Author Topic: Best quality seat covers??  (Read 4271 times)
Offline willial
« on: March 15, 2017, 04:48:34 PM »
I have tried the search option in order to see if there is info already out there on this topic, but I had no success with it (probably me!!).  Can anyone direct me to the best place to buy a replacement seat cover for my 1977 CB 750?   I will need the strap, and strap hardware along with the cover.  Am I correct in saying that the design in the padding on the top of the seat cover is "pressed" into the originals, and that some replacements are sewn in, or am I wrong about that?
Thanks
Larry
Offline tlbranth
Re: Best quality seat covers??
« Reply #1 on: March 15, 2017, 05:52:17 PM »
It's been a while so I can't give names but I bought a seat cover for my K0 on ebay and it is spectacular. It's stitched instead of welded. Fits like a glove. I don't think it came with the strap - I think I used the original.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Gene
  • Chat enuf you too can be a
« Reply #2 on: March 15, 2017, 05:56:53 PM »
gumtwo on eBay. That's the stitched one - affordable and well made.  I've got two of them currently. Can't say enough good things.
*1973 CB750K3 (Bow)
Offline przjohn
« Reply #3 on: March 15, 2017, 06:06:22 PM »
Ditto
Offline jonda500
« Reply #4 on: March 15, 2017, 06:12:22 PM »
The pattern is originally pressed into the cover. Ebay seller gumtwo has the seatcovers with the pattern stitched rather than pressed in. Most ppl in here give it a good review. I have one - it fit perfectly, seems to be good quality and is very comfortable. Tight-fit-seats (UK seller) has replica covers a little cheaper that have the pattern pressed in. I have one of them too, but I haven't used it much yet - so far it seems maybe a little less durable and comfortable.
John
A starter clutch thread:
Offline willial
« Reply #5 on: March 15, 2017, 07:22:30 PM »
Thanks for the help everyone.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #6 on: March 16, 2017, 04:48:26 AM »
If you get a gumtwo, make sure you put some plastic wrap or some plastic sheeting under the cover. That way water won't soak your foam through the stitching.
--Evan
1975 CB750K "Rhonda"
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: March 16, 2017, 06:13:04 AM »
It also helps prevent the cover from getting "hung up" on the foam while pulling it into position. I wrapped my seat from side to side all the way around with overlapping passes from front to back with saran wrap and then trimmed it underneath so it folded under the bottom edges with the cover leaving it just short enough so it did not "peek out" from under the cover.
New gator teeth upholstery strips riveted to the seat pan to hold the new seat cover:
New skin stretched into place:
All that work just for this:
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Deltarider
  • I'm back
« Reply #8 on: March 16, 2017, 08:40:54 AM »
Seriously, what good is a buddyseat cover if it can let water into the foam??
« Last Edit: March 16, 2017, 08:44:25 AM by Deltarider »
CB500K2-ED Excel black
Offline willial
« Reply #9 on: March 16, 2017, 11:24:44 AM »
I appreciate the help.  Does anyone have any experience with covers from Morreti Direct in the UK, and if so are their seams pressed versus sewn.  Is there a good source for the strap hardware.
Thanks again
Larry
Offline willial
« Reply #10 on: March 23, 2017, 06:52:12 AM »
For anyone's future reference, Gumtwos CB 750 K7 seat cover is patterned more after the K8, and is sold to cover either year.
Larry
