Author Topic: RE: Tytronic Electric ignition $75 from China  (Read 61482 times)
Re: RE: Tytronic Electric ignition $75 from China
« Reply #275 on: March 15, 2023, 01:41:49 PM »
I remember my mate Davey telling me about his old Kawasaki Avenger 350’s tank becoming “live” on one very wet ride in the 1970’s, and zapped him in the balls when he blipped the throttle at a set if lights, like all of us, he’d been kicked in the nuts once or twice, but he said nothing compared to an angry Avenger… ;D
Offline WideAWAKE
« Reply #276 on: March 15, 2023, 04:16:28 PM »
My order shipped from USA
https://www.ebay.com/itm/155231948547?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=5tYHHEJBQ9C&sssrc=2349624&ssuid=XgCEg0CPSya&var=&widget_ver=artemis&media=COPY
Be interested to hear your feedback on it when you get it.
I mean it’s pretty simple (magnet and 2 sensors) and compared to some ignitions (boyers come to mind) it seems of a higher quality. My Boyer looks like it was assembled from items at the local hardware store and it was $250 (it did come with a coil though)
« Reply #277 on: March 15, 2023, 05:39:10 PM »
The crappiest electronic ignition I’ve ever had was a Prestolite ignition for a CB750, I bought several for only a few bucks from a guy in the US, they worked about as good as they looked and I think I threw them away, from memory. ;D
Offline C317414
« Reply #278 on: March 15, 2023, 06:52:24 PM »
Looks are deceiving.  I've installed and used many Boyer ignitions in the last 40 years, and have never had one fail.  They are expensive, but they control the advance electronically, and are not dependent on a mechanical advance mechanism.
Offline WideAWAKE
« Reply #279 on: March 15, 2023, 09:04:02 PM »
Electronic advance depends on which ignition you buy, Some use a mechanical advance still. And they fail, not often, but it’s definitely got its faults and failures
« Reply #280 on: March 16, 2023, 01:37:33 AM »
ive used a lot of boyers and there fine,ive had one on a 500/550 for i think 15 years and lots of miles all good,hey Terry i used to have an old 73 yammy DT400 they had cdi,id get a shock from the bars sometimes if it got wet,never did figure out why?
Online Deltarider
  • I'm back
« Reply #281 on: March 16, 2023, 03:37:37 AM »
To put things in perspective, all EI's are but a switch in the NEG path of the IGN. You can brand your product with a posh Blabla & blabla name, even add the adjective Royal, but that's what they all are: a switch.
Then this: even the design I have used for mine, warns in its original manual that you may have to renew the plugs more frequently as electrodes may erode quicker. I don't know what most of you're after, but as far as spark energy, for our models, a simple transistorized device is plenty. The standard OEM ignition already was. Mike Hailwood won all his races with breakerpoints...
The task of the sparkplug is two-fold:
1. Ignite just that little mixture around its electrodes. The flame front will take it from there.
2. Stay relatively clean so it can continue to perform 1.
That's all to it.
« Reply #282 on: March 16, 2023, 04:16:49 AM »
I have got them. Ordered 2.
I have not tried any of them yet.
I also have China coils that look like Dyna 5ohm coil.
« Last Edit: March 16, 2023, 04:19:33 AM by PeWe »
Online Deltarider
  • I'm back
« Reply #283 on: March 16, 2023, 05:17:54 AM »
Personally I woudn't use that blue connector. They are notorious unreliable. No pro mechanic would use them.
Offline WideAWAKE
« Reply #284 on: March 16, 2023, 07:14:48 AM »
Yeah those are garbage.
I ditched it and used correct bullet connectors.
« Reply #285 on: March 16, 2023, 10:11:18 AM »
The package with the blue exactly as Dyna-S.
I feed it from the relay I have added close to battery. The ignition has an own fuse.
« Reply #286 on: March 17, 2023, 03:33:27 AM »
yeah those "scotch locks"are crap and should be illegal there so #$%* house?they include them so even dumb #$%*s can install the unit?
Online bryanj
« Reply #287 on: March 17, 2023, 05:02:49 AM »
Have you seen the "waterproof" ones filled with a gell stuff Dave?
« Reply #288 on: March 17, 2023, 05:08:15 AM »
yeah ive used that type bryanj,supplied by a cable company for if we used to have to cut and use as a pull through existing phone lines to install pay tv years ago then re join them,.we also used what we nicknamed "snot blocks" that were just a gell filled block of grease in a plastic enclosure we would just snap close dodgy connections we had made,pretty #$%* but hey?we got paid?
« Last Edit: March 17, 2023, 05:16:54 AM by dave500 »
Offline Bailgang
  • Scott
  • Indiana
« Reply #289 on: July 10, 2023, 03:24:54 PM »
About 5 or so years ago I rolled the dice and purchased a Tytronic EI for my wife's cb350 twin and have been pleasantly surprised by how reliable it's been so I decided to get one for her cb400F. It arrived over the weekend and this time though I wasn't impressed. To put it in a nutshell, the aluminum rotor they sent me that replaces the points lobe was a raw casting (it's not billet). Its magnets were installed but no other machining was done to it and wouldn't fit onto the mech adv. I'm aware that not all mech advances on cb400F's are the same, earlier ones had a smaller shaft that the rotor fits on compared to later 400F's that had a slightly larger dia. I double checked mine before ordering and confirmed mine had the earlier smaller dia. Now I coulda/shoulda contacted the seller and requested a replacement but I'm impatient, and lucky for me I have a lathe and small boring bar so I opened the inside bore of the rotor the .010" it needed but it wouldn't go all the way because the slots on the end that fit over the advance weights weren't finished either so I had to do some careful filing of those slots to take care of that. It's all together and running now and all seems fine, I must admit the built in timing light led's is convenient but the fact that they sent me an unfinished rotor is not cool and I was lucky to have the shop equipment needed to finish it however most of you probably don't. Did my rotor fall through the cracks of their quality control and just an isolated incident or is there more out there? I can't answer that nor can I get Tytronics web site to come up, is it a server issue on their end or are they even in business anymore? Either way how would you be able to contact them for a replacement? With that said, buyer beware.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #290 on: July 10, 2023, 05:21:32 PM »
Yep, I recently bought a Tytronic ignition for my Suzuki T500, same issues, the backing plate was a smidgeon too big and I had to machine it and the rotor to fit. I followed their fitting instructions to the letter, but I couldn’t get a spark out of it, so ripped it out and installed NOS points and condensers and it fired right up. I can’t speak for their other ignitions, but this one was garbage. Not the most money I’ve wasted on aftermarket parts, but annoying just the same. ;D
Online Deltarider
  • I'm back
« Reply #291 on: July 11, 2023, 01:05:29 AM »
It's typical for the Chinese vision on doing business: first profit from good reviews, then go cheaper and inferior.
Offline rotortiller
« Reply #292 on: July 11, 2023, 04:57:53 AM »
Did a quick search as I did not know they even had a website. Your resurrection of the post got me interested as mine is still going strong after many years. Good thing the inverse situation was not at play in your case, too big a part cannot be made smaller as easily lol. I have a small lathe that has saved my ass on many occasions often extending product life and repairing children's toys, tools, motorcycles etc. Good luck.
website http://www.tytronic.com/tytronic/products/16472228_0_0_1.html
contact https://www.ebay.com/itm/114921733610?hash=item1ac1de7dea:g:kmIAAOSwYIxX43ER#LISTING_FRAME_MODULE
« Reply #293 on: July 11, 2023, 05:18:09 AM »
FYI…. $15 less on their website vs. EBay.
Online bryanj
« Reply #294 on: July 11, 2023, 05:31:12 AM »
Website wont work for me, clunkiest onecever
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #295 on: July 11, 2023, 06:40:17 AM »
Time to update the title of this thread. Even going through their website it's now $80 with $20 shipping = $100...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #296 on: July 11, 2023, 09:52:29 AM »
Same for me. It’s pretty inconsistent.
Offline redbaron
« Reply #297 on: July 11, 2023, 10:21:42 AM »
1976 Honda 550F - I just bought a Chinese electronic ignition for $57 from ebay. Bike runs great! I rebuilt the last bike 5 years ago and the chinese knock offs were not available, only Dyna for $150.  I will let you know if it fails.
« Last Edit: July 11, 2023, 10:46:46 AM by PeWe »
Offline WideAWAKE
« Reply #299 on: July 11, 2023, 01:42:57 PM »
