Author Topic: First bike build 78 CB750K  (Read 22428 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: First bike build 78 CB750K
« Reply #25 on: April 26, 2016, 07:44:32 AM »
For some reason, none of the pictures from your last post appear on any device I use to read your thread? Anyone else having problems?
I don't see them either.
Think the original image in my google photos account might be too big for taptalk, or not formatted correctly or something.  I resized one and it's showing up now on taptalk for me.  None of the rest of them though.  Maybe caching, I'll take a poke around when I'm at work today.
They're showing up fine on the sohc web forum for me though.
You're on the right track. Image one is now showing.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Mule169
« Reply #26 on: April 26, 2016, 09:02:23 AM »
Aight... Sorry everyone, images sorted now.  Hiccup in the intertubes I guess.  I just recopied and pasted links.
Offline Mule169
« Reply #27 on: May 08, 2016, 07:05:06 PM »
Been a busy couple of weeks, not much time to work on the bike, but here's what I got.
So I got the power side of the M-Unit wired up and cables roughly run.  I decided to just get a small piece of alu to bolt components to, and I'll just velcro that to the seat pan.  I was pretty averse to drilling through the seat pan to mount things (save for the taillight wires/mounting bracket).
Here's the M-Unit and starter solenoid
For the solenoid mount I just cut a thin piece of alu, and bent ears on it.  I pop riveted it to the alu plate, and those ears fit perfectly in the stock rubber mount from the stock solenoid.
I'm going to give the Ricks the same alu plate treatment.  There was room to mount it next to the M-Unit, but I thought it might get too hot and there would be the possibility of damaging the M-Unit, or melting wires, so I'm going to mount it in the far back little seat cavity.
Here's a panoramo of the wiring up the bike.  Blue wire is the start wire hanging down, and it's hard to see but I'm going to mount the wireless ignition right in front of the battery in the little ear of the battery tray.
Here's all the wires pulled up and through the headlight bucket.
Next up I think is going to be starting to run all the front control wiring through the bars.  I'm going to install control switches that I got from Lowbrow customs and they'll be flush mounted to the bars.  I'm also planning on running clutch/brake switch lines through the handlebars and probably have them exit down by the top triple nut.  Hoping for a pretty clean front end wiring wise.
Another little project that I'm going to tackle here in the next week or two is building a bucket for the GPS speedo/digital tach.  The unit I got is from Speedhut, and they're designed for cars.  I've seen several projects use them and they have kind of a cheezy spin on plastic nut.  Most projects I've see just cut out a plate and spin the nut on the back.  I'm not really into that so I found a perfectly sized piece of pipe at my local metal supermarket that the speedo will more or less drop into.
I've got a small piece of flat cold rolled steel to weld onto the back to seal the back off, and a thicker chunk of steel to make a mount for this spot on the triple that I think was used for a wiring mount.
So yeah, I'm going to get everything roughly mounted in the next little bit before I start cutting and soldering wires, and really wiring the thing up in earnest.
I'm wondering/debating if I should splice the original starter motor wire to make it longer, or replace it completely as it's not long enough now to reach up to the starter solenoid in it's new placement.  I guess that starter isn't too difficult to pull out and put a new wire on, just a matter of another trip to the hardware store, and time to pull the thing out and build a new wire.
Anyway, probably going to pull the plug on new shocks (still debating on budget, and how much performance I need) shortly as I'm hoping my newly hondaman'd swingarm will be back from Colorado soon.  Also getting rubber mounted on the wheels in the next week or so, so I'll have that all mounted up soon too.
Things are getting dangerously close, or at least it feels that way from way back when I started this whole project.
Ok, more as soon as I have time!  As always, it's my first build, so feel free to point out where I'm #$%*ing up, or if you have any advice that you're willing to share on parts, placement, etc., to help a brother out!
Cheers all!
« Last Edit: May 08, 2016, 07:14:32 PM by Mule169 »
Offline Mule169
« Reply #28 on: May 08, 2016, 07:32:36 PM »
Some of your pictures went missing again?
Dammit!  Think I fixed that now.  Sloppy cutting and pasting.
Be sure to clean that solenoid stud really, really well! You can run the Y/R wire from the solenoid directly to START ouput, and the Gr/R wire straight to ground and be all done with that portion, unless you are determined to use the left side Clutch Safety switch wiring?
Ya, just a test fit on there for now, I got to scrub the #$%*e out the terminals.  I was thinking about wiring up the clutch switch safety wiring.  If I ever sell this thing, or let any buddies ride it, I'd rather just be safe than sorry having it wired up.  I'm becoming a wus as I get older, I took all that crap off my first bike years ago.  IDK, doesn't seem like too much of a pain in the ass.  Any reason I shouldn't other than the complexity of the wiring?
Regarding the speedo cup, how will yu secure the unit to the cup now that y arent using their threaded receiver? Its also advisable to isolate thwt unit with a small rubber bushing instead of a hard mount only. The vibration is a bit hard on them in the long run.
Still working on that.  The fit is a very tight press fit right now, so I was thinking of just turning the threads down a bit and wrapping a small bit of rubber around the gauge before sliding it in, hoping to still keep it a tight press fit.  I was also planning on getting a large o-ring to slide on for where the lip of the gauge meets the top of the gauge bucket.  Still a bit of a work in progress in my head and probably needs some refinement.
Reg/Rec - consider mounting it on the underside of the seat pan where it will be in free-flowing air. Its probably fine where you plan it, but open air is far better.
Ya, I wondered about that.  I couldn't really find any literature on how hot that reg/rec really gets (especially the newer models like the ricks).  It seems from reading the interwebs that the old ones get far hotter, but if in the seat cavity really isn't a good spot, my alternate was going to be on the underside of the battery tray to try and conceal it a bit and save some of the aesthetics.
M-Lock - test it for reading throughh yur seat before you install it as you plan. Ive installed them from the underside in a similar location without incident. Youll probably need slightly longer screws too, I think M3 is the gauge...
I probably shouldn't have been more clear here, but I was planning on mounting it on the underside of the battery tray.  Basically drill a couple holes in the battery tray and run those M3's down and mount the m-lock unit basically in the open air under the tray.  Concealed but not behind any metal (as the manufacturers instructions say it won't work if it's behind metal).  Again, just initial thoughts, might change with advice from folks like you, and/or just changing my mind :-)
Offline Mule169
« Reply #29 on: May 08, 2016, 09:10:05 PM »
I dunno about the clutch switch. Without it, the bike wont start in gear, so how could anyone get hurt? Only get confused when it wont go...
Good call.  I didn't think about that.  One less set of wires I have to pull through the bars.
I think youre onto something with the gauge install...
I'll post pics, when I get into the welding shop to build.
Under or underneath is fine for the Reg/Rec, just dont know about your seat and clearance is why I asked.
Yeah, I have prob 1/2" - 3/4" clearance above the seat pan.  Figured that would be enough of an airgap
A final idea, with the m-buttin planned (sure i cant talk you out of it???) why not install it within the handlebars toond have just the single CONFIG wire rearward? Youd need a larger hole underneath your Renthals, but the wiring would be invisible.
Great idea!  I didn't even think about this, sold!
Offline SierraCB
« Reply #30 on: May 08, 2016, 11:37:13 PM »
Wow killer work!  Love how clean everything is, makes me wish I had the skills and patience.
Offline Mule169
« Reply #31 on: May 09, 2016, 10:02:50 AM »
Thanks!  Yeah, this has for sure been an exercise in patience.  Promised myself I wasn't going to rush, and I was going to learn as much new stuff as I could.  Been a pretty awesome process, but I still don't have a bike to ride yet!  ;D
Still have a nagging feeling in the back of my head that I'm going to get it all ready to go, hit the start button and it's going to blow up and catch on fire or something :-)
Offline Mule169
« Reply #32 on: May 15, 2016, 06:50:32 PM »
Ok,
So in what is becoming a bit of a theme for me... I didn't have as much time this weekend as I'd hoped.  Work is killing me.  So here's just the shortest of updates.
I marked out where I wanted to mount handlebar switches, punched center locations, drilled and tapped holes for the little mini switches I bought.
I used an old clutch cable with some tape on the end to feed all the wires through the bars to a hole I cut on the right-ish underside of the bars.
I also ran the brake light switch
This is how it all came out in the end.  Drilling into the bar, and clamping with all the bends meant that my placement was a little off (specifically the gap between the two switches between the left and right handlebars), maybe next time I'll see if someone has a mill, or I can create fixtures that would help keep bits from wandering, and allow me to go exactly perpendicular to the tube when drilling.  I'm still pretty happy with how it came out in the end.
I think I'm also going to take a scotch brite pad to the buttons to dull down that shine a little bit 8), too much shine and bling  ;)
I also am taking Cal's advice and I'm not going to use the m-Button to wire up all my switches.  I admittedly bought it cause it was "cool and part of the m-[product] line".  Sounds like with some of the older bikes, all of the control signals being send down that one bitty wire might cause problems.
I'm sure I'll do another build another day when I have more time, and I'll either use it then, or I'll sell it.  Thanks again Cal for the advice!
Seriously thinking about a PTO this week to make some serious headway on welding the speedo cup, wiring, and picking up parts, mounting rubber, etc.
Thanks again for taking a look, comments and feedback always welcome!
« Last Edit: May 18, 2016, 08:27:50 AM by Mule169 »
Offline Trad
« Reply #33 on: May 15, 2016, 07:39:42 PM »
Hey Cal, want to mail that too me so I can borrow it for a week? I'll send it back with a few little sohc4 goodies.  ;)
PS: that wiring is looking nice. You might want to consider bolting the reg/reg in on the bottom of the electonics plate. More airflow for keeping things cool. Just my two cents, keep up the good work homie.
« Last Edit: May 15, 2016, 07:42:15 PM by Trad »
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline theslayedsaint
« Reply #34 on: May 15, 2016, 08:46:09 PM »
Yeah Cal where did you get that?
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
Offline Mule169
« Reply #35 on: May 15, 2016, 09:20:44 PM »
« Reply #36 on: May 16, 2016, 10:12:29 AM »
That's a handy tool for bars.
« Reply #37 on: May 16, 2016, 08:01:06 PM »
Also I can't see the new photos again...... Anyone else?
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Offline Mule169
« Reply #38 on: May 16, 2016, 08:14:06 PM »
Should be fixed theslayedsaint, sorry for images continuing to drop off.  Google Photos must rate limit, or switch image URL's after a period of time.  I'll find a different way to host images to try and keep this from happening in the future.  I'm sure it's getting annoying.
« Reply #39 on: May 16, 2016, 08:39:48 PM »
Thanks for fixing it! the bars look really clean, way better then how mine turned out i also had issues with getting the holes right where i wanted them. the buttons you installed look great too, way cheaper then buying then from motogadget or other places. can't wait to spot your bike on the road this summer. keep up the good work.
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Offline Mule169
« Reply #40 on: May 23, 2016, 06:43:24 AM »
Small amount of progress this weekend.  I had a wedding to attend, and my car was totaled from a rear-ender, so I only got a couple hours to work on things.
Speedo cut and welded!  I tried to go as minimal with the bracket as I could and I think it turned out pretty OK.  My welding was even halfway decent on this thing.  Corner welding is the hardest for me so I'm pretty happy with the way it turned out.
And a couple with the speedo in.
I drilled a small hole for the speedo wires to route through, and they come right down by the handlebar switches.  Should be pretty clean once I get everything wired, and bundled up.  I'll be getting some sort of grommet to put in that hole when all is said and done of course.
Also just started running the control wires from M-Unit to front controls, and the ricks mounted up.
Ok, that's it for now!
« Last Edit: May 25, 2016, 05:10:22 PM by Mule169 »
« Reply #41 on: May 24, 2016, 09:32:01 AM »
I'd encourage you to abide the stock Honda wire colors. It will make troubleshooting for you and any future owner, much, much easier.  :-\
+1 don't ask how I know.
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
« Reply #42 on: May 24, 2016, 09:32:41 AM »
Also still can't see photos  :-\
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Offline Mule169
« Reply #43 on: May 25, 2016, 05:11:22 PM »
Ok, well I'm done with Google Photos, I thought I found a setting that would keep this from happening, but clearly not.  I just uploaded my latest round of photos to flickr and re-posted.  I'll go do the older posts later when I have time.
Sorry again, pain in the ass.
Offline Mule169
« Reply #44 on: May 25, 2016, 05:15:22 PM »
I'd take y'alls advice here if I hadn't already bought wire that followed the M-* wiring color scheme.  I'm going to update the wiring diagram I attached to this thread and make sure to have it available when/if I sell the bike.  I totally get why you'd keep it close to stock Honda, but again I spent the money on wire, and I'm half way into it right now.  I'll make sure the documentation is up to date, and hopefully this won't be too much of a first timer fubar situation.
Still appreciate the advice, and keep it coming, I've taken (almost) all of it when it has come my way!
« Reply #45 on: May 25, 2016, 05:17:29 PM »
Did you end up mounting the gauge with some rubber to isolate the road vibration?  also is your mount point just one bolt to the lower left.  You might need another mounting point to reduce stress on the mount.
Offline Mule169
« Reply #46 on: May 25, 2016, 05:26:14 PM »
I did order some rubber wrap, and an o-ring for where the face meets the cup.  My local hardware store didn't have either.  I'll install it before firing up and taking out and calling things done.
It's just on the bottom left.  I was a bit worried about that, in the end I bought a pretty heavy gauge steel for the mounting ear, and the materials cost me about $12.  I rationalized the approach in my head by doing a bit of thumb in the air engineering.  I'll monitor the mount for cracks, and in the end if I have to replace it, or re-build it I'm really out a small amount of money and some extra welding practice.
It's a good thought though, and something I'll probably follow up on after I've put some miles on this thing.
Offline Mule169
« Reply #47 on: May 30, 2016, 06:23:23 AM »
This one starts (again) with more excuses.  Just didn't have much time this weekend again.
I got the Headlight bucket all wired up, all the handle bar control side wires run, (not fully wired up).
I need to work on my shrink tube length consistency looks like :-[
And the headlight bucket - I'm realizing how awesome Cal's suggestion of staggering connectors down the cable runs back to the electrics tray vs. cramming them all in the headlight bucket is.  There's now so much room in there!  I remember taking the original apart and thinking I was never going to get everything shoved back in there.
Also got the M-Lock wired up and mounted
Feels like I got a lot left to wire:
  • Ricks
  • Hand controls
  • Seat latch solenoid
  • Speedo/Tach
  • Coils
  • Charging system
  • GPS Hot start cutoff
  • Neutral indicator
  • Oil pressure indicator
Hopefully I'll have enough time to bang all that out next chunk of time I get.  Also got word that my front rim is done at powder coater so I can get that laced up.  Still waiting on shocks, and swingarm from Hondaman, but I think most of those will go quick when I get them.
Then carbs and start er up!
« Last Edit: May 30, 2016, 06:26:54 AM by Mule169 »
« Reply #48 on: May 30, 2016, 11:08:00 AM »
Man that looks really nice! would love to hear your thoughts on the M-Lock when you get it all working do you think its worth the money etc?
also whats "GPS Hot start cutoff" guessing its some type of anti theft #$%*? are you really worried about the bike being stolen in Portland?
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Offline Mule169
« Reply #49 on: May 30, 2016, 02:38:54 PM »
I think I'll echo Cal's sentiments.  I read a lot of reviews from folks with multiple bikes, and above and beyond just the "cool" factor, I think it'll be useful on any other bikes I buy/build.  But yeah I'll post back if I have any issues.  I'm sure they'll be operator error if anything.
The "GPS Hot start" is a feature of the GPS speedo/tach I bought.  It has a wire that draws 25 micro amps that will poll for GPS location when you shut your bike off so that you don't have to wait for the speedo to acquire signal when you stop at the cafe for an espresso.
I'm paranoid and with the expensive ass battery I bought, I want to be able to shut that off with a switch when I get home, or during the winter so it's not drawing, so I'm just wiring in a switch that I can turn off/on when I'm done riding for a long period of time.  I'm sure it would take months if not years to drain the battery at 25 micro amps but I've learned to be skeptical of documentation.  Especially now that I got a few hours today, and was going to wire up the speedo/tach.
I went to wire up the turn signal and H-Beam indicators and this is what I see coming out of the back of the unit.  I guess if I used this unit I'd have a hard time knowing if my right turn signal and/or high beams were on.   >:( >:( >:(
I've sent speed hut an email and we'll see what they have to say.
