Author Topic: Where to buy custom length brake lines?  (Read 5933 times)
« on: July 12, 2015, 09:42:13 AM »
Slingshot is closed, hard to believe Shawn cant find banjo fittings!?
http://slingshot-cycles.com/
Regardless, where are you guys now ordering custom brake lines?
Re: Where to buy custom length brake lines?
« Reply #1 on: July 12, 2015, 10:35:25 AM »
Get a hold of Earl,s Supply.. Make your own..
. I myself dislike the banjo fittings..never look as nice or clean as a regular fitting..
I am starting to wonder...what is it about wrapping tape around a braided line, cutting it with a hacksaw, assembling it with two wrenches... That seems to make this a daunting task?
« Last Edit: July 12, 2015, 11:47:02 AM by 754 »
« Reply #2 on: July 12, 2015, 12:10:04 PM »
Did you mean Earl's Performance?
http://www.summitracing.com/search/brand/earls-performance/part-type/brake-fittings?N=400041%2B4294947829
I dont really care to spend $100 on supplies and tools to make an OEM style $15 line, Frank!
Offline Stilltime
  • Building my Dream
« Reply #3 on: July 12, 2015, 12:19:40 PM »
It might be an extra couple fittings, but you can buy the 10mm banjo to -3AN and the adapter from the caliper to -3AN and buy a preassembled Earl's or Aeroquip -3AN female to female line.  Total cost was going to be around $25 when I priced it before I found out about Slingshot.  Wish I could get another from him though :(
'78 CB550 - Orange Crush
« Reply #4 on: July 12, 2015, 01:00:00 PM »
Some things are just worth paying money for..
Also you can shorten an existing line from their components,  and reconfigure..
Gotta be easier to make and  install than a stock airbox.. The best fitting brake lines are the handmade ones..
JWExperience
« Reply #5 on: July 12, 2015, 01:18:34 PM »
I bought my set from coastgaurd1975 on eBay. Great guy to work with and I thought very reasonable prices. He made custom length lines for me and used fittings I asked for
Offline brandEn
« Reply #6 on: July 12, 2015, 01:28:34 PM »
Never tried the brakelines but I love the 888 throttle kits. Good customer service.
https://www.venhillusa.com/
Offline socal1200r
« Reply #7 on: July 12, 2015, 03:41:51 PM »
Try cyclebrakes.com, I think they can custom-make Galfer lines with different colors and different fittings...
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline CBGhia
« Reply #9 on: July 12, 2015, 06:49:32 PM »
Steve, I bought one of these for the 550...
http://www.amazon.com/Streamline-Universal-Braided-Stainless-Steel/dp/B0039SFKA0
I bought the 30", so just measure what you need.
« Reply #10 on: July 13, 2015, 03:37:27 AM »
Dang!
Offline DaveBarbier
« Reply #11 on: July 13, 2015, 03:45:34 AM »
Call up Raymond from www.rennsportautoparts.com
He does custom lines with different colors and fittings. I've gotten a few lines from him and I like them a lot. I heard about him from Godffrey actually.
« Reply #12 on: July 13, 2015, 05:46:14 AM »
Thanks for all the options, guys.
Offline Bodi
« Reply #13 on: July 13, 2015, 06:31:14 AM »
Earl's is about the easiest, and the finished line is DOT approved (no custom line from a hydraulic shop will be, not that it really matters). It gets expensive if you copy the Honda plumbing... but using a single line from MC to caliper it's fairly cheap: you need a switch banjo for brakelight activation though. This also cleans up the system and makes bleeding out all air much easier - that switch tee is a nightmare to de-air. One line and two fittings will be all you need. Remove the seat from the caliper hardline port (screw a sheetmetal screw in and pull it out) and you have a 10x1 (maybe x0.75?) thread that a banjo bolt will go in. You may need 2 crush washers under the banjo to clear the counterbore. Braided flex line with a slightly angled banjo on the caliper end looks good and works great. Just leave enough for flexing, a tyrap at the fender loop keeps it in place.
Offline DaveBarbier
« Reply #14 on: July 13, 2015, 06:43:50 AM »
M10x1.25 banjo bolt.
Offline CBGhia
« Reply #15 on: July 13, 2015, 07:43:27 AM »
The Streamline line I bought came with both banjo bolts and crush washers! That was a huge plus (and a surprise because I had ordered them separately)
« Reply #16 on: July 13, 2015, 08:27:28 AM »
For decades you could get premade lines in 2 inch increments..Drag Specialties. Was one supplier.  Then you need an adaptor for both ends..  But as I mentioned it is often a compromise. Making the line to fit your bike, can look much better..
The only place I would maybe run a banjo is on the 500. Calipers, and late 750..but there are ways around it.
 I just don't see the attraction of the often bulky banjo, plus there is two surfaces to leak rather than one..
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #17 on: July 13, 2015, 08:32:19 AM »
http://4into1.com/stainless-steel-brake-line-kit-black-single-line-honda-cb450-cb550-cb750/
This is where I'll get mine if Slingshot isn't back in service in a month or so...
--Evan
1975 CB750K "Rhonda"
Offline 78whiteorbs
« Reply #18 on: July 13, 2015, 12:46:51 PM »
+1 on the Goodridge brake lines from Z1. They have the adapters to eliminate the hardlines and every size you need for any handlebars. Good price to , best I could fine.
Offline evanphi
  • Apparently I'm an
« Reply #19 on: July 13, 2015, 05:55:59 PM »
That looks like a good option from Z1. Cheaper than my link, I think.
--Evan
Offline Djfob
« Reply #20 on: July 13, 2015, 06:56:44 PM »
I'll second this, too bad slingshot took a break.
78 CB750k
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #21 on: July 14, 2015, 01:12:13 AM »
Yeah I liked supporting sean at slingshot... maybe he just got sick of it?
« Reply #22 on: July 14, 2015, 03:25:38 AM »
He says he is closed till he gets supplies:
Unfortunately we are still closed due to our supplier not being able to get us 10mm banjo fittings. This is THE MOST used fitting for our offerings and we can't accept orders without them. So until they are available and in our possession again we will remain closed. Sorry for the inconvenience. We'd like to make money just as much as you'd like to order hoses. :(
Offline slikwilli420
  • Master of Disaster
« Reply #23 on: July 14, 2015, 07:04:47 AM »
I would also recommend the Goodridge lines with their fittings. As 754 stated, you could also forgo the banjo and get a fitting that adapts from the -3AN of the brake line right to the thread of your caliper. I will be using them on my AP Racing calipers.
Offline evanphi
  • Apparently I'm an
« Reply #24 on: July 14, 2015, 07:11:44 AM »
This one for stock calipers  M10x1.25 thread:
http://www.z1enterprises.com/ItemDetails.aspx?itemDescription=Brake+Hose+10mmx1.25+MALE+TO+MALE+ADAPTER&item=GR306-03-32CH
« Last Edit: July 14, 2015, 07:17:03 AM by evanphi »
--Evan
