Author Topic: Joke, or mood lightener of the day.  (Read 143871 times)
Re: Joke, or mood lightener of the day.
« Reply #1575 on: January 02, 2024, 06:16:55 AM »
Reminds me of Camry water pump on the timing belt.
HA! I just did one of those this weekend!  8)
I feel your pain.  My greatest struggle was the bottom pulley flange bolt.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #1576 on: January 02, 2024, 06:47:04 AM »
The pulley bolt was stubborn, but finally succumbed to the impact driver after eliminating the extension and using just the socket on the impact. The power steering belt proved my biggest hurdle since the pump would not swing the full extent of the slotted bracket coming up about 1/4" to 3/8" short. The pump housing was hitting the pump pivot bracket before reaching the full extent of the slotted bracket. I thought maybe I had the wrong belt at first, but both belts showed the same part number on the belt. I had to remove the pivot bracket from the engine and grind enough clearance off the pivot bracket for the pump body to get a full swing. The old belt must have been on the long side of manufacturing tolerance while the new belt must have been on the short side. Toyota usually does a better job on their engineering efforts...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #1577 on: January 02, 2024, 07:08:22 AM »
I had to buy 1" impact wrench from HF and drive to our hunting club for bigger compressor to get the bolt loose.
And my cam was between teeth on the belt - and I made a wrong choice.  It ran, but the timing was too retarted and the mpg went through the roof.
« Reply #1578 on: January 09, 2024, 05:32:46 AM »
« Reply #1579 on: January 12, 2024, 04:03:02 PM »
« Reply #1580 on: January 12, 2024, 11:37:32 PM »
Merry Christmas!
Nice...
Saw a few burning cars, all hybrids or full electric except maybe one in Phoenix Jan 1st...
It was only in the engine bay area so it likely was an international combustion engine, was a nice looking car before the funeral pyre flames reaching 20 feet into the air became roasting the vehicle. No one was near the vehicle and Fire hadn't been dispatched yet but Police were aware of the activity by the time the 911 operator stepped me through first doing fire and if needed EMS. Was parked beside I-10E bound near an overpass on one of the exits near Chandler. Yeah, they can rebuild it, not...it's beyond toast. Several electrics along I20 in full engulfed and firetruck pumpers pouring the water in them while the lithium batteries belched toxic black pyres into the skies. The smoke is likely going to killing anyone who would inhale more than 4 times that black acrid toxic mess if they got that close. The police present and traffic reducing from 65 or 75 to 25 to 30 as the water streaming across the roadway like a river was a huge hazard...
Of course all of them getting water dumped in them no longer had any windows as the heat and water caused them to explode like bombs if the fire hadn't breached them already. The ones I find interesting and kinda amusing are the initial fires before a fire truck arrives, the interior is on fire first as the battery packs are beneath you.  So the car guts it's luxury interior first...even if you could put it out, an interior fire will total the car unless put out in the first minute and even then I am gonna bet many get totalled even then. Had a coworker with a Pontiac Fiero GT get flooded in her apartment complex in Columbus Ohio years ago, the car had water up to the bottom of the dash. The insurance company paid to repair it and it like most flood cars are nothing but trouble after that...they aren't Jeep off road built vehicles enthusiast will strip and build to ford creeks and rivers and other outrageous things because they can and are a bit crazy...
It isn't like in Africa and other countries around the world where you do that kind of small or not so small river fording because that's the only way to get there...
« Reply #1581 on: January 12, 2024, 11:40:20 PM »
Went through the roof good phenomenal  mpg but almost inability to be driven?  Or, it went through the floor dropping to near nothing?
« Reply #1582 on: January 12, 2024, 11:43:57 PM »
Enjoy!
« Reply #1583 on: January 13, 2024, 03:53:11 AM »
You are right. Mpg dropped through the floor.   :).  From 300+ on tank to 150 or so.
Online PeWe
« Reply #1584 on: January 13, 2024, 07:22:55 AM »
Fun for me and my bikes. I can still hear them happy in the garage! ;D
Rental giant Hertz dumps EVs, including Teslas, for gas cars
https://www.reuters.com/business/autos-transportation/hertz-sell-about-20000-evs-us-fleet-2024-01-11/
https://abc7.com/hertz-electric-vehicles-ev-fleet-to-sell-evs/14314533/
« Last Edit: January 14, 2024, 07:08:04 AM by PeWe »
« Reply #1585 on: January 13, 2024, 12:27:20 PM »
It is a commit used expression and misused I knew what you meant but it struck me if it improved immensely at the cost of being almost inoperable... Usually the mpg crashes to the depths when you go out side the recommended range of timing values has been my experience when I screw up something. The potential for engine damage is there on interference car motors and our bikes are interference designed motors.
An old  car I owned wouldn't crash the valves and do head damage if the timing belt broke. It was nice not to have that expense if something went pearshaped or you forgot to do the belt every 60k miles as recommended. Never had a belt break in me but read many cases where those neglected or busy folks got but by it, the retaining the distributor's ntermediate shaft, the crank, and the camshaft in the OHC design was a pain but your error wasn't criticized by that forum crowd, just tried to be helpful and gave instructions on easy methods to fet everything back in time. I have trouble with sharp angles you were confined to for that problem would be solved by a large mechanics inspection mirror on a rigid collapsible wand. That was how I made sure I wasn't putting the intermediate shaft a tooth out or the crank. The OHC camshaft was very easily seen and accessed. Simple motor design but not a ton of HP and torque.
WS a forgiving design to learn how to work on cars and scratch the itch of working with my hands...
« Reply #1586 on: January 21, 2024, 10:05:45 PM »
A little late on the spring one ...
« Last Edit: January 21, 2024, 10:08:10 PM by RAFster122s »
Offline dhall57
« Reply #1587 on: January 22, 2024, 03:06:12 AM »
 ;D
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #1588 on: January 26, 2024, 09:18:04 AM »
« Reply #1589 on: January 26, 2024, 09:27:52 AM »
The thing I've liked most about the electric car this very cold winter has been that they don't clog up the snowy streets.
My JEEP steers easily around those that tried.
« Last Edit: January 26, 2024, 09:33:14 AM by HondaMan »
« Reply #1590 on: January 28, 2024, 11:38:21 PM »
 :o
« Reply #1591 on: February 02, 2024, 03:46:42 PM »
 :o
« Reply #1592 on: February 03, 2024, 04:25:42 AM »
New paint job.  ;D
Online PeWe
« Reply #1593 on: February 03, 2024, 07:37:31 AM »
Chicken race? ;D
« Reply #1594 on: February 03, 2024, 09:51:25 AM »
 Owning a GS1100e has lessened my distain for twin cam motorcycles.
« Reply #1595 on: February 03, 2024, 10:31:30 AM »
Chicken race? ;D
Not enough feathers???
Offline Kelly E
  • Geriatric Hooligan
« Reply #1596 on: February 03, 2024, 05:03:37 PM »
Yep, we love having a variety of bikes to choose from when it's time to ride. We have a great selection of bikes to pick from and every one of them is fun to ride in it's own way. I believe that many people miss out on some awesome bikes because they are overly brand/ bike specific loyal.
Broaden your horizons and you will be surprised and happy with what you find. I've seen brand loyalists so stubborn that they won't even try a different bike. Sometimes I think that they are afraid that they might like it better than the bike they've put on the pedestal. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #1597 on: February 03, 2024, 05:33:18 PM »
No joke !  ;D
« Reply #1598 on: February 03, 2024, 10:14:57 PM »
Never hurts to do your research as many bikes were real dogs and a bad idea to try to resurrect as they were problem childs with known issues on electrical components or handling, etc.
Vintage bikes with sucky brakes compared to modern bikes is but one issue in some vintage machines. As long as you ride the vintage bike with due caution it works, problem is in city traffic the asshats will take your stopping buffer almost Everytime and be a jerk to you if you try to educate them. People don't give a #$%* about your safety or your buffer zones you try to maintain around you. I've had an #$%* in a Mercedes Benz Gwagin SUV be less than 5 feet from my rear tire while riding one city street in Tucson. He would not back off and I was doing 15mph over as was the guy behind me. I wanted to do physical harm to him as Zi motioned for him to back off and he would not. You want to beat these people to an inch of their life as they will kill you if you hit something you don't see as they don't have reactions that are that good, despite their inflated entitlement and sense of superiority. Those people need to die from their choices but they will not. Few people get me angry like those entitled rich #$%*s. Sorry this isn't the pissed off thread...
« Reply #1599 on: February 03, 2024, 11:27:32 PM »
I'd like to see many of them lose their entitled attitudes;same here.
