Author Topic: CR 750 reinforced cam cover  (Read 14390 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: CR 750 reinforced cam cover
« Reply #25 on: November 01, 2016, 09:56:24 AM »
I made them locally .... I have M10x0.75 , and M12x0.75 inserts. Internal standard M6. 1eu per peace
Sounds quite reasonable. Doubt you could have inserts welded in for that price.  8)
What size of external thread you are using? And what glue for threads....
I have not tried this yet, but I am getting close to giving it a go. I have not decided on an external thread size, nor have I decided on the sealer. Maybe red locktite on the threads in the valve cover and some Permatex anaerobic sealer at the top of the threads of the insert? Use a 6mm bolt with a jam nut so you can crank'em down tight, let the loctite set up, then loosen the jam nut and take out the bolt.
The white Permatex thread sealer may work as well, at the top threads of the insert and on the hold down bolts. I have good luck with the Permatex white on the cam tower studs.
« Last Edit: November 01, 2016, 10:47:53 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline slikwilli420
  • Master of Disaster
« Reply #26 on: November 01, 2016, 09:57:54 AM »
Do you have a picture of the inserts you are using?
Offline turboguzzi
« Reply #27 on: November 01, 2016, 11:50:42 AM »
mmm. am reading you all and considering the difficulties, looks like livefast_dieold idea's is a walk in the park, odd that no one is considering it...
« Reply #28 on: November 01, 2016, 11:58:15 AM »
Too stealthy. Hold down bolts sticking up out of the head is old school cool.  8)
Form and function!  ;)
TAMTF...
Wilbur
Projects:
« Reply #29 on: November 01, 2016, 01:08:00 PM »
Maybe self cutting tapping insert will be easy to use? No expensive tools needed except for a drill and bolt as insert driver.
M8, OD 12x1.5 threads that will get a good grip in the soft alu. Hole 10.7-11.4mm
https://eshop.wuerth.de/is-bin/INTERSHOP.enfinity/WFS/1401-B1-Site/en_US/-/EUR/ViewCatalog-Browse?CatalogCategoryRef=14016006020201%40WuerthGroup-Wuerth-1401&SelectedFilterAttribut=%5B%7B%22name%22%3A%22Female+thread%22%2C%22value%22%3A%5B%228+mm%22%5D%7D%5D&CatalogCategoryID=gj0KD92ekKAAAAE_k.MMbtVQ
I used a similar one today for M6
http://forums.sohc4.net/index.php/topic,161884.msg1859277.html#msg1859277
« Reply #30 on: November 01, 2016, 03:41:02 PM »
A thread in could work ..If they are flat underneath, AND there is clearance.........and I dont know if there is ?
I am not understanding the tapping problem, hold the tap tight in drill chuck, undo the belt, turn the chuck by hand with one finger pressure pulling down on the handle.... Not going to bend a 10mm tap..
« Last Edit: November 01, 2016, 03:44:38 PM by 754 »
« Reply #31 on: November 02, 2016, 02:29:04 AM »
Just tap M8 for the M8 stud without insert must work too. Insert to be used when possible IF the threads are damaged. Stud should not be removed anyway. Different with threads frequently tightened and bolts removed.
Offline MessnerMoto
« Reply #32 on: November 02, 2016, 05:15:21 AM »
Yoss this would work if you want to split rocker pivots. I have made loose rocker pivots. So this is not an option for me.
Trust me taping a hole on slope surface and thin material is a big problem. You don't get continues thread in hole because there is a big difference in lowest and highest edge of hole. I ruined one cover. from 10 holes I tried 4 were acceptable...
« Reply #33 on: November 02, 2016, 08:39:28 AM »
If the thread is un even time to weld... If it cant hold a bolt , how can it hold an. Insert..?
Offline livefast_dieold
« Reply #34 on: November 02, 2016, 01:58:18 PM »
Finally some recognition! What's wrong with these guys Yossef?!? :-)
« Reply #35 on: November 02, 2016, 02:07:55 PM »
The bigger stud only holds down the middle, not the outside ends.. The cam cover holds down outside ends.
Back to tapping, and I looked at the CycleX stuff..
Tap selection and rigid holding of tap should work easily. Make sure tap has a lot of threads champhered, and hole is properly champhered, before tapping......not sure what you did that did not work...
« Last Edit: November 02, 2016, 02:25:53 PM by 754 »
Offline Haybus
« Reply #36 on: November 02, 2016, 07:05:38 PM »
I made the threaded version like Cycle X without issue. Weeped out of 4 locations all weekend during my first race round. The cam cover gets pretty warm, even with the Setrab cooler. I'm guessing warm enough to fail the Loctite on the studs and Hondabond on the inserts. Probably could have done some more to seal them up, but it's too much to worry about when racing. Plus, the two middle back ones don't come out without pulling the motor. I made all the inserts from 6061 so I could weld them if needed, but I don't think that cam cover is ever going back on my motor. Just my 2 cents
Alan
75 CB750
76 KZ900
Offline MessnerMoto
« Reply #37 on: November 03, 2016, 01:22:27 AM »
Yes I agree with how ends of rocker boxes need to be held
But you are right this is also not a bad solution.
Alan
What tap type and size did you use and did you use red Loctite?
« Reply #38 on: November 03, 2016, 04:22:22 AM »
M8 bolt will keep the cam holder better, right? - What about the cam, that one has only down forces and nothing that want to kick the caps?
« Last Edit: November 03, 2016, 04:34:28 AM by PeWe »
Offline Jim F
  • go baby go
« Reply #39 on: November 04, 2016, 06:08:58 AM »
mine is working great that I did my self and I think I did one for mike Reick
cut and milled to lenght, tapped for I think 8 mm with locking nuts.
welded out side with TIG and laser welded the inside
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline bear
  • Leeton in Australia
« Reply #40 on: November 04, 2016, 03:58:40 PM »
Craftsman quality as usual Jim. ;)
Offline Jim F
  • go baby go
« Reply #41 on: November 04, 2016, 06:49:51 PM »
Thank you sir :)
Online scottly
« Reply #42 on: November 04, 2016, 08:42:58 PM »
Jim, why did you Tig the outside and laser the inside? I would think your Tig fillets on the outside would have been adequate?
« Reply #43 on: November 05, 2016, 01:34:44 AM »
Fabrication of welded covers?
Offline Jim F
  • go baby go
« Reply #44 on: November 05, 2016, 05:58:01 AM »
I wanted to seal them up completely just in case. If there was
A leak if I didn't weld the underside it would be very hard to
Get the oil out to weld them
I am known for over engineering everything that I do
Which is good and bad.
« Reply #45 on: November 05, 2016, 06:21:56 AM »
It's all good Jim. ;)
Online Jerry Rxman Griffin aka MuthaF'er
« Reply #46 on: November 05, 2016, 09:48:51 AM »
Now Scottly, if you had a laser you'd do it too. LaserMan leaves no weld behind!
Offline Jim F
  • go baby go
« Reply #47 on: November 06, 2016, 11:53:13 AM »
 ;D :D :D
« Reply #48 on: November 06, 2016, 02:06:20 PM »
Laser is good stuff for those who can control it
"may the force be with you"
Online scottly
« Reply #49 on: November 06, 2016, 07:07:10 PM »
Sigh, I only have a stone-age TIG to work with. ;D
