 SS
« Reply #15 on: January 21, 2016, 07:54:23 AM »
Great idea! Does anyone have Mike R contact info?
Offline CB750 SS
« Reply #16 on: January 21, 2016, 10:13:38 AM »
thanks Calj737!
Offline dragracer
  • CB750F Dragbike
« Reply #17 on: January 21, 2016, 11:47:26 AM »
You've got several choices in the Atlanta area to include Cooper Performance and Rockdale Cycle. Star is a great choice as well. And don't forget Kim at Carolina Cycle up in Salisbury,NC. He's done several heads and transmissions for me some years ago at a great price and he can bore the cylinders for you too. He helps a lot of the TQ midget guys with SOHC builds in the past.
« Reply #18 on: January 21, 2016, 01:59:46 PM »
Thanks for weighing in, Frank.  Good information to have for all of us Atlanta people.
Offline CB750 SS
« Reply #19 on: January 22, 2016, 01:22:01 PM »
I emailed Mike and Bill and haven't heard back from them. So I called Rockdale, and they seems knowledge and nearby.  they quoted me $250 to bore out the cylinders.  As I need to bring the new pistons with me, I need to buy them.  Being a newbie in the piston world I asked their recommendations : forged and a brand name such as Wiseco.  I'm tore as to buy the $130 kit from cruzinimage on eBay, or pony up.  I assume the cruzinimage pistons are cast, so heavier & great variance in size. Wiseco are a bit out of my budget. Does anyone have a bad experience with pistons? BTW - are the originals? cast or forged?
« Reply #20 on: January 22, 2016, 02:50:18 PM »
There's a 16 page thread dedicated to the cruzinimage 836 kit on ebay:
http://forums.sohc4.net/index.php/topic,89779.0.html
cruzinimage now offers 2nd over (61.5mm) and 4th over (62mm) kits as well for $100 for a set of four pistons and rings. I've got a test mule here that may get a set of second over pistons after honing the bores to size myself.  8)
TAMTF...
Wilbur
Projects:
« Reply #21 on: January 22, 2016, 02:55:47 PM »
Dont buy pistons till your cylinders are proper measured, you need to be sure to get the correct size. I prefer to let the machinist do this.
Although I plan to use the CI piston kits on a rebuild, the last two [Kawasaki] motors I have rebuilt have been with forged Wisecos.
